Shaking/limp mode
06-23-2012, 05:08 PM | #1 |
63
Rep 788
Just changed ALL my coils and plugs. Had misfires on 4,5 n 6 cylinders. I would get limp mode and some shaking if car was "cold".
Unfortunately it still does the same thing. When up to temp the car is fine. Plugs were dirty as hell. Also, the holes where plugs go into had a black residue around circumference. Either fuel or carbon??? I also get a bunch of lambda codes so I'm guessing it's the o2 sensors on bank 2 that cause misfires/limp. Btw I don't have any misfires on cold starts. Any feedback will be appreciated.
JB4 Trebila tuned cp-e IC AMS exhaust BMS DCI AR DP's METH RB TURBO
19" VMR VB3 Stoptech BBK TC KLINE VORSHLAG SPEC STG 3 OSS design |
06-23-2012, 05:55 PM | #3 |
161
Rep 7,377
+100.. Really dont get how people can treat their cars like shit and go WOT cold...
06-23-2012, 06:02 PM | #5 |
63
Rep 788
Well I didn't mean going WOT right away after starting off. Meant like 5-10 min after driving.
But while driving on a cold start (oil temp less than 210F) I get shakes/ hesitations.
06-23-2012, 06:32 PM | #6 |
371
Rep 2,838
Drives: e92 335i, e34 525i & e60 530i
Make sure your o2 sensors are in the correct dp if you have any. This cleared my lambda codes and shaking. Remember, gray wired one goes in the dp on the passenger side and the black wired one goes into the driver side dp. Good luck.
Here are the codes I had. 2C7F-Lambda probe after catalytic converter 2, trimming control 2C6A-Lambda probe after catalytic reversed 2C6C-Lambda probe after catalytic converter 2, system check
06-23-2012, 06:41 PM | #7 | |
63
Rep 788
