Idle surging. Throttle potentiometers question
06-19-2012, 03:35 PM | #1 |
NeedsMoarBoost
42
Rep 527
I am throwing 2CF6 and when I reset the throttle / codes it gets better but always comes back. Brought to BMW they cleared and say its not duplicating which I told them it wouldn't right away if it was cleared.
When it happens the code is always the same 2CF6 which has to do with the "throttle potentiometer 1 In regards to air mass." Anyone have any idea which part # this would refer to. I'm just going To fix it myself but having a hard time finding the part #. Can only find the entire throttle body on getbmwpxxxs. The idle will surge badly until warmed up than surge mildly. Once codes are reset with throttle it goes back to normal for any amount of time it feels like Than comes back. I've had it. And don't want to wait any longer. Thank you very much for any help you can provide me !
08 135i 6m - 12.1@120.2 2.0 60ft - JB4/Meth - SOLD
09 335i e92 Mtech - RB FBO |
06-19-2012, 04:08 PM | #2 |
Some dude
92
Rep 1,780
Any intake leaks? Boost or vacuum leak after the throttle sounds like the culprit.
The throttle position sensors (not traditional variable resistance but non-contact position sensors) are inside the EGAS (electronic throttle), not serviceable or replaceable. I'd avoid replacing it unless you can't find anything else wrong. Also any chance the JB4 needs to be blown away and reloaded with firmware and software? Or maybe a bad connection as worked itself a little loose?
RRT
E92 335i/6MT with stuff and things |
06-19-2012, 04:35 PM | #3 |
177
Rep 6,631
Some weird stuff. I'd drive around on map 0 to see if it comes back on, disable the auto code clearing so that it saves itself and take it back to dealer.
E90 LCI N54 6AT
06-19-2012, 08:27 PM | #4 |
NeedsMoarBoost
42
Rep 527
Thanks for the tips.
Car was on map zero for a while and it happened. Firmware has been switched and g4 and g5 boards were used. It started months ago when randomly it would surge on start up and I'd have to do the idle control reset. (Aux on for 10 secs than off , on , etc. it would work). This time it wouldn't but BMW cleared codes and reset throttle and it went away. But I'm sure it'll do it again. What I was looking for was that I need the whole throttle body ($400 tischer) I'll see what BMW does Abd wait for it to pop it's head again maybe try BMW one more time than I'll do it myself. Thanks. Code clearings been off. Myst did u see my text of my crazy list of codes ?!?
06-19-2012, 10:26 PM | #6 |
Some dude
92
Rep 1,780
I would think you should have a throttle potentiometer mismatch code and go instantly to limp mode if you had a bad EGAS. Sure there are no leaks or bad MAP sensor pre or post throttle? The code verbiage states some calculated air mass is exceeded/not achieved when compared to throttle angle.
RRT
06-21-2012, 07:17 PM | #8 |
Commander
10
Rep 273
I'm having the same issue, first threw 2CF7, now 2CF6.
Please let me know what you find out, I'm hoping I don't need to buy a new throttle body.
2011 335D E90 M-sport Space Gray - JBD, K&N, M3 interior conversion, GiroDisc Rotors
2012 Volt Premium 2007 Mustang GT Covt -MT |
07-21-2012, 01:34 PM | #9 |
33
Rep 886
I had the same issue and the problem went away after I reset the codes. Now its back after 3 weeks :/ anyone have any luck fixing it for good?
Performance: JB4 ECU, CP-E DP's, WW BMS Meth Kit, AR meth elbow, BMS DCI, AFE Intake Scoops, Exterior: Enkruez 19" H8R, H&R Spacers, Aero Lip, Tint, ACS Roof Spoiler, HID AE's, HID Fogs, Black Grills, Sport Pedals |
08-24-2012, 02:18 AM | #10 |
64
Rep 1,159
I've similar issue, usually when I've JB4 installed. I set it to Map0, reset code, went on a test run, didn't even push the car, and limp mode. I just took the JB4 out and about to go on a test run. see if it comes back.
Anyone got a fix for this? much appreciated. |
12-07-2012, 10:38 PM | #11 |
125
Rep 3,004
BUMP, just started having the same issue
2007 E92 6MT SGM: MusicarNW Level 2, Procede Rev 2.5, FFTEC/Vishnu LPFP with Flexfuel Sensor and Flash, M3 Offset V701's, WaveTrac LSD, Michelin PSS, Downpipes, M3 Control Arms, TCKline D/A Suspension, LCI Tail lights, Lux AE's, ER Charge Pipe, DCI's, Mtech Front and Rear, M3 Sideskirts, HPF Stage 1 Clutch
12-08-2012, 12:04 PM | #12 |
Rep 63
I have had this problem on a car before, the car would die in the middle of the road, id also have lean faults and a million air mass correlation faults. It would usually happen when it was cold and i had all the accessories on (seat heating, headlights ect) we replaced the throttle, map sensor, and tmap sensor. We found one thing in common with the faults, voltage. Check your alternator. As we were monitoring the vehicles voltage to see if the alternator was actually dipping like the faults claimed, it completely locked up.
I have also seen failed alternators take out tuners...
BMW master tech
2010 E92 335i 6-speed 25k miles. - For sale. 1989 E30 325i coupe 5-speed DD |
05-12-2013, 04:33 PM | #14 |
125
Rep 3,004
I had the same error that came and went, when I cleared adaptations it would be fine for days sometimes months, but always came back, more and more frequently.
In my case it was the throttle body, which is around $300 from the dealer and a SUPER EASY DIY. Like 45mins if you take your sweet ass time. It's literally 4 bolts at the top of the engine, the bolts on the back side are a bit tricky, because you can't see them. I have yet to have the error return in 3 months and ~3k miles
05-12-2013, 09:21 PM | #15 |
16
Rep 282
Looks like my problem is more
Complicated since I have replace the throttle with one that was working on a 135 but I still have the code. I dont know if it could be the main ECU that need to be replaced. |
08-28-2013, 05:53 PM | #16 | |
200
Rep 2,799
Car will start but the idle is surging from 400 to 1300rpm back and forth rapidly, throwing the 2CF6 and 2CF7 code. Even after resetting everything and all adaptations and ecu, the problem is just as bad, never gets any better. Did you guys let your cars warm up when it was behaving this way? Do you think it's safe to do so? Should I just bite the bullet and not drive the car until I order the throttle body and replace it? Any input greatly appreciated as I cannot drive my car right now.
thanks to MGallop |
08-28-2013, 07:11 PM | #17 | |
125
Rep 3,004
P.S. BMW in San Mateo got within $20 of Tischer's price. You just need to mention Tischer's price and with shipping it's about the same price, except you get the part the same day. you are more than welcome to take my old one. It still kinda works if you need something temporarily, but I am up in SF, so you should probably just install a new one.
08-28-2013, 11:50 PM | #18 | ||
200
Rep 2,799
thanks to MGallop |
08-29-2013, 12:19 AM | #19 | |
125
Rep 3,004
08-29-2013, 07:46 AM | #20 |
///Member
49
Rep 327
I had same issue.you need to direct connect the throttle wire from plug & play.forgot which wire.do a search.I had same annoying issue & tries it all.doing this. Fixed it.try it.its free
01-05-2016, 01:22 PM | #21 | |
423
Rep 900
