Warped Rotors 16000 KM?
06-29-2012, 10:20 AM | #1 |
Rep 54
Hey, i was wondering if anyone has experienced anything like this? I have a 2011 328i XDrive as stated above it only has 16000 KM and the rear rotors are warped? This seems really premature i called the dealer and they said that it's most likely not covered because thats too many KM? seriously this does not make any sense for a car of this caliber? Please anyone that might have expierenced this i live in Canada so keep that in mind when thinking warrenties!
06-29-2012, 10:26 AM | #2 | |
Rep 25
06-29-2012, 10:29 AM | #3 |
17
Rep 276
Well, a warped rotor is hardly a mechanical failure. It is most commonly caused by external factors, such as extreme heat (too much hard breaking), rotor got wet when hot or hit by something.
It could also be caused by faulty brake pads, but I guess you would notice if a break pad is not working well. |
06-29-2012, 10:34 AM | #4 |
Rep 54
06-29-2012, 11:20 AM | #6 |
9
Rep 60
Warped rotors can also be caused by the driver. If u have to panic stop real hard from high speed ( get them red hot ) and u hold u foot on the brake pedal while stopped, this can and will warp the rotors.
At the very least this will deposit material on the contact spot on the rotors which may feel like warped rotors. |
06-29-2012, 11:35 AM | #7 | |
Rep 54
06-29-2012, 12:16 PM | #9 |
Zeed
17
Rep 561
If your car is under warranty and based on model year and mileage of your car it is I would take to the dealer and request to have the problem checked and if in fact the rotors are warped have them replaced under warranty. That's what 4 years 80 000 km free maintenance plane is for. And if they give you grief, just call BMW Canada.
07-03-2012, 07:03 AM | #10 |
Rep 54
As far as i have read tho free maintenance is not on parts that ware, do you guys have any info om this at all? it's at the dealer now getting it's first maintenance.
07-03-2012, 05:04 PM | #11 |
Gateropode
329
Rep 2,848
Warped rotors are rarely warped. Most commonly, deposit of pad material is provoking pulsating brakes, not actual rotor warp, and a resurfacing is enough to fix the issue.
