The Tire Rack
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Powertrain and Drivetrain Discussions > N54 Turbo Engine / Drivetrain / Exhaust Modifications - 335i > Vishnu/FFTEC Single Turbo Dyno (573whp): 6AT with "little" 58mm Turbo Option
      06-21-2012, 03:24 AM   #1
OpenFlash
Drives: A Lot
Exclamation Vishnu/FFTEC Single Turbo Dyno (573whp): 6AT with "little" 58mm Turbo Option
Hi guys,
We've been working nonstop for the last 3 weeks on single turbo 6AT tuning. S Specifically how boost/throttle is controlled during short shifts (upshifts). It's during this specific condition that over-torques the 6AT clutch pack. So we developed Procede boost control code to manage torque during these mid-shift conditions. It's working quite well on the road (i'll post up logs later this week). But today was the dyno to see what it is currently putting down to the ground on the Dynojet at full boost.
We still aren't completely done with the WOT calibration (still have to do pump gas mapping) but we are getting close. So far, running 93oct+meth, it put down some good numbers at just 20psi tapering up to 23psi by 6300rpm.
On the dyno during a 4th gear pull, the 58mm turbo on the 6at spools up exactly as quick as the 62mm on a 6mt. But on the road, it has significantly faster transient response making it a good match for the 6at. And since we are currently rev limited with the 6AT upshifting at 6500rpm, there is little sense in going with the bigger 62mm turbo. In the end, running similar boost curves, the 58mm 6AT puts down nearly identical power/tq as a 62mm 6MT all the way up to 6200rpm. Above that, the 58mm 6AT power curve tapers off boost due to higher back pressure levels and in preparation for the upshift while the bigger turbo 6MT still keeps climbing and climbing:
The run duration on a 570+whp car is pretty short. So short that the dyno doesn't load up the car properly which means the turbo doesn't get a chance to spool up as fast as it would on the road. So I did a partial 5th gear pull which gives a better idea of what to expect on the street. In 5th gear, we mapped the Procede to reduce high RPM boost target a bit to compensate for the higher IAT and higher engine load (hence the power power number). We also had to stop the run early to avoid hitting the max speed limit on the dyno (160mph) which would delete the run. But the recorded low end is still very representative of real-world behavior (400lbft@3400rpm):
As time goes by, we will get more and more aggressive with these single turbo tunes. I have no doubt that we can achieve 600whp even with the small 58mm turbo. Especially once we are able to remap the TCU to shift at 7000rpm instead of 6500rpm. But for now the car runs fast, shifts quickly and doesn't trigger transmission codes/problems
Cheers,
Shiv
      06-21-2012, 04:55 AM   #2
D_Smiderreen
Drives: Please delete my account
Pretty impressive Shiv, great job. There is light at the end of the tunnel for us 6AT guys.
      06-21-2012, 05:07 AM   #3
WINGNUT
Drives: 2007 BMW 335i 6MT
I hope my wife doesn't find out about this. She's a speed freak and if she finds out that she can have a 335 with 600hp in an AT platform, she may buy a car and make it happen before I can, and she's spotting me a car. Lol
Keep it up Shiv.
      06-21-2012, 05:31 AM   #4
plague
plague's Avatar
40
Drives: 335i sold :( / jb 20th AE
nice shiv! 600 whp on the 58trim should assume 700+ on the 62
07 335i- SOLD, and will be missed...
Parts for sale- PWM meth kit, M steering wheel, M shift knob, perforated e brake handle
      06-21-2012, 05:54 AM   #5
seoulmandmd
seoulmandmd's Avatar
Drives: 335i
So 58 only for 6at.
Not that almost 600 hp is anything to laugh at!
      06-21-2012, 06:22 AM   #6
Stucks
Stucks's Avatar
Drives: 2017 F30 340i Xdrive
Wow, that's pretty cool! 6AT single turbo 335i's should be rather easy to get into the 10's.
Current: 2017 F30 340i xdrive
Previous: 2008 e92 335i coupe: RB turbos, mach 116 race fuel, methanol, alot of boost.
Previous: 2003 Honda Accord V6 coupe: AEM V2, zex 75 wet shot (sold)
      06-21-2012, 07:31 AM   #7
Dr_Dirt
Dr_Dirt's Avatar
Drives: E90 335i 6AT
What is the stock turbo sized at for comparison?
      06-21-2012, 08:00 AM   #8
chris b.
chris b.'s Avatar
Drives: zmp e90
2010 335i  [0.00]
Brentuning Cobb AP pro tune -IG: @beemeraddict
2010 335i zmp fbo, 465/513 E60 mix
      06-21-2012, 08:25 AM   #9
Mr_PharmD
44
Drives: 335i coupe
very impressive as usual.
