F30POST
F30POST
BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > Wheels and Tires -- Sponsored by The Tire Rack > TPMS reset problem, need some advice
proTUNING Freaks
      06-24-2012, 06:32 PM   #1
FotiosF90M5
///M Specialist South Shore BMW
FotiosF90M5's Avatar
Drives: 2021 M5 Comp BHG/Silverstone
Exclamation TPMS reset problem, need some advice
I bought a set of oem 356 from a 5 series member and the tpms are the same year and mhz. Im doing it right and it wont reset. Sometimes it will say it reset than the warning will come on. When I start the car again and drive off its fine for about half a mile then the warning comes up saying malfunction. After a few seconds it goes away and it says tpms active and the tires light up green on the idrive. Even if I check the system check it says everything is fine and working. It will do this cycle everytime now. It says its messed up then it goes away leaving not a trace. If they werent compatible wouldnt the light remain on? I love these wheels but the message is annoying. any help or insight would be greatly appreciated.
2021 M5 COMPETITION LCI Brands Hatch Gray on SIlverstone, carbon roof, comp wheels, Mperf splitter, carbon pro spoiler, carbon diffuser , carbon paddles, executive pkg. Dinan HAS, RaceChip, dinan spacers, FC stud kit, etc
      06-24-2012, 10:30 PM   #2
FotiosF90M5
Now it comes on right at startup then disappears even without clicking "ok" exit button. It says malfunction right at startup every time now. I'm just wondering if it really is messed up whether it would stay on or not. Any experience from anyone ? Thanks
      06-26-2012, 12:20 PM   #3
200Duece
200Duece's Avatar
45
Drives: '73 2002,'18 X5 35d,'17 328d T
Run it by the dealer. If your whole setup is oem they will find out what's goin on
1988 E28 535is Euro Conversion --- sold
2009 E90 335 6MT --- sold
2003 E39 540iT Msport --- sold
      06-28-2012, 08:03 PM   #4
Mean_M3
32
Drives: 2009 E92 coupe
Your sensors and fine and working properly, its just your idrive, You have to reset your idrive, it happened with me once when I put on a new set of wheels (however it didnt happen every time i put on a new set of wheels). For these wheels, everytime it would say TPM malfunction at start up and then go away without me doing anything, I reset the idrive and it worked fine after that. (you dont even have to go to the dealer, you can find info on the forum and can do it yourself, I did it myself). I dont know about the F30 but worst case you can take it to the dealer. As long as the wheels are green they are working properly and the right ones for your car.
      06-30-2012, 04:01 PM   #5
bavarianx
bavarianx's Avatar
Drives: 2006 X5 4.4i
Your using the wrong TPMS if its out of a 5er. The F30 uses a new part number for TPMS #36106798872. Same Frequency but not compatible with older versions.
      06-30-2012, 10:31 PM   #6
FotiosF90M5
Goddamnit!!
      06-30-2012, 10:33 PM   #7
FotiosF90M5
Thanks guys. I think the wheel is too big looking for an f30 anyway so oem 356's up for sale. Just my f@#ken luck.
      06-30-2012, 10:35 PM   #8
FotiosF90M5
I'm confused why it goes away and the I drive says all is good. All green wheels. Seems the only explanation. Don't know how to reset the I drive so off they go.
f30post
