F30POST
F30POST
BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > N55 Turbo Engine / Drivetrain / Exhaust Modifications > Hartge N55 F30 335i Engine Software Tune Yields +56HP / +59TQ for F30, F10, F25
GetBMWParts
      06-24-2012, 12:41 PM   #1
Balzz
96
Drives: F97 X3M
2019 M4  [0.00]
2021 X3M  [0.00]
Cool Hartge N55 F30 335i Engine Software Tune Yields +56HP / +59TQ for F30, F10, F25
BIMMERPOST
     Featured on BIMMERPOST.com
Hartge Engine Performance Upgrade - F30 335i F10 535i F25 X3 35i (N55 Engine)
HP gain = 56 hp
Trq gain = 59 ft-lbs
The Hartge 'Engine Conversion' is a bespoke tuning module that plugs in ahead of the engine computer on the wiring harness. It has factory-style plugs to connect in-line with the water temp sensor, fuel rail pressure, turbo boost pressure sensors, turbo wastegate valve, intake camshaft sensor, 12V power and ground. The module then sends a modified signal to the engine computer allowing it to increase boost by varying amounts depending on load, engine speed, and other factors.
All of the factory safeguards remain in place, including overload protection, warm-up protocols, and the engine tuning is unchanged below 70% throttle to preserve all factory driveability and emissions certification*. One of the key advantages of this type of 'piggyback' system is that it is unaffected by factory BMW updates and service. If BMW updates the computer software to fix any small bugs or issues, the Hartge performance upgrade is not lost or overwritten. This is key on a new model like the F30 because BMW is constantly releasing small software updates. All of the factory diagnostics and service access is retained.
This item fits the following BMWs:
2012+ F30 BMW 335i - Sedan
2011+ F10 BMw 535i 535i xDrive
2011+ F25 BMW X3 xDrive35i
VIA http://www.turnermotorsport.com/p-16...55-engine.aspx
Name:  Screen Shot 2012-06-28 at 7.21.01 AM.jpg
Name:  Screen Shot 2012-06-28 at 7.21.24 AM.jpg
Name:  Screen Shot 2012-06-28 at 7.21.14 AM.jpg
      06-26-2012, 03:24 PM   #2
m5 guy
m5 guy's Avatar
Drives: 2020 M5 Comp
Looks promising, I like all the safeguards they have built into it. Only time will tell though...
2020 F90 M5 Comp Oxford Green Metallic II-Aragon JOURNAL
2016 F10 M5 Space Gray-Black SOLD
2012 E70 X5M Monte Carlo Blue-Silverstone SOLD
2001 E46 M3 Oxford Green Metallic II-Cinnamon SOLD
      06-27-2012, 02:07 AM   #3
bmw_fanatic
7
Drives: f30 328
Check out the engine section on F10 5 series board..someone just posted review on it.
Expensive yes! But it's probably the only choice for now!
      06-27-2012, 07:36 AM   #4
Robin_NL
S0THPAW
Robin_NL's Avatar
8680
Drives: HS M2 Competition
This one? OP says below 3000rpm it just feels the same as stock. <3000rpm is exactly where I'm at when I'm driving normally....
http://f10.5post.com/forums/showthread.php?t=700487
Cheers
Robin
      06-27-2012, 09:42 AM   #5
Diver
Diver's Avatar
Drives: Black '12 135i - Sold
You might wait for the BMW PPK, rumored to be out by the end of this year. The PPK in my car gives more torque in the driving range from 1500 to 4500 RPM, no questions on the warranty and no problems.
      06-27-2012, 10:42 AM   #6
Alan l.
Alan l.'s Avatar
5341
Drives: 2020 F95 X5M Competition
^^ what is the expected HP increase with the PPK? In the past the gains are only up to 335is specs which is only 320hp.
Turner is willing to do $1500 for the Hartge tune when i emailed them. Still a lot of money for a piggyback system but looks like the only option at this point.
You can NOT compare JB to Hartge. Hartge is in a completely different league as a Bmw tuner in Europe
Alan
      06-27-2012, 01:19 PM   #7
bmw_fanatic
7
Drives: f30 328
Cheers
Robin
Yup, you found the threat.
My thinking is if you look at JB4 N55 stage 1 tuning, it is not getting much more tq out of the N55 so I suspect there is not much room to work with or wait until someone else with Flash to see if there is room to be extracted.
      06-28-2012, 02:08 PM   #8
OdomPHD
I break for no one
OdomPHD's Avatar
Drives: e9o "Vanity 2"
The guy that said it looked promising but only time will tell was spot on.
Originally Posted by southlight View Post
You're low-balling
      06-28-2012, 02:28 PM   #9
csween86
DSC OFF
csween86's Avatar
Drives: 2011 135i, N55, 6MT, MPK
For anyone interested, look into the Dinan stage 2 upgrade for the n55. It bumps power to 355hp and torque to 401 lb-ft.... There will eventually be a stage 3 as they mentioned that on their site. The stage two is like $2g's so a bit pricey, but they will match your warranty and BMW will acknowledge this tune and will still service your car hassle free.... Just saying.
