Old Tischer Performance Shock Kit
06-26-2012, 12:16 PM | #1 |
Rep 16
I just dug out the old Tischer Performance Shock Kit I ordered over a year ago...The part number is #33500429574
I'm ready to install them now, but not too sure what springs to pair them up with. I have a 2008 328i non-sport E90 sedan with manual transmission. Has anyone paired these shocks up with non-oem springs (Eibach, H&R, etc)? If I wanted to go 100% OEM, I keep seeing references to D4, D5, D6 springs? Which springs are for which car? Thanks guys! |
06-26-2012, 11:56 PM | #3 |
84
Rep 777
get either a set of sport springs from a car similar to yours that has the ZSP option (to have the Dx you need), or go aftermarket (I wouldn't recommend eibachs), or if you can source a set of BMW perf springs from the v2 kit you will be amazed - that was I have and feel it's a really great match.
328i Sports Pkg, Michelin PSS on Staggered 18" OZ Ultraleggeras
. BMS Powerbox. Cyba scoops + Rev motoring intake hose + charcoal delete. Wavetrac LSD . M3: subframe bushings + sways + control arms (fr & rr). Meyle rear toe arms. M3 diff fr bushings . BMW Perf: v2 springs + v1 dampers. Valeo SMFW+clutch. 034 MotorSport engine mounts . Short Shifter + Turner PU bearing + ZHP M weighted shift knob. CDV delete |
06-27-2012, 08:11 AM | #4 |
208
Rep 3,175
If you want to keep it OEM, stick with ZSP springs, otherwise EPK springs (which have a similar spring rate to the ZSP springs albeit slighty stiffer) are the recommended springs with these shocks. I paired mine with EPK springs because I wanted a lower stance.
06-28-2012, 02:43 PM | #7 |
321
Rep 721
Drives: 2018 530e
I'm pretty sure the PS struts come with shorter bumpstops.
2018 BMW 530e Alpine White | Black Napa Leather | Bone Stock
06-29-2012, 12:18 AM | #8 |
151
Rep 2,638
06-30-2012, 08:18 AM | #9 |
289
Rep 864
Same Kit Here
On ZSP -- have installed the rears and still debating on diy installation on the fronts.
. Car has 70k miles --- so far the new rear struts really firmed up the ride but a little bouncy over bridges / expansion hwy joints. . . Kit has all the bstops / sleeves and fasteners needed to do the job right. |
06-30-2012, 11:27 AM | #10 |
164
Rep 2,556
THIS^
2007 E90 335i, TiAg, 6AT, ZPP, ZSP, ZCW, 6FL, HD
Quaife lsd, ETS fmic, GIAC s/w, Dinan intake/exhaust/oc, Koni/M3 susp, Apex Arc 8, Mich PSS |
06-30-2012, 11:29 AM | #11 |
164
Rep 2,556
Nope. OP has the 'old' V1 kit that came with taller, firmer bumpstops designed to be used with oe sport springs.
06-30-2012, 06:33 PM | #12 |
321
Rep 721
Drives: 2018 530e
Ok, thanks for the correction, I was under the impression the bumpstops were shorter even on the old V1 kit.
07-01-2012, 05:56 AM | #13 |
Diamond Geezer
212
Rep 2,385
Drives: Jet Black 2007 328i Saloon
07-03-2012, 11:32 AM | #14 | |
Rep 89
At 65k the car is getting sloppy on original shock/struts.
-Jonathan '07 335i E90 blue/brown/stock/stick/sport/stuff |
07-04-2012, 02:59 PM | #15 | |
Diamond Geezer
212
Rep 2,385
I'd say more than slightly firmer, maybe "definitely firmer" though very tolerable for daily driving. I think you will like the change with the V1 kit, especially if you're sport shocks are worn. |
07-05-2012, 09:37 AM | #16 | |
Rep 89
I had 'newer' Bilstein Sports on my previous 95 M3 and loved and lived with the firm ride.
07-12-2012, 10:16 PM | #17 |
10
Rep 76
just my 2 cents..not bashing the BMW Performance shocks...I actually had them on my E90 with H&R Sport springs......I would use them only with the factory OE springs wether sport or non sport springs its a good upgrade.
The rebound is extremely unpleasant. Save and buy the Koni's since Bilstein no longer sells the SPORT shock, but can be aquird by special order only. I have a set its was on my car for 1 week.....im giving it away, I would be ashamed to sell it to someone...let me know if anyone wants its, Im in Fairfax VA. |
07-13-2012, 12:40 AM | #18 | |
84
Rep 777
07-21-2012, 05:00 PM | #19 |
93
Rep 651
I'm about to get pro kit with my old performance dampers. I think it's a little too bouncy especially with 3 others. And I would like to lower it to about 1 index finger width height.
