Clutch Pedal Help!
07-27-2012, 10:38 AM | #1 |
19
Rep 511
Clutch Pedal Help!
When I drive my friends 335i the clutch pedal feels a lot stiffer and engages closer to the clutch stop whereas my 335xi pedal feels mushy throughout and engages the clutch much higher. I can shift without grinding gears pressing about half way even with a thicker clutch stop.
Is this a pressure plate issue or an easy adjustable clutch pedal issue or another I vs XI nuance? We both have removed CDVs and clutch stops, but he removed all the clutch pedal springs - that shouldn't make THAT much of a difference, right? Especially for the engagement range. I have no slipping of the clutch either. Any insight please!
2008 E92 335xi | Cobb AP Stage2+ | AR DP | ETS FMIC | ALUFELGEN SF-71 DC Blk | HANKOOK V12 | UUC SSK | H&R Coilovers | AE Exhaust |
Are YOU Ready to Buy/Sell/Rent Property In The DMV? LET ME HELP YOU! |
07-27-2012, 11:24 AM | #3 |
19
Rep 511
Yes b/c I want input from all people not just XI guys.
07-27-2012, 11:39 AM | #4 |
The bigger they are...
18
Rep 264
The clutch spring makes a HUGE difference!!!
Tom Williams BMW Service Advisor
'07 335i Sport 219M Wheels, MMW CF Lip, Shadowline Taillights, Vishnu Procede, BMS DCI, BMS OCC, Aasco LW Flywheel, South Bend Clutch, Turner 90mm Studs, Stoptech pads rotors and lines, BMS LED Tag Lights, BMS Clutch Stop, BMS Clutch Non-Delay Valve, ACS Style Rear Glass Spoiler |
07-27-2012, 11:43 AM | #5 |
19
Rep 511
can you clarify please? Are you talking about the clutch springs in the pedal?
07-27-2012, 01:02 PM | #6 |
18
Rep 264
http://www.m3post.com/forums/showthread.php?t=195777
Go there, it will explain everything you need to know.
07-27-2012, 01:42 PM | #8 | |
19
Rep 511
07-27-2012, 01:43 PM | #9 |
19
Rep 511
lol +1 he responded to this issue i posted in the XI thread in case it was XI related, but wanted everyone's input here - don't know what the big deal is
07-28-2012, 11:15 AM | #10 |
Rep 50
The "big deal" is I told you what your issue is. Just as I would have told any customer that came into the shop with the same complaint.
But you can sit here and wait for the rest of the internet yahoos to give you advice like "it's your pedal spring". I don't really care. |
07-30-2012, 12:24 AM | #11 | |
19
Rep 511
yeah, clearly the guy who said "it's your pedal spring read this thread" doesn't read my post in its entirety, but you are no better by thread jacking my thread with useless banter. Do you have an issue with people doubting your knowledge?
07-30-2012, 12:25 AM | #12 |
19
Rep 511
bump - for real input
