Do I need a spring compressor for install?
06-26-2012, 02:47 AM | #1 |
30
Rep 318
A buddy and I are going to install coilovers this weekend on our cars. He has a 335i and going to put on some pss9 coils and I got a 328i and going to put Sonic Tuning S3 coilovers. So my question is do we need to get a spring compressor to remove the stock ones out???? Thanks for the help!
06-26-2012, 05:59 AM | #2 | |
146
Rep 1,160
Figured out how to spread the pinch clamp? |
06-26-2012, 11:11 AM | #4 |
163
Rep 2,979
Drives: 07 SBM E92 335i 6MT
Yeah and make sure you have an impact. Takes a lot of time off the install. Especially when decompressing/compressing the compressor when the assembly is off the car.
In the process of restoring an 07 335i
06-26-2012, 12:39 PM | #5 |
81
Rep 6,092
if you swap out the entire coilover system itself, you wont need to compress the stock springs in the front. (unless you want to separate the spring from the shock)
the rears, you dont need a compressor for anything.
06-26-2012, 12:53 PM | #6 |
290
Rep 28,154
he still needs the oem bearing plates, unless his coilover system comes with it, which is unlikely
06-26-2012, 12:53 PM | #7 | |
30
Rep 318
06-26-2012, 12:56 PM | #8 |
163
Rep 2,979
You'll have to compress the fronts to get them out? Is there something I don't know? And putting the assembly in? I guess the race springs are pretty damn short so maybe it would come out without a compressor. Either way, renting a compressor is free...
06-26-2012, 12:56 PM | #9 |
290
Rep 28,154
oh and you will need spring compressors just to get the strut out from under the fender unless you are going to unbolt the control arms and tension arms and pull out everything as an assembly
06-26-2012, 01:00 PM | #10 |
163
Rep 2,979
I did H&R sports and they are quite a bit shorter than OEM sports. There is no way I could have gotten them to clear the fenders without compressing them...or vice versa. The race are what.... .5 shorter? I still think you'll need to compress to get them out.
06-26-2012, 05:09 PM | #11 |
30
Rep 318
I called LTBMW and asked them, they said I would need it since I have regular suspension. My friend might be able to get away with not using it since he is on sports suspension. So I'm just going to rent one and be safe.
06-26-2012, 07:40 PM | #12 |
163
Rep 2,979
I would still like to know how you could get the front assembly out without taking the whole thing out or using a compressor?
06-26-2012, 09:49 PM | #13 | |
146
Rep 1,160
Considering there's a preload on stock springs, you gotta be STRONG to get 'em out w/o compressors! Last edited by CALWATERBOY; 06-27-2012 at 07:50 PM.. |
06-27-2012, 09:40 AM | #14 |
232
Rep 642
Drives: 2010 E92 335i
06-27-2012, 04:29 PM | #15 |
81
Rep 6,092
hmmm... its been awhile (but not that long) since I swapped my suspension... I don't remember compressing the fronts before pulling out under the fender. I thought I compressed the springs after I pulled it out. shit my bad if you have to compress before.
