Just ordered my procede rev 2.5se!
06-22-2012, 05:39 PM | #1 |
15
Rep 368
So after much reading of various threads etc and of course the sale price. I couldn't let this slide. Still apprehensive about the install and well issues that exposed when running a tune but hoping for the best. I went with Vishnu bc I felt they were always figuring things out. This is my first performance euro. Accustomed to Japanese tuned cars. Hope I don't regret it. I have no warranty etc. my car has 9000 miles on it. Yes I don't drive the car. Anything I should do before installing the tune? Car had hpfp and all six injectors replaced already on it. I recently threw an exhaust cam code so I have solenoid to change still. Would I need to change plugs?
06-22-2012, 06:20 PM | #2 |
Rep 21
I just got the same unit on Monday. I know basically nothing about cars but was able to complete the install myself in an hour or two with no problems. Just make sure you have a 8mm socket wrench (I used an adapter for a screwdriver-style handle which worked great), and a small, sturdy flathead screwdriver for prying things here and there.
Watch the install video on youtube a few times so you're semi-comfortable with what you'll be doing ahead of time. Aside from the unclipping stuff to get everything apart, it is very straightforward and would recommend anyone else try it themself. This is especially true since you might want to take it off for certain types of services in the future... Good luck! |
06-22-2012, 06:21 PM | #3 |
Rep 21
I should also add to be VERY careful with the green power cord's clip mechanism as I actually broke off the little flap on mine during this (even though I was being careful). Luckily the flap will actually go back on and stay in place without being attached at the base. You'll see what I mean once you get in there =)
06-22-2012, 06:30 PM | #5 |
Rep 21
Mine didn't throw any codes so overall it sent as smoothly as possible. I've only had it in for a few days, but from what I can tell you the reviews are all true. It feels like a different car in terms of power delivery. Install it and tell us yourself what you think =)
06-22-2012, 08:27 PM | #6 |
Rep 65
At 9,000 miles I wouldn't change the plugs, wait till 20-25,000 miles to change them. BMW says they don't need to be changed till 60,000 miles but with a tune its recommended every 20-25k.
06-22-2012, 08:27 PM | #7 | |
78
Rep 887
OP, if you can afford it, you might as well replace all 6 spark plugs. How many miles is on your car? edit: nvm just read 9k, yeah the plugs don't need to be changed but like bceagle said, every 20-25 with a tune. |
06-22-2012, 08:45 PM | #8 |
Rep 65
I did the same thing with that green clip but mine fell into a black hole never to be found again. It has not been an issue though, the pins are held in by themselves not sure what the purpose of the green flip cover is.....maybe just added protection
06-23-2012, 03:21 AM | #9 |
yasmin3
18
Rep 112
The intall is pretty simple just make sure that you have the right maps for your type of car. ie 6AT maps for 6AT, 6MT maps for 6MT car. my initial problem was that i didn't have the right maps. but once it got fixed, with the help of another e90post member, we were able to get it to run fine. good luck.
Current: 2017 M3 competition Pack.
Old: 2015 Audi S4 2011 335is 2009 Honda S2000 2008 328i 2007 Honda S2000 |
06-23-2012, 03:30 AM | #10 | |
Rep 21
06-23-2012, 08:25 PM | #12 | |
yasmin3
18
Rep 112
Did you install it yet?
06-23-2012, 08:50 PM | #13 | |
1538
Rep 1,665
06-27-2012, 06:27 PM | #14 |
yasmin3
18
Rep 112
I think that the power delivered by the procede is definitly noticable. but from the get go Shiv told me that the overboost will no longer be applicable in the "IS" as it is also a tune that was done by bmw to increase the hp/tq therefore bypassing the ecu makes it essentially the same as the 335i with the extra OEM cooling and the DCT.
06-28-2012, 03:59 PM | #15 |
Rep 21
07-02-2012, 11:07 PM | #17 |
102
Rep 693
Its the same just the dme is on the other side exactly same instrustions very easy to install just make sure bonnet is up and lock the car for about 15mins but don't unlock the car untill you have installed the procede.
THE BEAST MHD Flash Tune /M3 suspension/Forge Intercooler/Alpina B3 AT Flash/Bilstein B4 Suspension/BMW OEM M3 Steering Wheel and DCT Paddles/LUX V4 Angel Eyes/CIC Retrofitted
07-03-2012, 05:35 AM | #18 |
15
Rep 368
What about the serial port. Where did you pass it? Our glove compartment is on the opposite side.
07-05-2012, 09:46 PM | #20 |
24
Rep 1,244
You really don't have to, it's just an extra precaution. I just recently installed mine and if you watch the video, it'll be very easy. I don't know if you have E85 where you are, but those maps are a BLAST!!!
07-05-2012, 09:59 PM | #21 |
220
Rep 880
i disconnected the batter, and make sure you have an eyeglass flat head screw driver to get some of the tabs off easier
fyi my green tab connector broke off like most other peoples have so dont worry if it happens to you |
