m3 or polyurethane bushings?
06-18-2012, 04:40 PM | #1 |
104
Rep 1,529
Hey guys just wondering which ones you would choose...i just spoke with vac and they told me that the powerflex polyurethane subframe bushings would be the best but im afraid of it being too stiff or noisy.
they said that there is no difference between the powerflex and the m3 bushings as far as noise goes but the powerflexes are a little more stiff and easier to install. either way i was hoping someone on here had experience with either. please let me know thanks.
Space Gray l 6MT l OSG LSD w/ VAC Race Diff Cover l Cobb e30 l Morr vs8.2 l UUC SSK w/ DSSR l VSRF Catless Dps l RPI Intercooler l CDV Removed l HID AE 8000k l ETS Catback l AST 5200 w/ Vorshlag Camber Plates l ER Dual Oil Coolers l Rear Camber and Toe Arms l K&N Drop In l Solid Tranny/Diff/Subframe Bushings l Bridgestone RE-11
06-18-2012, 05:36 PM | #2 |
161
Rep 7,377
Go M3, also search in the proper section.
06-18-2012, 05:38 PM | #3 |
102
Rep 1,903
Drives: e92 335i 6MT
Was thinking about this as well.
06-18-2012, 06:12 PM | #4 |
79
Rep 2,396
Drives: '08 E90 335i
No personal experience, but I've been looking in doing a full M3 suspension conversion (they sell it as a package from Tischer) -- For a DD it'd prob be enough of an upgrade (with an LSD, coilovers & springs) where it significantly upgrades the handling for my DD without killing my spine
06-18-2012, 07:10 PM | #5 |
Some dude
92
Rep 1,780
Urethane bushings are not great - they can slip and move in subframe applications. You have to ensure they can't move. I use them on racecars in certain applications, but only carefully. The M3 bushings are not easy to install, but they hold up much better and don't slip like urethane bushings.
The M3 arm conversion set from Tischer is good. Not all of the M3 arms fit non-Ms, but Tischer only sells the ones that will work. I've machined E36 balljoints to fit all of the rubber bushings on the E9x rear ends for racecars, and that would be the ultimate ideal.
RRT
E92 335i/6MT with stuff and things |
06-18-2012, 07:31 PM | #6 |
79
Rep 2,396
I think the Tischer kit $2k (Control Arms, Guide Rods, Strut Braces, Wishbones + Sway Bars) and then for another $240 you get the rear M3 subframe bushings
06-19-2012, 12:52 AM | #7 |
164
Rep 2,556
M3 subframe bushings are ok, but I still have straight line tracking problems.
No experience with Powerflex, but past experience with polyurethane was sqeaky. VAC should be a good source of info. If you don't mind an increase in NVH and have a high HP car, look at Turner's solid Delrin mounts or BMW Motorsport group N bushings; the latter will set you back $800. Wrong sub forum btw
2007 E90 335i, TiAg, 6AT, ZPP, ZSP, ZCW, 6FL, HD
Quaife lsd, ETS fmic, GIAC s/w, Dinan intake/exhaust/oc, Koni/M3 susp, Apex Arc 8, Mich PSS |
06-19-2012, 01:16 AM | #8 |
104
Rep 1,529
well this sucks because i still cant make up my mind...and i do see what you mean by they can slip cause that is the main reason why vac recommended them was for an easier install.
i really wanna know if there is any downsides to the powerflexes as they are only $50 more but saves like $150 in install...but if there is any downsides then i might as well just get the m3 bushings.
06-19-2012, 02:22 AM | #9 |
40
Rep 623
I think the poly's for daily driver use are a little to much. Not so much in the stiffness of the way the car sits when you romp on it, but more so just cruising or heading to work early in the morning during traffic lol. Going over the slightest offsets in the road, your going to feel. I would go with the M3 ones. I have them and could tell a major difference especially when paired up with a LSD
[SIZE="2"]Crimson Red E92 335i M-sport 6-speed with MHD custom stage 2+ flash only , 40% E85/93 mix,+ HRE P40S wheels, KW Clubsport, M3 sways,+BMW performance CF Mirrors, BMW Performance CF deck lid spoiler,+ CF interior trim, p3 vent boost gauge,+ LUX angel eyes (11.73@124mph on street tires)
06-19-2012, 08:32 AM | #10 |
38
Rep 1,079
I have the M3's in my car and love them! They're a great upgrade and an OEM part.
2004 E46 M3 | Imola Red on Cinnamon | Slicktop | Manual Seats | 6spd MT |
06-19-2012, 08:37 AM | #11 | |
nsomneeak
39
Rep 501
Yeah, the poly ones definitely give you much more road feedback. I don't have them in this car, but I replaced all the bushings in my last car with graphite impregnated poly bushings (Energy Suspension) and it was as described above, though that is what I was looking for...you'll definitely feel the road much more with them, all the time. They didn't add any noise though, but I lubed the crap out of them before putting them in. |
06-19-2012, 08:53 AM | #12 |
103
Rep 1,520
+1 for the M3 bushings.
Be sure to examine your diff bushings also. Mine were toast after 75k. replaced them with turners aluminum ones and should be good forever now. |
06-19-2012, 08:57 AM | #13 |
52
Rep 306
The polyurethane Powerflex bushings should be a bit more firm than the M3 bushings, but can squeak a little if not generously lubricated. I have used polyurethane on a few different cars of mine with good results all around. It's not a bad material to use for a bushing replacement. The M3 bushings will definitely give you a noticeable improvement as well like many members around here will tell you. Neither choice is bad. In my opinion, price is probably the biggest factor here.
-Josh |
06-19-2012, 11:10 AM | #14 |
104
Rep 1,529
well if price is really the only factor then its the powerflexes.
thanks still taking more inputs as i wont have this done til probably next weekend.
06-19-2012, 11:15 AM | #15 |
164
Rep 2,556
^pm 'chowbow' and ask him how his Powerflex subframe bushing inserts are holding up. If your choices are limited to Powerflex and M3, go M3
06-19-2012, 11:21 AM | #17 |
104
Rep 1,529
how so? and who makes one.
06-19-2012, 11:26 AM | #18 |
34
Rep 1,381
The solid delrin is the best to keep the subframe intact for better launches and stability. Turnermotorsports makes them. http://www.turnermotorsport.com/BMW-...nd-mounts.aspx
06-19-2012, 01:56 PM | #19 |
102
Rep 1,903
Why do the Delrin ones cost twice as much as the M3 bushings tho? Is it that much better??
06-19-2012, 02:05 PM | #20 |
46
Rep 1,145