      06-28-2012, 02:48 PM   #10
bmrm396
Drives: 2018 F80 M3cs
r they aware that their pricing will completely price them out of the market ... dunno who does their market research but they better get a grip on things
Formerly addicted to e46fanatics
Formerly addicted to e90post
      06-28-2012, 02:54 PM   #11
m balla
m balla
Slovakia
14
Drives: ///M
Aren't there cooling issues with the dinan? I can attest that the 335i m-sport with the ppk, pe is no where close to the power of the is even though they match up on paper. I would mos def do ic upgrade. I would just wait it out or do turbo upgrade.
      06-28-2012, 02:58 PM   #12
csween86
DSC OFF
csween86's Avatar
I agree. A bit overpriced but you get what you pay for with the hartge and dinan tunes, especially the ppk. Maybe they are a little pricey but they are worry and hassle free. Yeah you can easily get a better tune for cheaper, but in my experience cheap stuff is usually cheap for a reason, it doesn't last as long and stuff is constantly breaking. You don't go to Kmart to buy your awesome set of golf clubs...
      06-28-2012, 03:17 PM   #13
///M.Tonee
///M.Tonee's Avatar
Drives: Porsche 991.1 GT3
Does it still have the CEL issue?
Garage: 2015 991.1 GT3 | 2016 AMG GTS Sold | 2015 C7 Z06 Sold | 2015 M4 SO/6MT Sold
Instagram: M.Tonee
      06-28-2012, 03:50 PM   #14
Ash83
Ash83's Avatar
Drives: 135i & RS5 (SOLD)/ 18 CTS-V
for $1500 they are out side the game unless you are 10 years old and want it NOW.
Alpine White, Coral RED , Glacier Silver Aluminum trim, M sport, 6MT, NAV, HiFi, USB-iPod, Bluetooth
Performance: JB4|BMW PE|DP Cosmetics: BMW Sport Pedals|Black Kidney Grill
      06-28-2012, 03:55 PM   #15
Balzz
96
Drives: F97 X3M
2019 M4  [0.00]
2021 X3M  [0.00]
That's me!
Gimme the marshmallow now!
      06-28-2012, 05:11 PM   #16
Beemw335
62
Drives: 335i
Procede/ jb4 are better options.
Theyll be ready soon.
      06-28-2012, 05:57 PM   #17
pkimM3r
pkimM3r's Avatar
205
Drives: m3 saloon in granny mode.
is this true in fact? so if you lease a car and do this bmw will have no problems with it? im assuming if they are ok and it doesn't void warranty, it shouldn't even raise an issue with anything. if a motor blew because of this tune, you get a new motor for free no hassle? is this true?!!?
      06-28-2012, 05:59 PM   #18
pkimM3r
pkimM3r's Avatar
205
Originally Posted by Balzz View Post
That's me!
you must be an addict too huh? my name is phil and im an alcoholic/addict LOL
      06-28-2012, 07:15 PM   #19
e84
13
Drives: 328
Wondering if it will fit 135i n55?
      06-28-2012, 07:58 PM   #20
AJG1137
Member
AJG1137's Avatar
12
Drives: 2011 335i e93
Alan
How is jb4 not in the same league?
I would buy a burger tune any day over this, based on my experience with an n55 jb3.
Current: 2017 F36 430i GC
Retired: 2011 E93 335i; Retired: 2013 F10 528i
Retired: 2011 E90 335i; Retired: 2008 E90 328i
Retired: 2003 E39 530i; Retired: 1997 E36 328i
      06-28-2012, 08:37 PM   #21
jtuds
71
Drives: 335rwd Dinan S2
Alan
What impact do these piggyback tunes have on fuel efficiency and the different drive modes?
      06-28-2012, 09:13 PM   #22
AJG1137
Member
AJG1137's Avatar
12
Alan
In my experience, fuel economy is unchanged. Although, having the tune makes it much more tempting to be more aggressive with the throttle, which in turn will decrease fuel economy.
Tags
335i ecu, 335i software, bmw 335i tune, bmw n55, bmw n55 ecu software, bmw n55 engine, bmw n55 engine software, bmw n55 engine tune, bmw n55 engine tuning, bmw n55 piggyback software, bmw n55 piggyback tune, bmw n55 software, bmw n55 tune, bmw n55 tuning, f30 335i piggyback, f30 335i software, f30 335i tune, f30 335i tuning, hartge n55, hartge n55 engine, hartge n55 software, n55 ecu, n55 engine, n55 engine ecu, n55 engine tune, n55 hartge, n55 hartge ecu, n55 hartge tune, n55 piggyback tune, n55 software, n55 tune, n55 tuning
Search this Thread:
Advanced Search
f30post
