07-12-2012, 03:21 PM | #2 |
72
Rep 941
I'd look at the pics in onehungevo's thread. In comparison, your wheels will sit 3mm further out (3mm lower offset), you'll have a 1/2" wider wheel, and the overall wheel/tire diameter will be larger (onehungevo is running tires with a lower aspect ratio than spec). His car is lowered though, but I still don't like your chances.
07-13-2012, 02:11 AM | #4 |
Rep 76
From what I've read, you will need a 40et to a 45et for the rear in that size of wheel. I've used elementwheels.com search function for the F30 and it gives the et and fit required for a 9 and 10 rim.
2013 AW 328i: Sport Line, Sport Trans, Moon roof, Navigation, HK Stereo with Sat Radio, Xenons and 351m wheels
10-30-2012, 06:20 PM | #6 |
87
Rep 497
anybody try this yet? sorry if i'm bringing it back from the dead
I'm thinking that a 245/35/19, 265/30/19 will make this work. drop it low and make the natural camber settle it in. I saw a few that went x10.5+45, x10+40, but haven't seen a x10+35 yet. |
10-30-2012, 06:36 PM | #7 |
Perf BMW mag issue 147, 159
414
Rep 6,803
That's the same sizes I had on my F30. The rear will poke out a bit. Probably more than most people would like. With a 285 and my drop, it did not rub though. Take a look at my thread in the gallery section with the K3 Projekt wheels.
'13 Estoril Blue 335i M-sport
*Don't PM me!* Message me here- http://www.facebook.com/ProjectEstoril |
10-30-2012, 11:20 PM | #8 | |
11
Rep 251
10-31-2012, 07:12 AM | #9 |
414
Rep 6,803
Oops. I thought it said 10.5. Well if my 10.5's worked, im sure the 10's will work also
10-31-2012, 11:59 AM | #10 |
11
Rep 251
There you go op. Looks like it would work. Also, the cars in the European car magazine with the HREs have 20x11+42 and 20x11+44 which are slightly more aggressive.
