Coilovers w/comfortable ride?
06-22-2012, 10:01 AM | #1 |
54
Rep 523
I've had FK Silverlines for ~30K mi now and the ride is starting to get to me. It's a bit harsh, and the rear just flies up while going over bumps/expansion joints on the highway. It is annoying to rear passengers and even when I'm alone in the car. It just feels bouncy. I want the car to soften the bumps and not be so bouncy at the same time. Idk if it's the settings or the coilovers themselves, but I can't stand it anymore. Recently did a 700 mi. roundtrip ride and it was irritating to even drive the car.
I do want to stick w/coilovers b/c of the drop, but wondering what the best options are? |
06-22-2012, 10:53 AM | #2 |
MFCEO
Rep 191
Changed your dampening settings to softer yet if one way adjustable?
The problem with one-way adjustable dampening is that if you want the coils to soften the bumps (compression) then they are also going to soften the rebound just as much to match. Not too familiar with the FK's, but if rebound is adjustable seperate from compression, you should try adjusting that as well to fix the "rear flying up" aka the strut rebounding. You can also look into a different spring setup on the coils, ie swift springs with a different rate. Lastly, look into aftermarket sway bars. This will not only help with handling but will also aid the struts/springs in more precise rebounding/compression. |
06-23-2012, 03:49 PM | #3 | |
1559
Rep 4,109
Drives: BMW M3
Measure how much travel your dampers have because it sounds like you're rebounding off the bumpstops. That's not good if it's happening all the time.
Do the dampers have adjustment knob(s)? What are they set at? Quote:
A different sway bar is not going to alleviate or noticeably help the issues the OP has. He's driving in a straight line and having problems. I'm tempted to say they would do almost nothing in this scenario. Going to a different spring is an alternative but my experience says the damper is key. These cheap coilover kits are designed to work with the springs they're sent with only. The dampers are just not good.
2024 BMW M3 Sedan Frozen Pure Grey II/Fjord Blue, 6MT
Past: 2021 Z4 M40i Frozen Grey II/Black Alcantara | 2017 F30 340i Mineral Gray/Coral Red, 6MT | 2011 E92 335i Le Mans Blue/Black, 6MT |
06-23-2012, 04:21 PM | #4 | |
146
Rep 1,160
As one low rider, you got form over function. Why sport a 'look' when it's annoying to drive? Go a diff direction, matched coilovers. Getting pretty good results & riding lower w/Ground Control - shocks are their spec yellows - approx. 3/4" below stock, adjustable. However, running M arms/sways. Seems to be in a sweet spot. Maybe not as low as yours. |
06-24-2012, 06:41 PM | #5 |
164
Rep 2,556
KW Street Confort c/o's
2007 E90 335i, TiAg, 6AT, ZPP, ZSP, ZCW, 6FL, HD
Quaife lsd, ETS fmic, GIAC s/w, Dinan intake/exhaust/oc, Koni/M3 susp, Apex Arc 8, Mich PSS |
06-26-2012, 12:31 AM | #6 | |||
MFCEO
Rep 191
Also, there are plenty of cheap coils out there that seem to perform significantly better with upgraded springs, Fortune 500's (a cheap coilover with different Swift options) is a good example of this. But again, i have no knowledge of FK's. |
06-26-2012, 09:32 AM | #7 |
54
Rep 523
Thanks for the responses guys. I'll look into the suggestions here, but am not too familiar w/the setup myself b/c I had the shop who installed it do the settings. I might end up taking it to VAC here in Philly and see if they can adjust it to my liking.
I think I forgot to mention, but it's not too bad when it's just me in the car. But, if I have passengers in the back, it's the worst. It's kinda ghetto seeing that rear (and the passengers) fly up/bounce any time we hit some joint in the hwy. It may be that it's hitting the bumpstops now that you mention it. |
06-26-2012, 10:07 AM | #8 |
592
Rep 5,396
Its set too low, and likely the dampers arent high enough quality to work with a stiff spring and also work with substantially less available suspension travel range
You will need to raise the car up at least a half inch or more to gain an appreciable gain in ride comfort. this will be the same for any coilover you use.
06-27-2012, 04:55 PM | #10 |
107
Rep 884
I have FK Silverlines on my Audi and after 4 years when I first drove my new CPO 335i, the ride was the softest thing I've felt in a while. I love the flatness in turns of the FKs, but wow if rolling over leaves wasn't jarring. I didn't get any bounce though, it's really, really, stiff.
I don't think I'd ever get FK's again and if I get some extra cash I'll switch them out for something else since my wife took the Audi. My wife doesn't seem to mind the ride, but she's only had it for a month.
Current: 2021 Carbon Black w/Cognac X5 M Sport
Sold: 2018 Dark Graphite 540i M Sport Sold: 2013 Mineral Grey 335i M-Sport Sold: 2010 Sapphire Black E90 335i |
