E85 studder's on startup
06-23-2012, 02:55 PM | #1 |
196
Rep 2,669
Running a 50/50 mix of E85 and 93, when the car is cold and you start it, run's rough and stutters, seems almost like a misfire, I have had a HPFP code pop up, forgot to write it down.
If I run pure 93 I have no issues. |
06-23-2012, 03:47 PM | #6 |
196
Rep 2,669
06-23-2012, 04:01 PM | #7 |
Rainbow Racer
1008
Rep 2,539
try a lower mixture like 35%.
-Loe P.-
Prior Car:'14 Audi S5 3.0t DSG [ APR ECU/TCU | Pullies + basic bolt-on mods | 10.861@127.90mph ] Current Car: F82 M4cs | TT-RS | On Order: i4 M50 |
06-23-2012, 04:57 PM | #8 |
161
Rep 7,377
Run 1/4 tank only. Thats enough for good octane .
06-23-2012, 05:09 PM | #10 |
Epic404
23
Rep 260
The rain has sucked here. I run 50/50 and had 3 fuel system codes pop at once during WOT recently but it hasn't happened again. My car runs good cold start and great at op temp, no real issues. Might be because I have fresh coils and spark plugs. I read that jb4 tunes dont activate until the car reaches 160 degrees. I'm not sure if this includes commands that mediate the differences in using E85 vs unleaded?
06-23-2012, 05:29 PM | #11 |
196
Rep 2,669
06-23-2012, 05:41 PM | #13 |
196
Rep 2,669
06-23-2012, 06:07 PM | #15 |
Rainbow Racer
1008
Rep 2,539
wow Tornado warnings down south? Yikes!
It was dry this morning until noon, i was able to get some E85 runs. Tropical depression Debbie
-Loe P.-
06-23-2012, 06:08 PM | #16 |
Rainbow Racer
1008
Rep 2,539
me either, my logs tells me my car is just as happy with a lower ratio vs. a 50/50 ratio.
-Loe P.-
06-23-2012, 06:31 PM | #17 | |
915
Rep 3,456
Drives: Harrop E90 M3
06-23-2012, 07:06 PM | #19 |
Rainbow Racer
1008
Rep 2,539
JB4 activates at 160F oil temp
-Loe P.-
06-23-2012, 10:28 PM | #20 |
125
Rep 1,546
My car on a 35% mix of E85, it doesnt FIRE right up as when on pure 93 octane.. I have tested this and seen it for myself.
But this is the nature of E85..E85 is known to give a little extra delay in starting, hence on many other platforms they have a increase in cranking time. If the car is running good on WOT and datalogs well i wouldnt worry about it. |
06-24-2012, 01:04 AM | #21 |
79
Rep 2,396
Drives: '08 E90 335i
Try something less aggressive, a 50:50 mix of 93 + E85 balances out to 99 octane. Run a 2:1 mix of 93 + E85 will have you at 97 which might be a little easier on the car.
Here's an E85 Octane Mix Calculator: http://www.intercepteft.com/calc.html |
