Stock Brakes
06-19-2012, 10:13 AM | #1 |
Rep 16
Stock Brakes
My wife has a 06 325i and it will be needing front brakes soon. It's just a daily driver so stock is fine with her.
What would you recommend? THANKS, Jody in Tallahassee |
06-19-2012, 03:43 PM | #2 | |
15
Rep 153
Something you might look into prior to changing the front pads though is to inspect and see if the rear pads need to be changed also. On my 325i, the rear pads had about 3 times more wear than the fronts with the same mileage. If you are using the CBS to determine when you need brake pads, I also suggest that you have someone visually inspect the pads. In my case, the CBS was way off for the fronts and somewhat accurate for the rears. |
06-19-2012, 06:24 PM | #3 | |
Rep 16
THANKS Brad,
OEM is fine, I should have asked where to shop for parts too? I do not want to deal with the dealership, major rip-off here in my town. Do you have a suggestion? THANKS Quote:
06-19-2012, 06:55 PM | #4 |
Freight Dawg
104
Rep 2,103
www.getbmwparts.com in general as good stuff.
Here's their package on front rotors pads and sensor: http://www.trademotion.com/partlocat...catalogid=4462
--Marcelo
'06 Arctic Metallic 325i | Sport Package | 6MT | Dinan Stage III suspension | Dinan exhaust | 330i manifold swap! Click here! | Active Autowerke tune | 135i Brake Calipers | Deiselboost caliper brackets | E46 M3 front rotors |
