Mystery Misfire: Not Plugs/Coils/Injector - Any Ideas?
06-17-2012, 12:30 PM | #1 |
Aficionado of All Things Vroom
171
Rep 1,213
So as the title states, i've been having an obnoxious yet consistent misfire on cyl 3 for the past few weeks. Of course I tried replacing all 6 spark plugs (first dealer trip), in addition to swapping coilpacks between that cylinder and another. misfire remained in cyl 3 so I figured it was the injector. Dealered twice, once for injector and once because they wanted to try replacing the coilpack, yet the misfire stayed in cyl 3. It essentially occurs every time I drive the car, and makes it pretty much undrivable ( having to stop/restart motor every time). Conditions don't matter, as it happens across the board both with tune and without.
I've read about carbon buildup causing misfires, but from what I've gathered, it won't necessarily trigger a single cylinder as consistently as I'm getting them (everytime I drive). Similarly, I've seen hints at dirty vanos solonoids causing misfires, but I know nothing about whether or not that's accurate in regards to a single cylinder. I assume if it was a bad O2 i would see misfires across the entire bank, instead of an individual cylinder. I'm dealering the car tuesday (fourth time in a month for the same problem) but I'd like to have a list of places to suggest they start. Any clues what else could trigger a consistent cylinder misfire besides the aforementioned typical clues? For reference, i've got 37k miles on the car and am FBO/Meth. thanks, Zach EDIT: Forgot to mention I've been getting a limp mode/engine malfunction in higher gears at lower RPM if i go WOT... I think this is my turbos starting to go (30FF thrown, actuators not sealing causing a boost leak) but figured it may be worth mentioning
Current: 2020 F97 X3M Competition
Retired: '18 6MT AW F30 340x Drive | '15 6MT F80 M3| '11 AW DCT E92 M3| '09 6MT AW E90 335i| 08' 6MT E92 328xi Last edited by ZTZ1010; 06-17-2012 at 12:56 PM.. |
06-17-2012, 12:31 PM | #2 |
348
Rep 1,407
car is a 09 with 2-3 yeard of driving around and being FBO you may have a good amount of carbon in your valves.. I would rule everything out before having to remove all mods and taking to the dealer...
06-17-2012, 12:37 PM | #3 | |
171
Rep 1,213
Luckily my dealer is mod friendly and I'm under warranty. I think the walnut blasting will be the first item on my list, since I'm just going to press them to fix/replace everything it could be. 4 times in 3 weeks is excessive, so I want to make sure I address all possibilities. Thanks for the idea!
Retired: '18 6MT AW F30 340x Drive | '15 6MT F80 M3| '11 AW DCT E92 M3| '09 6MT AW E90 335i| 08' 6MT E92 328xi |
06-17-2012, 12:40 PM | #4 |
83
Rep 2,132
Drives: FBO+ N54xi
Is the injector coded in correctly?
JB4+usb | P3 Vent Boost Gauge v2 | BMS OCC | BMS DCI | AMS FMIC | AR xi CL DP's | BT Tool | Edibias/NCSExpert/INPA BMW Coding | Cyba Quad Exhaust tips | M-Tech Rear & M3 Front Bumper | Red Cyba Air Scoops | Blacklines | Vinyl Overlays | ACS Roof Spoiler | Matte Black Grilles | LED Side Mirrors | Rear Euro Fogs | etc..
06-17-2012, 12:42 PM | #5 |
171
Rep 1,213
dealer did it.. my tech is very knowledgeable and precise so I can only assume so...any way to check?
06-17-2012, 12:42 PM | #6 |
348
Rep 1,407
Do some research... also read where it could be solenoids or cam lifters... dont quote me on that though... there was a huge thread on it but im toolazy to search Definitely check out the valves... at 37k miles you are about due...
06-17-2012, 12:45 PM | #7 |
83
Rep 2,132
Drives: FBO+ N54xi
Yea there is a DIY on coding and changing the injectors, i think i have one posted on this forum too, im on my phone so i cant link you, but do a quick search and go check it liteterally takes u 10min tops..
06-17-2012, 12:45 PM | #8 | |
171
Rep 1,213
Didn't even consider that! Unfortunately I don't have the appropriate cable (or a PC besides my netbook) in order to test with INPA. I'll make sure my tech looks into it tuesday, though. Would be an easy solution!! Thanks
Retired: '18 6MT AW F30 340x Drive | '15 6MT F80 M3| '11 AW DCT E92 M3| '09 6MT AW E90 335i| 08' 6MT E92 328xi Last edited by ZTZ1010; 06-17-2012 at 12:52 PM.. |
06-17-2012, 01:21 PM | #9 |
76
Rep 1,883
LPFP?
