New to Cobb community: Cobb gurus how does my first data log look
06-21-2012, 11:24 PM | #1 |
81
Rep 1,656
This is my first time logging data with Cobb. Any help or insight will be appreciated greatly. Here is my data log of timing and boost. I have N54 E92 335i auto. I was running 93 octane on stage 1 sport. The temp was about 86 degrees day time.
nickname"BAD 3",MHD E85 tune,RennArt catback non-resonated exhaust,VRSF Downpipes, VRSF 7"FMIC,VRSF stock side inlets,SSQV BOV,ECS CP,M-performance alcantara steering,retrofit M3 paddle shifters,Alpina B3 tranny flash,AFE power seal CAI,LED angels,ST Coilovers,M3 upper/lower control arms,E93 M3 Front Swaybar ,235/35/19x9 ,275/30/19x9.5. M sport bumpers, CF diffuser. When in doubt..flat out.
06-21-2012, 11:28 PM | #2 |
Agent Smith
270
Rep 3,344
Drives: 2016 i8
Image requires an account on cobb forums. You'll want to save it locally and add it as an attachment here.
The i8 needs a V8 amirite?
06-22-2012, 01:16 AM | #3 |
81
Rep 1,656
Here you go guys sorry about that. I fixed the original post also after uploading the image.
06-22-2012, 06:36 AM | #4 |
36
Rep 708
You need to graph more monitor channels.... Search for my datalog grapher, that will make life easier for you.
06-22-2012, 09:29 AM | #5 |
313
Rep 3,262
Logs look quite good, I suppose this is Stage 1 ? Can you also put the throttle position in the graph ?
06-22-2012, 09:58 AM | #6 |
70
Rep 2,197
Need more info(channels.)
Here's something to get you started: http://www.e90post.com/forums/showthread.php?t=696472 |
06-22-2012, 10:07 AM | #7 | |
196
Rep 2,669
06-22-2012, 10:14 AM | #8 |
24
Rep 1,244
06-22-2012, 12:04 PM | #9 | |
78
Rep 887
OP, the runs look good as far as timing goes and usually hints the car is running healthy and 100%. logging timing in cylinders 2-6 gives us a better idea as well. |
06-22-2012, 10:54 PM | #10 |
81
Rep 1,656
Thanks a lot guys for taking a look and helping me out......you guys are the best
I read the thread some of you pointed me out to. I realized that I never did the run without traction control off. Thus, the slight timing drop even before 1st gear change. I know the rest looks OK as you guys mentioned. I will do another run with traction control off and maybe a bit more higher map. I will go with stage 1 aggressive maps stock since I run 93 octane. Do you guys think it is safe to do stage 1 aggressive or stick to stage 1 sport. I will respost my results in a new thread. Once again thanks to all you fellow tuners you guys are great
06-22-2012, 11:11 PM | #11 | |
70
Rep 2,197
You really need to log RPM, TPS actual, boost and timing corrections(or just timing) as a bare minimum to get a good idea of what's going on |
