F30POST
F30POST
BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > Wheels and Tires -- Sponsored by The Tire Rack > 19x10 rear thoughts?
ARMA SPEED
      07-19-2012, 03:28 PM   #1
kokopuffs405
Yup
kokopuffs405's Avatar
104
Drives: BMW?
2014 BMW M5  [0.00]
What are your guys thoughts on a 19x10 rear + 25 tires : 265/35/19
Lowered on h&r
Will it fit?
Oh hello
      07-19-2012, 03:41 PM   #2
martinf79
martinf79's Avatar
191
Drives: 2020 G05 X5 M50i
Lowered on h&r
Will it fit?
Personally - I wouldn't go w/ a rim fatter than 9"- 9.5" max. Even w/ that offset, you might be sticking out well past the fender. 265 tires should be fine (I've seen 275 and still looked fairly flush w/ the fender). All depends on the rim + offset. Go w/ a 9.5" +33 offset and you'll be a lot better off (weigh less).
It all depends on personal prefernce, but I wouldn't do it (might end up w a bad result). See diagnostic below:
http://www.rimsntires.com/specs.jsp?item=Wheel-Tire size comparer&sw1=255&ar1=35&bd1=19&rw1=8.5&et1=47&sw2= 265&ar2=35&bd2=19&rw2=10.0&et2=25&text1=&text2=
2020 X5 M50i | 2015 X3 28i xLine | Retired 2013 335i M Sport
trA.MM16.50
      07-19-2012, 05:56 PM   #3
onehungevo
64
Drives:
If the offset is 25 it won't fit.
      07-19-2012, 06:30 PM   #4
kokopuffs405
Yup
104
Drives: BMW?
2014 BMW M5  [0.00]
I ran these rims on my e92 335 XI coupe, but I had to roll the fender, and it still rubbed alittle , only on one side though
Oh hello
      11-26-2012, 09:06 PM   #5
mikew2069
mikew2069's Avatar
413
Drives: F30 335i MSport
I ordered 19x10 for the rear and now debating b/t 265/35 or 285/30 for the rear tires. Anyonyone have a pic of a 19x10 wheel on 265/35 rubber?
      11-26-2012, 09:17 PM   #6
ScarecrowBoat
Zooombie attaaack!!
ScarecrowBoat's Avatar
Drives: 328
I'm on 9.5" with 275 and get rubbing with a full car when the suspense travels a lot. Usually just when backing out of steep driveway or whatever, never while driving. I also can't imagine the tires sticking out anymore. On H&R and a 10", you are going to rub like craycray with 285.
      11-27-2012, 06:32 AM   #7
mikew2069
mikew2069's Avatar
413
Dang, do you know your offset in the rear? Pics of your setup?
      11-27-2012, 06:47 AM   #8
jsedlak
jsedlak's Avatar
13
Drives: F30 335i 6spd
I wish it would work... I'm trying to figure out how I can get a 19x10 to work without lowering springs.
      11-27-2012, 08:00 AM   #9
F555
F555's Avatar
Indonesia
37
Drives: F30 - 335i
it will work if u run higher offset like +45 above.
      11-27-2012, 09:03 AM   #10
Jamesons Viggen
Drives: '98 M Roadster stg 2+ S/C
I ordered 19x10 Forgestars last night. They confirmed with 265's it will not rub with H&R Sports. They have other customers with the setup and it's perfect. I was going to do 275/30's, but this is the safe bet. Remember, some of you are spending $$$ to get light wheels, tires seem to pick up a lb of unsprung weight by going up a size or two.
'98 Dinan/RMS stage 2+(VAC cams, CES Cutring etc)
'15 Buick Regal "T"(wife)
'06 Saab 9-5 Combi 5mt (full suspension, LSD, clipped turbo etc)
      11-27-2012, 09:06 AM   #11
SamS
Drives: Tesla M3 Perf + '18 X3 M40i
What offset are you using for those rear 19x10s?
      11-27-2012, 09:25 AM   #12
Jamesons Viggen
I forgot the number. It's aggressive, I think we are matching the stance of this car pictured:
      11-27-2012, 09:57 AM   #13
jsedlak
jsedlak's Avatar
13
CF10s in Titanium :droooooool:
19x9, 19x10...
I think I may have to do that next summer...
      11-27-2012, 10:13 AM   #14
ScarecrowBoat
Zooombie attaaack!!
Drives: 328
19x9.5 ET38 Rear with 275/35/R19
It might be better with 275/30 instead but I got the tires used from another member so there was no picking a size. Whenever I need new tires I'm going to go with 265's.
It looks fine on the car, but see what I mean? Can't imagine the rears sticking out any more than that.
      11-27-2012, 10:14 AM   #15
Jamesons Viggen
19x9, 19x10...
I went with Gunmetal F14's(as pictured), 19x8.5(19x9 pictured) in the front. Didn't want to add too much weight.
      11-27-2012, 10:32 AM   #16
mikew2069
mikew2069's Avatar
413
I paid a lot of attention to tire weight when shopping for tires. I'll be going with either Continental ExtremeContact DW or Michelin Super Sports. They are the lightest I could find. If I go with 285/30 in the rear, I'll have to get the Conti, 265/35 rear, I'll get Michelin.
When I ordered them, they said that Forgestar custom makes the wheel to your car's specs so that it sits flush. As long as it doesn't stick out, I'm fine with that. I would guess its 42-45 with the 10" in the back.
I think you're rubbing b/c the 275/35 is almost an inch taller than the 285/30 tire. That added height and depending on your wheel offset will cause the rubbing.
My main concern with the 265/35 on a 10 wide wheel is the 'stretch' look. I currently have 245/35 on a 8.5" wheel on my other car and it looks perfect. Not really stretched at all.
      11-27-2012, 10:34 AM   #17
SamS
I had 265/35 on a 10" wheel with my M3 ZCP. Looked perfect. But I wouldn't want to go any more stretched than that.
      11-27-2012, 10:38 AM   #18
Jamesons Viggen
I have 10.5" rears with 265's on my Roadster in my sig. Granted, I can fit 295's which I will do next time, but the 265's look fine.
      11-27-2012, 11:55 PM   #19
1clean335i
Perf BMW mag issue 147, 159
1clean335i's Avatar
Vietnam
414
Drives: Project Estoril
Im running a 275 tire on a 10" wheel. My offset is in the mid 30s and I only rub very very slightly going up/down parking garages. +25 offset would poke way too much in my opinion
'13 Estoril Blue 335i M-sport
*Don't PM me!* Message me here- http://www.facebook.com/ProjectEstoril
      11-28-2012, 03:26 AM   #20
s1k0ne
87
Drives: ..
scarecrowboat,
can you take a picture of the area where the tire meets the rim? a close up picture please. I'd like to see how much stretch there is.
Thank you
      11-28-2012, 03:28 AM   #21
s1k0ne
87
Drives: ..
Lowered on h&r
Will it fit?
I'd go 245/35/19 on those to make it fit. i had 245/35/19 on my previous x10.5 and it gives it a nice stretch. However, if you're going with that sort of stretch, I'd recommend you slam your car.
Previous rims:
LE37, 19x9.5, 225/35/19; 19x10.5, 245/35/19
      11-28-2012, 06:48 AM   #22
mikew2069
mikew2069's Avatar
413
Previous rims:
That's way too stretched for my taste. I think I'm going to have to order 265/35 to make sure it doesn't rub but I really want the 285 look. Decisions decisions. At least I have another two weeks for the wheels to get here so I can change my mind five more times .
f30post
