Splash -20F (31-34% Methanol) logs
07-18-2012, 05:33 PM | #1 |
Rainbow Racer
1008
Rep 2,540
The reason of the range in methanol content is because of various MSDS sheets I've seen on this brand/model.
Where to find: Target automotive section Price: $1.59/gallon At the moment, I'm going to say this is probably more useful to me than any 50/50 ratio mixture because: I'm only running a peak of 17psi on my 18ohm board. This is more than fast enough for me, even after 5 months of various mods. This $1.59 windshield washer fluid does the trick without needing to spend anymore $$, anything above with my current setup is an overkill and really no difference in acceleration feel. Mods: DCI, CM methanol injection, 40%/60% E85/93 octane blend, JB4 map 3. My system had issue's getting 100% flow, but as long as it's above 50%, it'll hit the timing curve with no drops. Timing curve starts at 10.5 and advances up to 13.5 peak @ 6,450rpm. I even seem to think having that high of an E85 ratio is an overkill, but I wanted to be safe considering I lowered my Methanol content. car is happy, and again, it's only $1.59
-Loe P.-
Prior Car:'14 Audi S5 3.0t DSG [ APR ECU/TCU | Pullies + basic bolt-on mods | 10.861@127.90mph ] Current Car: F82 M4cs | TT-RS | On Order: i4 M50 |
07-18-2012, 06:08 PM | #3 |
3441
Rep 79,211
07-18-2012, 06:12 PM | #4 |
307
Rep 5,175
When you inject water/methanol, the amount of water that goes into your engine is key on this motor. Anything over about 350 ml/min seems to cause quench on this motor.
654 RWHP ... ! Vishnu/FFTEC Single Turbo 335
07-18-2012, 06:14 PM | #5 |
Rainbow Racer
1008
Rep 2,540
IIRC CM10 nozzles are rated at 800cc/min @ 150psi. My pump is set at about 200psi
-Loe P.-
07-18-2012, 06:17 PM | #6 |
Rainbow Racer
1008
Rep 2,540
Should I be reconsidering using this considering my logs look healthy and the car feels just as strong?
-Loe P.-
07-18-2012, 06:29 PM | #7 | |
184
Rep 2,841
I went to larger nozzles and reduced my meth percentage to 40% meth 60% water. My timing curves looked fantastic! But the car seemed to bog at lower rpms in high load gears like 3rd and 4th. I upped the meth percentage back up to 80% and the car feels a bit more powerful, but my timing dropped about one degree up top. I suspect that too much water will give you nice looking timing curves due to the combustion chamber cooling - but it may also reduce power. So you can't rely on how your timing curve looks to indicate power levels. You would have to verify and fine tune on a dyno. I think Formerboosted is right about quench. There seems to be a fine line there. Too much water seems to rob you of power since it's effectively replacing fuel that would otherwise be making power. |
07-18-2012, 06:34 PM | #8 | |
184
Rep 2,841
Seems to be in the ballpark. Would be nice if there was some math behind it. Howerton doesn't recommend running more than 15% of your total fuel with a 50/50 mix. Problem is that no one seems to know what the stock injectors flow at, so it's difficult to calculate how much 15% of that would be. |
07-18-2012, 07:19 PM | #10 |
1737
Rep 17,960
Drives: A Lot
Garage List 2018 Ducati Panigal ... [0.00]
2016 Mazda CX5 [0.00] 2017 Aprilia Tuono ... [0.00] 2019 BMW M2 Competi ... [0.00] 2015 BMW M5 Competi ... [10.00] 2016 Ducati XDiavel S [0.00] 2016 AMG GT S [0.00] 2011 Ferrari 458 It ... [0.00] 2017 Charger Hellcat [0.00] 2015 KTM Super Duke ... [0.00] 2016 KTM RC390 [0.00] |
If you inject too much water, your logs will look great. But you will be down on power.
+1 regarding the need for dyno tuning |
07-18-2012, 07:20 PM | #11 | |
307
Rep 5,175
07-18-2012, 11:04 PM | #12 |
Rainbow Racer
1008
Rep 2,540
I guess the question is, how much power can this really rob if i'm only capable of running 17psi using an E85/93 octane mix with a 31% methanol ratio?
Is the extra octane above what an E85/93octane mixture already provides at that boost level necessary? or is it an overkill? Would lowering IAT's using a higher water concentration a better way to go to keep the timing happy. Keep mine mind that I'm strictly talking about 17psi between 4,700-5,200rpm tapering to 14psi above 6,500rpm I guess those questions will be answered on a dyno like everyone has suggested.
-Loe P.-
07-18-2012, 11:08 PM | #13 | |
184
Rep 2,841
But what really sucks is the lag/bog at lower rpms if you quench with too much water. |
07-18-2012, 11:26 PM | #14 | |
Rainbow Racer
1008
Rep 2,540
Just trying to pinch some penny's
-Loe P.-
