Where's the oil catch can data?
07-05-2012, 01:38 AM | #1 |
28
Rep 488
Drives: 2008 335xi E90
I've been searching for data that shows oil catch cans actually improve performance. Can anybody lead me to real data - Dyno pulls, data logging, etc? I am still unconvinced that OCCs do anything. Thanks.
07-05-2012, 01:39 AM | #2 |
161
Rep 7,377
OCC wont improve performance. they will do what they are named for , catch oil .
07-05-2012, 01:53 AM | #3 |
28
Rep 488
Understood. So catching oil is somehow a good thing. I've read that OCCs prevent the valves from clogging and can prevent oil from coating the inside of the intercooler, among other things. I believe the first is a long term maintenance issue which, I suspect, could be cured every 40K miles with walnut blasting or sea foam. I'm still under 30K and haven't had any major problems. The second could be a performance issue, for example higher IATs with no OCC because of oil coating the IC. If so, how much oil does it take to reduce the cooling efficiency of an IC, and how much time/miles does this correspond to?
07-05-2012, 06:35 AM | #4 |
29
Rep 1,551
Seems like you've made up your mind already. Some prefer to spend the cash on a catch can for preventitive measures. I just like to keep that gunk out of my rear turbo and charge pipes.
07-05-2012, 08:18 AM | #5 | |
79
Rep 2,396
Drives: '08 E90 335i
I have one, it's def working b/c in the intake hoses has oil in it, the output hose does not & there is oil in the can. |
07-05-2012, 09:40 PM | #6 | |
28
Rep 488
07-06-2012, 10:20 AM | #7 | |
12
Rep 248
07-06-2012, 10:23 AM | #8 |
79
Rep 2,396
Wats your point?? An OCC won't add any performance, but if installed correctly & the OCC does not distort airflow/crankcase pressure, the OCC will not hinder performance. So yes, if it's actually catching oil it can prevent performance degradation.
07-06-2012, 10:41 AM | #9 | |
Joint Chiefs of Staff
4920
Rep 115,999
Mike |
07-06-2012, 10:44 AM | #10 |
79
Rep 2,396
Thanks Mike -- I figured after spending $850 on my Helix, I could afford to spend another $175 to protect it with the BMS OCC. Especially since oil blowthrough is a known "headache" with the N54, it's not a bad preventitive measure to take.
