Meth and Pro Tune
06-21-2012, 04:47 AM | #1 |
169
Rep 1,247
Meth and Pro Tune
Well my car was dropped off saturday for meth install and cobb access tuner pro tune. On the way to the shop, I threw a P3OFF boost leak code and
P2A87 vanos plausibility. I believe this is the exhaust vanos solenoid from the research Ive done. Obviously the boost leak could be solved with new charge pipe and BOV, but if not the shop has a smoke tester. But does the P2A87 code prevent them from doing a pro tune on the dyno? Does that code put the car in limp mode? WOndering how this should be handled...
2009 E92 BMW M3.
06-21-2012, 05:20 AM | #2 |
915
Rep 3,456
Drives: Harrop E90 M3
Yes it will. The 30FF is likely set as a result of the vanos fault. Just replace both solenoids and change the oil. You should be good to go.
06-21-2012, 07:31 AM | #3 |
169
Rep 1,247
I was also getting the P3OFF code without the vanos code. So Im assuming I also have a boost leak...
2009 E92 BMW M3.
06-21-2012, 07:42 AM | #4 |
33
Rep 1,029
06-21-2012, 07:42 AM | #5 |
196
Rep 2,669
06-21-2012, 09:11 AM | #6 |
169
Rep 1,247
Hopefully it is the charge pipe pr DVs because the charge pipe is being replaced with an ETS chargepipe, and the DVs replaced by a Tial BOV. Im hoping that solves the boost leak issue. But I hope the vanos solenoid doesnt prevent them from tuning the car. I miss my car lol
2009 E92 BMW M3.
