BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > Mechanical Maintenance: Break-in / Oil & Fluids / Servicing / Warranty > "Blow By" Oil Residue on Power Steering Reservoir
      08-03-2012, 06:25 PM   #1
kfrazie1
kfrazie1's Avatar
64
Drives: 335i
2007 E90 335i
Auto Trans
71,000 miles
No OCC
BMS Dual Cone Intake
I seem to be getting some oil residue being blown onto the power steering reservoir tank on the driver side near intake cones. Trying to figure out where this is coming from. Any ideas? Could it be diverter valves blowing out oil to atmosphere carried over from PCV loop? I'll add a picture.
Keith
Montego Blue E90 335i
7" VRSF IC | OFT Tune | DCI | RB PCV | Secondary CAT Delete & CYBA 3.75" Tips | M3 Front | Mtech Rear | CSL Trunk | 219M | KW V1 | AA CP
      08-03-2012, 06:40 PM   #2
gzim335
gzim335's Avatar
Drives: e92 m3
2007/1 e90 335i  [2.00]
its a small rubber tube thingy on the cap replace n ull be good
e92 m3 dct
gintani stage 2+ full ethanol custom pulley and meth
kw clubsport,ap racing radical,volk te37sl,akrapovic rear,recaro profi xl,voltphreaks battery
      08-03-2012, 07:29 PM   #3
kfrazie1
kfrazie1's Avatar
64
Drives: 335i
Well i dont think its a problem with the reservoir. Its seems like its oil coming from something else.
      08-05-2012, 08:15 AM   #4
leebermeister
Drives: 06 330i
Oil filter housing gasket?
      08-05-2012, 09:43 AM   #5
EJ_3
EJ_3's Avatar
Drives: e92 335i, e34 525i & e60 530i
2007 BMW 335i  [8.34]
2016 Ram 1500 Sport  [8.00]
1994 BMW 525i  [10.00]
2007 BMW 530i  [8.66]
Sounds like a pinched o ring maybe, check around your oil filter. I had the same problem a few weeks ago.
      08-05-2012, 02:35 PM   #6
Surly73
535
Drives: '11 535xi 8AT KWv3 MPE MHD xHP
I second gzim's initial reaction that it's the PS reservoir leaking. Every BMW I've seen in the last 15 years seems to have (or develop) a leaking PS reservoir. You seem pretty convinced that's not it though - can you supply a pic?
      08-07-2012, 07:11 PM   #7
kfrazie1
kfrazie1's Avatar
64
Drives: 335i
      08-08-2012, 07:48 AM   #8
Surly73
535
I still think it's the cap and/or it's coming from that vent hole.
There could be something going on with a blockage of the internal filter, or something else causing the level to be higher than normal.
Try:
- cleaning it up
- replacing the O-Ring
- insert a Q-tip into that vent hole you can see in the cap and break it off so that there's still enough stalk to pull the Q-tip out. This allows it to vent but dramatically reduces the changes of liquid coming out.
From what I see, I don't think this is coming from anywhere else upwind of the reservoir - I see it all the time on BMWs.
      08-08-2012, 09:28 AM   #9
raceyBMW
king of the hills
raceyBMW's Avatar
92
Drives: 2011 M3 w/ESS55, 2001 540i/6
2001 BMW 540i/6  [8.17]
1994 530i  [9.00]
2007 335i Coupe  [8.37]
Looks like a leaky cap o-ring for sure. Make sure also that the PS Fluid level isn't to high (check when engine is warm).
Part #12 here
http://www.realoem.com/bmw/showparts...41&hg=32&fg=20
      08-08-2012, 02:41 PM   #10
cvc 22349a
cvc 22349a's Avatar
Drives: 335i
Part #12 here
+1. Had the same issue and replaced o-ring.
2007 E90 335i, TiAg, 6AT, ZPP, ZSP, ZCW, 6FL, HD
Quaife lsd, ETS fmic, GIAC s/w, Dinan intake/exhaust/oc, Koni/M3 susp, Apex Arc 8, Mich PSS
      08-08-2012, 06:29 PM   #11
kfrazie1
kfrazie1's Avatar
64
Drives: 335i
Try:
- cleaning it up
OK, I'll try that and report back.
      10-13-2012, 07:02 PM   #12
jalberto
Drives: 335i
Did it work?
Did the fix on the power steering cap solve the oil issue? I have the same problem. Tks
J
      10-15-2012, 11:49 AM   #13
g9sBMW
g9sBMW's Avatar
23
Drives: 2007 BMW 328i
2007 328i Sedan  [0.00]
I had the same build up of oil on my power steering reservoir . . . and it was the oill filter housing in my case.
[2007 328i|Black Sapphire|Terra Leather|6 MT|Xenon headlights|BMW Alarm|Clear Bra|Stainless Steel Pedal Pads|Black Line Tails|MTEC V3.0 Angel Eyes|HUPER OPTIK 30 Ceramic TINT|GPThunder Fogs|LED License Plate mod|Sport Shocks/Springs upgrade|ZHP Shift Knob|//M Dead Pedal|Matte Black Grill|Aluminum Strut Bar|Cyba Air Scoops|Rear Fog Switch|Perforated Mtech Wheel|Miro 935s|Hankook v12 evo Tires|BMW SSK]| BMW PE
      10-20-2012, 03:36 PM   #14
kfrazie1
kfrazie1's Avatar
64
Drives: 335i
It turned out to be just a loose cap!
      01-09-2013, 10:43 PM   #15
abhishriv
100
Drives: 2007 335i Coupe (Space grey)
i think i have the same problem, did you change the fluid too?
      01-10-2013, 12:12 PM   #16
kfrazie1
kfrazie1's Avatar
64
Drives: 335i
Not yet, on my list. Its still leaking just a bit.
      04-06-2013, 10:22 PM   #17
M5Rlz
249
Drives: R8, f10m59(Rip), m4, GTR
revive. How do you change the O ring?
      04-07-2013, 01:59 AM   #18
BillionPa
BillionPa's Avatar
Drives: 335i
cut the old one off with a razor blade, put the new one in its place.
additionally, you will notice there is actually a vent hole in the cap (you can see in the pics above) and oil residue will leak out of that hole, so the o-ring is not always the solution.
My current recommendation is to drain the fluid and replace the entire reservoir every 30000 miles, as it has an integral filter, and you get a new o-ring at the same time.
