E90 320i excessive road noise
06-22-2012, 04:48 PM | #1 |
Rep 5
Hi Guru's
I have recently noticed an increase of road noise/resonance coming from the front end (I think) of my E90 320i (110K km). The intensity varies depending on road surface and increases under brakes. I have non standard (non-RFT) 19" wheels and tyres (Kumho 235/35ZR19). The BMW dealer service department said the differential needed replacing at a cost of $2920 (parts only) which I am very sceptical about. I'm thinking maybe the front wheel bearings maybe on the way out. What do you guys think? Cheers |
06-22-2012, 07:39 PM | #2 | |
69
Rep 2,934
06-23-2012, 12:22 AM | #3 |
Rep 51
I just had to replace my partners RHF wheel bearing ASM at 60,000kms as it completely failed. Does the noise get worse turning one way or another and quiter in a straight line?.
Bearing replacement inc parts was around $340.00 |
06-23-2012, 03:54 AM | #4 | |
162
Rep 1,460
regards Peter |
06-23-2012, 04:50 AM | #5 |
16
Rep 192
I had the same problem with my E92 323. I also had Kumho tyres.
The noise was almost gone when I put the standard runflats back on. I think the problem is the Kumhos. Before you spend a lot of money on wheel bearings and diffs, I suggest you borrow some different wheels and see if the noise disappears. |
06-23-2012, 07:40 AM | #7 |
Rep 7
I would be trying to fit a donar set of wheels/tyres to test first, as tyres definitely could be your issue if the noise does not change through turns.
Wheel bearings are more likely if your noise changes through turns, but do not rule out the rear differential though as this was the issue on my car. |
06-24-2012, 06:29 AM | #8 |
Rep 5
Thanks for the replys everyone.
I jacked the front end up and rotated the wheels and didn't notice any abnormal noises or grinding. The noise is louder in a straight line and not so loud when turning. I guess this would suggest it's not bearings as lateral load (ie turning) would make it louder. I suspect that the tyres maybe the problem, and tried to put the old wheels and RFT's back on today but couldn't loosen the wheel nuts (the knuckle draggers at BMW service department must have set the rattle gun to super tight). I'll take it to a tyre place and get them to swap the wheels and I'll let you know how it goes. Cheers |
06-24-2012, 09:24 PM | #10 | |
Rep 49
06-25-2012, 05:51 AM | #11 |
Rep 5
Yes, the Kumho's are KU31's and agree with KUSH, so I think I'll replace the front tyres and see what happens. Can anyone recommend what tyres I should get. I'm happy to pay a little extra to get good quality and a quiet ride.
06-25-2012, 07:55 AM | #12 |
Lord Captain Commander
110
Rep 3,093
Michelin Pilot Super Sports off tirerack.com. Shipping is around $250. You'll soon see it's still much cheaper than anything local. That's where I get all my tyres.
E82 135i M-sport: SGM/6MT/Black |
06-25-2012, 08:00 AM | #13 | |
44
Rep 913
Why when you have been told its your diff thats the problem, you're immediately going out to buy a new set of tyres???
. ..sweet torquin' diesel! |
06-25-2012, 08:38 AM | #14 | |
Rep 49
My kids scream when the TURBOS SPIN
06-27-2012, 02:06 AM | #15 | |
Rep 5
06-27-2012, 02:14 AM | #16 |
Rep 5
On the tyre front......has anyone had any experience with Falken FK 452's? I can get some 235/35/19 for $220 each and 265/30/19 for $250 each delivered to Canberra from Tempe tyres, which is reasonably cheap compared to some other brands.
06-27-2012, 05:43 AM | #17 |
Rep 49
They are cheap for a reason. if youre willing to go cheap then why not nankang ns2s? they'll be like 100 a corner.
07-03-2012, 09:32 PM | #18 |
Rep 34
Falken 452s have rated very highly in Wheels tyre tests in the last few years. I have them on my Golf (225-45-17) and I'm very pleased with them. I also had them on my V6 4WD Passat and they performed well, including during a skidpan session with Rick Bates driver training at Sutton Rd.
07-03-2012, 09:38 PM | #19 |
83
Rep 1,543
Am almost sure it's your tyres, if that's the issue you wouldn't get better than Michelin Pilot S.Sport non runflats on 19"s for comfort and low noise!
Tiag E90 | JBSPEED Spli t t ers | JBSPEED ACS style Roof Spoiler | JBSPEED M3 style Trunk spoiler | Euro plates | K&N Intake | BMW OEM Performance Exhaust | Debadged | OEM Chromeline trim |230 OEM rims | 19" Michelin Pilot Sport PS2 Non runflats | OEM Burr Walnut Gear knob | OEM Blacklines | OEM Spacesaver |
07-03-2012, 10:15 PM | #20 |
79
Rep 1,123
Drives: E39 540i, E90 320d,F15 30d
doubt it is the tyres, given the noise increases under brake, i'd say worn bushes or CV joints - a common problem for older BMWs.