Legal Disclaimer: Anything I or anyone else says about my vehicle on this website(e90post.com or any affiliated or nonaffiliated sites), pertaining to modifications, is only to gain acceptance from my/our peers, and does not actually represent anything actually existing on my car, and thus, cannot be held against me in any issues, i.e. warranty claims, that may arise.
06-17-2012, 01:22 PM | #10 |
171
Rep 1,213
never thrown a fuel related code... possible even withstanding that?
06-17-2012, 04:35 PM | #11 |
39
Rep 315
I have the same issue (misfire on cyl 3) and am running FBO+Meth, have done coils/injectors/plugs.
My next step is going to be valve cleaning. 38k km's on the odo. |
06-17-2012, 08:41 PM | #12 | |
171
Rep 1,213
yours as prominent/consistent?
06-18-2012, 01:43 AM | #13 |
39
Rep 315
Damn near every time I push it past 4500 rpm in 3rd/4th, or a long pull in 6th.
To the point now where I don't even let off when it's misfiring. Pulled on some subaru who thought he was hot stuff and blew past him while the engine was missing on cyl #3. I found it to be hilarious. I also ensured my injectors were properly coded today, and they are. I've switched away from Husky E10/94 Octane (run it in all of my other tuned cars) to Petrocan 91. Wasn't able to get a misfire on the way home, but I didn't bag it that hard. I'm also thinking that one of my widebands might be on the way out for bank1 (cyl 1,2,3) Robert at Vishnu thought it might be an issue when I sent him logs. So it's either going to be: I was running out of fuel (shouldn't be, because I only see misfires on ONE cyl) Valves are starting to gum up (plausible, maybe cyl 3 just has it worse due to head flow/design) o2 sensor (I don't know enough to understand why it would read cyl 3 rich/lean and not others) |
06-18-2012, 08:32 AM | #14 |
79
Rep 2,396
Drives: '08 E90 335i
I don't know if would be your o2 sensors cause wouldn't you be getting for the entire cylinder bank then (which would cause misfires on multiple cylinders, not just a specific one)?? My o2 sensors were backwards and it caused misfires on all the cylinders in the specific bank I was getting the error code for. The fuel quality also doesn't explain the misfires cause (once again), it would cause non-specific misfires -- Not like cylinder 3 gets shafted on the octane quality while everyone else (1,2,4,5 + 6) gets the good stuff.
Is it possible the Voltage/Knock sensors need to be replaced for that specific cylinder?? And because they're broken/not working, that the DME has restricted the activity of that specific cylinder as a preventative measure? |
06-18-2012, 09:53 AM | #16 |
313
Rep 3,262
Try a compression test...could be engine damage (piston rings, valves). There are some small cameras that can be introduced inside the cylinder through the sparkplug hole and you can then see the state of the piston/cylinder.
06-18-2012, 11:10 AM | #17 |
3441
Rep 79,211
With almost 40K on the clock it could be carbon build up.
Some guy just posted his car with 35K approx and they were gunked up pretty good. |
06-18-2012, 01:09 PM | #18 |
41
Rep 487
Make sure the injector has the decoupler on it. I had similar misfires and it ended up being all of the injectors were missing this piece. Also, if you have a tune, make sure it's connected properly. Seems I've read somewhere someone had a cyl 3 issue and it ended up being a defective tune. I recently had a carbon cleaning (82k mi) but never had misfires b/c it needed cleaning. The SES kept coming, don't remember what codes it was throwing, but pretty sure it didn't single out a cylinder.
06-18-2012, 03:04 PM | #19 |
103
Rep 1,520
06-18-2012, 04:45 PM | #21 | |
8
Rep 128
06-19-2012, 09:49 AM | #22 | |||||
171
Rep 1,213
Just to update, I dropped my car at the dealer this morning. Made a list of the suggestions and spoke to my tech about the possibilities. He's active on this forum (has a modded 1M) and had actually seen this post (i thought that was funny). Interestingly enough, after I cleared the codes last time, I checked this morning to see what else had come up. I ended up with full bank 1 misfires (cyls 1,2,3) which I had not seen before. I guess this is good as it gives me a few more options as far as diagnosis is concerned...
My syptoms are nearly identical. let me know if you figure out a solution. Quote:
Any other ideas?
