Single Turbo + Cobb ATR
06-21-2012, 12:38 PM | #1 |
Rep 211
At the risk of eliciting some strong opinions, I'm curious whether or not anyone has any intention of getting a single turbo and making an ATR map for it rather than using a procede.
Is it possible? I'm sure there are pros and cons to both, meth support likely being a big point of contention. What might be some advantages? I know a large part of developing the turbo kit had to be dialing in the tune to get consistent, smooth results that generate as much power as possible without blowing things up, so it's bound to be quite a bunch of work. Having options though would definitely be a positive. Thoughts? |
06-21-2012, 12:42 PM | #2 |
196
Rep 2,669
It would be more realistic to have a ATP map where you can put the car on the dyno and start from there.
ATR will come after that. HFS-4 and HFS-3 meth system work great with Cobb |
06-21-2012, 12:49 PM | #4 |
1737
Rep 17,960
Drives: A Lot
Garage List 2018 Ducati Panigal ... [0.00]
2016 Mazda CX5 [0.00] 2017 Aprilia Tuono ... [0.00] 2019 BMW M2 Competi ... [0.00] 2015 BMW M5 Competi ... [10.00] 2016 Ducati XDiavel S [0.00] 2016 AMG GT S [0.00] 2011 Ferrari 458 It ... [0.00] 2017 Charger Hellcat [0.00] 2015 KTM Super Duke ... [0.00] 2016 KTM RC390 [0.00] |
Some will try and I suspect they will be disappointed. Too many things in the DME which make single turbo control unrealistic. I suspect those who disagree will agree if/once they actually try it.
06-21-2012, 01:02 PM | #5 |
76
Rep 1,883
First hurdle that comes to mind: MAP sensor.
Legal Disclaimer: Anything I or anyone else says about my vehicle on this website(e90post.com or any affiliated or nonaffiliated sites), pertaining to modifications, is only to gain acceptance from my/our peers, and does not actually represent anything actually existing on my car, and thus, cannot be held against me in any issues, i.e. warranty claims, that may arise.
06-21-2012, 01:03 PM | #6 |
33
Rep 1,029
06-21-2012, 01:06 PM | #9 |
70
Rep 2,197
06-21-2012, 01:11 PM | #10 |
33
Rep 1,029
06-21-2012, 01:13 PM | #11 |
70
Rep 2,197
06-21-2012, 03:31 PM | #16 |
1737
Rep 17,960
Drives: A Lot
The map sensor isn't the real issue. But rather load scaling, torque limiters, boost control issues and rev limits (throttle based). I think it's possible to make it work to a point. But it won't work nearly as well or as consistently without an external tuning device. We have tried
06-21-2012, 03:35 PM | #17 |
1737
Rep 17,960
Drives: A Lot
Current tech actually makes it more difficult to do things outside of the parameters it was designed for. If one could remove the DBW, torque limiters, throttle based boost/rev control, high freq flyback solenoid control, transmission/dme communication, all the inter-table dependancies, etc, the MSD80/81 would be easy to map for single turbo applications.
06-21-2012, 04:26 PM | #18 | |
Rep 211
Now that I think about it, I can't recall ever seeing a member using one.. |
06-21-2012, 04:35 PM | #19 |
1737
Rep 17,960
Drives: A Lot
Some high end stand alone ems system capable of supporting direction injections are certainly an option. But you would be sacrificing some of the things that the factory DME does better than anything else (knock control, closed loop fuel control, misc safetly functions, etc). On the end, the best solution is one that doesn't give the important things up while improving upon/replacing the functions that it doesn't do well (due to fundamental design).
06-21-2012, 05:10 PM | #20 | |
41
Rep 468
Cheers, Rob |
06-21-2012, 05:20 PM | #21 |
1737
Rep 17,960
Drives: A Lot
06-21-2012, 05:48 PM | #22 | |
46
Rep 1,145
