front M3 wishbones without M3 tension struts?
06-26-2012, 04:25 PM | #1 |
Diamond Geezer
212
Rep 2,385
Drives: Jet Black 2007 328i Saloon
from everything I've read here, the M3 wishbone (control arms) are what provides increased (more negative) camber.
also, from this forum, at least some folks believe the M3 tension struts are basically identical to non-M3, except for the bushing. Is anyone running the M3 wishbones without the M3 tension struts? Are you doing okay with it? There is one post where someone says they experienced problems. I already have new tension struts (Meyle HD) with stronger bushings and I'm considering my options for adding negative camber. Seems like the easiest solution from an install / labor side of things is M3 wishbones. Not sure if I would go that route if I have to spend $$$ to replace tension struts as well. Thanks in advance for any feedback |
06-26-2012, 04:39 PM | #2 |
1821
Rep 5,337
I am surprised at the amount of interest something like a very small increase in negative camber is gathering here for a crowd that will likely NEVER sniff the hot side of the track. It's almost like a weird obsession that, if it's equipped on an M3, it MUST be better...
I'm also shocked at the amount of concern about "understeer" on a car, again, NEVER going to sniff the hot side of the track. Weird.
Sitting on a beat-up office chair in front of a 5 year old computer in a basement floor, sipping on stale coffee watching a bunch of meaningless numbers scrolling aimlessly on a dimly lit 19” monitor.
06-26-2012, 05:33 PM | #3 | |
34
Rep 1,381
lol
06-26-2012, 05:44 PM | #4 | |
34
Rep 1,381
if you want more negative camber there are several ways. ! camber plates
take the pins out ! lower you car ! make the holes more oval on the frame. M3 wishbones will not give you that much negative camber. Replacing the tension struts and wishbones is pretty easy and can be done with simple tools. Quote:
06-26-2012, 08:07 PM | #5 |
Diamond Geezer
212
Rep 2,385
I agree to some degree with the responses however my question is focused on compatibility. Do the M3 wishbones work with non-M tension struts (or not?). Is anyone running such a setup and would they recommend it?
06-26-2012, 09:40 PM | #6 |
38
Rep 864
Drives: '08 E92 335i
The main upgrade of these parts are the bushings contained within... the minor amount of negative camber you gain is just a bonus.
06-26-2012, 09:41 PM | #7 | |
146
Rep 1,160
What you'll have are delrin on one lightweight, very stiff arm; rubber on another, heavy iron arm if you're going half stock. Hey.... Camber adjustment's to be had w/quality plates. |
06-26-2012, 09:50 PM | #8 |
Diamond Geezer
212
Rep 2,385
thanks. mostly concerned about how they might work together. Would rather not go M3 wishbone if they won't work with my new Meyle tension struts. On the other hand, if they were compatible, think the payup for M3 part is small compared to new non-M wishbone.
06-26-2012, 10:13 PM | #9 |
26
Rep 454
It will work, anything can work. It will be different with no harm. If your changing the arms I would go ahead and spend the little extra on them.
Where in Florida are you from? |
06-26-2012, 10:22 PM | #10 | |
Diamond Geezer
212
Rep 2,385
06-26-2012, 10:29 PM | #11 |
164
Rep 2,556
Well, it's been a while since I've seen The Hack berate someone for asking about a suspension mod for a car that may never see the 'hot side of the track.' Good to know e90post hasn't lost it's flavor. The bottom line (for me and many others that may never see the hot side of a track) is an additional -.07d of front camber really improves turn in on the STREET especially for those of us who ditched the rft's and lost some of that turn in response..
mlifxs: fwiw, you can get about the same amount of neg camber by pulling the alignment pins from the strut mounts and realigning. Maybe ask Harold at HPA about compatibility of your oe tension links w/the M3 wishbone link? Of course, he's a vendor so I'm pretty sure the answer will be yes.
2007 E90 335i, TiAg, 6AT, ZPP, ZSP, ZCW, 6FL, HD
Quaife lsd, ETS fmic, GIAC s/w, Dinan intake/exhaust/oc, Koni/M3 susp, Apex Arc 8, Mich PSS |
06-26-2012, 11:19 PM | #12 |
Rep 182
I won't be tracking my car much, if at all, but I sure put it through some work on the back country roads and generally just enjoy the feel of the improved suspension.
2009 E90 335i - All go, no show
Mr. 5 Intake, VRSF FMIC, Quaife LSD, BMW PS, M3 Bits, RE Toes, ER CP, Forge DV, JB4, PSS |
06-27-2012, 02:10 AM | #13 | |
146
Rep 1,160
So, what've you got? And are bushings rubber or no? |
06-27-2012, 05:56 AM | #14 | |
Diamond Geezer
212
Rep 2,385
Seems like EVERYONE who's tried it likes the M3 setup. Wondering if I can get away with just the wishbones, thinking they'll be paired up with stronger than oem tension struts, but don't want to do the labor twice or pay for new M3 tension struts if the M3 wishbones are incompatible on their own. I've also explored the "pull the pin", as we've conversed on this in another one of my threads: http://www.e90post.com/forums/showthread.php?t=703484 So far, "pull the pin" has earned me a 0.2 degree improvement in camber. I'm a noob at this so perhaps I can get more out of it with some work or the tool I mention in that thread. Hopefully there are folks out there has tried the "M3 wishbones only" setup to say yay or nay. I'm not inclined to pursue it without positive feedback from those who've done it. |
06-27-2012, 08:44 AM | #15 | |
146
Rep 1,160
Front control arm R&R is a very easy job requiring no more than raising the vehicle on jack stands & wrenching, 2 bolts at the subframe and 2 nuts at the knuckles. Reality: Shop having a lift, 1 hr to do both wishbones & tension struts, but most'll charge about what BMW says is labor - they have expenses & employees to pay. Can easily DIY - I did.... Then, alignment needed. M3 arms are the can't-go-wrong solution, excellent performance, as you might expect. Highly recommended & you'll feel the love. Went from stock to Ground Control camber plates so don't know how pin pulling goes. Camber plates allow max adjust-ability; deliver big gains if you're looking for stock to -2.5° camber, DIY alignment very useful if you adjust. For a few hundred bucks, I'd ditch rubber bushings for M3 arms and save by DIY, assuming you know the technique. |