How much meth is the 58mm turbo using and is the high back pressure due to maxing out of the turbo?
      06-21-2012, 08:43 AM   #10
themyst
themyst's Avatar
South Korea
177
Drives: '16 MK7 GTI
So you are saying don't short shift the auto? Not that I'd want to given that turbos flow characteristics. By reducing torque before and after the shift though you'd cost the car some acceleration time I would venture to state. I've done something similar by tapering off very aggressively after 6500 RPM but it simply reduces momentum and the car will perform poorly.
Or we could simply build the transmission, chalk it up to a requirement and not worry about it. The user picked the transmission, now the user can pay to build it.
E90 LCI N54 6AT
      06-21-2012, 09:45 AM   #11
JMARS
Not Baned
Drives: e92 Single-T
This all looks very exciting, I'm curious though if the AT kit would also fit a MT car? I'm planning on picking up a 6spd 335is e93 early next year BUT I'd love put this kit on whenever it gets released on my current AT 335i...
      06-21-2012, 10:49 AM   #12
cupertinosteve
Drives: BMW 335i
I'm pretty sure the kit is interchangeable ... its possible you may run out of breath on the 58mm turbo on the 6MT since you have nearly a 1000 rpm more to run.
      06-21-2012, 10:53 AM   #13
cupertinosteve
Drives: BMW 335i
Originally Posted by themyst View Post
So you are saying don't short shift the auto? Not that I'd want to given that turbos flow characteristics. By reducing torque before and after the shift though you'd cost the car some acceleration time I would venture to state. I've done something similar by tapering off very aggressively after 6500 RPM but it simply reduces momentum and the car will perform poorly. ...
I know that the up top taper is there to the impending shift that will happen - whether user or TCU induced.
With regards to the short shift and non-desirable stress that is added from going to post-shift boost pressure to full boost ... there is something in the works to make it really sweet.
And yes, i have set aside budget for a new transmission. I'd like to see what a stock 6AT can do, so we will all know where the limits are.
      06-21-2012, 11:31 AM   #14
Eleventeen
30
Drives: G42 M240i
I have an auto, so I am most interested in how things develop with this kit, even if it's not as aggressive as the 6MT kit. What meth mixture are you running with this turbo?
That's some nice power, B.T.W.
G42 M240i xDrive
      06-21-2012, 11:51 AM   #15
OpenFlash
Drives: A Lot
Yes, the turbos are all interchangeable and I think the 58mm will be a nice match for the 6mt for those who aren't going after big numbers. I suspect it will make 600whp on meth and 500whp on pump. Just speculation at this time as we have not tested such a combo.
      06-21-2012, 11:59 AM   #16
OpenFlash
Drives: A Lot
Currently spraying 1000cc/min using an 80/20 mix. The 58mm turbo definitely isn't as fuel hungry as the 62. Most of the top end roll off is caused by boost reduction in preparation for the upshift. It goes through the shift so quickly, you don't even feel or able to log any pre-shift boost drop.
      06-21-2012, 12:03 PM   #17
Bakeme521
Some say...
Bakeme521's Avatar
Drives: Fresh
2007 BMW 335i  [8.24]
Until the transmission pops
I have exhaust and an intake...
      06-21-2012, 12:04 PM   #18
onesuperboi
onesuperboi's Avatar
Drives: '08 e92 335i COBB 4.01 Stage 1
Is there a smaller turbo that could be used that could offer similar power but even faster spool up?
      06-21-2012, 12:06 PM   #19
nafoo
nafoo's Avatar
Drives: Boosted Bimmer
When are you taking the AT to the track?
      06-21-2012, 12:07 PM   #20
OpenFlash
Drives: A Lot
I'm pretty confident they should hold up well.
      06-21-2012, 12:11 PM   #21
Eleventeen
30
Drives: G42 M240i
57.99mm
Precision has quite a few turbo options, but the 58 mm seems to be delivering some nice power for it's size. For reference a GT3582R is 61.4 mm and is rated at ~600 HP.
Precision.pdf
G42 M240i xDrive
      06-21-2012, 02:27 PM   #22
vereak82
vereak82's Avatar
14
Drives: 6-spd e92 335i
DAMN! Thats awesome i bet that A/T is a riot to drive
2008 135i 6-speed current stock for now
1995 e36 M3 5-speed
Jb4 G5//CM-FX400//FBO//Meth// 12.06@118 6-speed manual sold summer 2013
