BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > Suspension | Brakes | Chassis > spacers with 162's and zsp
      06-17-2012, 01:39 AM   #1
nation
Drives: 335i
i know this has prob been brought up before but i seem to suck at searching.
im trying to figure out the ideal spacer size for stock wheels(162) with sport suspension. i was thinking 15rear/12front but im not sure. any help and pics would be awsome. there are alot of good deals to be had,but until im sure what size i didnt want to waste anyones time asking "how it looks"
      06-17-2012, 04:49 AM   #2
LT
Alderney
43
Drives: Black 07 e90
I have the same setup (162s with sport suspension) and would like to know the same thing. I've read a million threads and I'm still not 100% so I feel you on just asking the question. It's also worth mentioning that I'm pre-lci, which I guess has a few extra mm's that you can push the stock wheels out without issue (lci extended the rear track a few mm).
      06-17-2012, 05:57 AM   #3
cdgatti
cdgatti's Avatar
255
Drives: e90 328i
I think the change from pre-lci to lci was a 1" (25.4mm) wider track, so you could use 12mm just to get to lci, that's what I am thinking about doing anyway.
      06-17-2012, 11:33 AM   #4
VTECaddict
Where'd my VTEC go?
VTECaddict's Avatar
Drives: 06 330i 6MT
I have 12mm front and 20mm rear on KW V2. Front rubs the fender liner a little bit on hard dips, but nothing too serious.
Mods: BC BR coilovers | Blacklines | M-tech rear | dual exhaust | M3 steering wheel | BMW SSK | ZHP shift knob | High-kick CF spoiler | NBT Retrofit
M3 front control arms | M3 rear guide rods | Manzo rear toe and camber links | Monroe rear shock mounts | Varrstoen ES1 19x9.5+20 Front, 19x11+25 rear
      06-17-2012, 09:35 PM   #5
nation
Drives: 335i
any headon and side pics? its hard to find a full 360* shot.
      06-18-2012, 01:14 PM   #6
Justang
Justang's Avatar
Drives: 07 335i
I had the 12mm/15mm set up in my 162/ZSP. IMO it's the perfect match up. I had 20mm on the rear but it didn't look right. With the 12/15 I never rubbed under any circumstance. I have tons of pics, but I'm on my phone. I'll post tonight.
I also just upgraded wheels so my spacers are for sale if you are interested.
07 335i E90 JB ZSP | 260M's | Cobb AP | DCI |
      06-18-2012, 02:34 PM   #7
mave198
mave198's Avatar
11
Drives: 2007 BMW 335i
12mm up front 20 in the rear......
      06-19-2012, 07:46 PM   #8
nOshi
nOshi's Avatar
Drives: TiAg E90 335i
im pre lci and i wish i had a 20 instead of a 15 in the rear. at certain angles it looks sunken.
      06-20-2012, 01:38 AM   #9
Blue Streak
Gunny
Blue Streak's Avatar
Drives: '07 E90 335i 6MT, 2016 F10 535
2007 E90 335i  [9.00]
Same here. I have 12 front and 15 rear with the 162's, pre-lci e90. The fronts are almost flush while the rears are still not pushed out enough. It's still way better than stock though.
2007 E90 335i 6MT, ZSP, Nav, PDC, CA, Montego Blue, Terra Dakota leather, CDV, clutch-stop, E46 M Shift Knob, Logic HVI, JB4 PnP, MS 3" downpipes, Koni Yellow adjustable sport shocks, RE 12mm(f)/BMS 15mm(r) spacers, Blacklines, LUX 5.0 LED halo ring lights, DAEOS (Vista) harness, GP Thunder 7500k fogs, 35% sides-20% rear tint, matt black kidney grill, matt black 335i trunk badge
      06-22-2012, 02:56 AM   #10
Justang
Justang's Avatar
Drives: 07 335i
Here are some pics of my 12/15.
      06-22-2012, 03:37 PM   #11
JRob23
Drives: e92 m3
How much for the 12mm spacers? Drop me a pm Justang
'04 E46 M3 - Silver Grey - Sold
'09 E92 335 - Space Grey - Sold
'12 E92 M3 - Frozen Silver - Current
      06-22-2012, 03:49 PM   #12
JRob23
Drives: e92 m3
I'm also in the same predicament. E92 with oem 188wheels with h&r springs and it looks like I'll be going 12/15
      06-29-2012, 11:29 AM   #13
jakuum
Drives: SGM e92 335i M-sport
2011 BMW 335i  [0.00]
What tires are you guys running with your 162s? I have an e90 with 162s and Michelin PSS and from my measurements it looks like 20mm will rub, while 15 would be pushing it. The sunken look of my car is getting a bit tiring hehe.
      06-29-2012, 08:04 PM   #14
Pete Schweaty
Pete Schweaty's Avatar
39
Drives: 2014 750li
I have a 2007 e90 with zsp and 162's. I went with 10s and 18s. No rubbing and it's pretty flush. You would have no problems going up to 20 I the rear. The front is pretty wide from the factory so I wouldn't go with anything over 10. I have OEM Bridgestone run flat 225/40 18 up front and 255/35 18 in the rear.
      06-29-2012, 08:36 PM   #15
mave198
mave198's Avatar
11
20mm won't rub.
Do it.
      06-29-2012, 09:00 PM   #16
Pete Schweaty
39
Drives: 2014 750li
Originally Posted by mave198 View Post
20mm won't rub.
Do it.
+1. 20s won't rub.
      06-30-2012, 01:58 PM   #17
Moz_e90
7
Drives: 325 e90 Sparkling Graphite
Running 20m H&R in the rear on non-Sp 2/162s. Pre-lci. The 20mm's bolt on to the hub.
Looks just right imho. The rear fender gap is ridiculous on sedans.
Planning to add some KV1's in the next few months.
For those running 12's in the front, are these hub-centric? Any preferred brands? Tips on where to buy? I've been told this makes a big difference on turn in. Opinion?
      06-30-2012, 04:29 PM   #18
mave198
mave198's Avatar
11
Hub centric either from Turner or H&R.
Running H&R's up front. Think I bought them from Tire Rack, don't remember exactly......
      07-01-2012, 02:09 AM   #19
nation
Drives: 335i
so i got them installed,totally changed the way it looks. more planted comes to mind.
i may go 18mm in the rear to give it a more even look. the wheels will be coming off shortly. the stockers will be getting poweder coated in gunmetal.
      07-03-2012, 03:08 AM   #20
udm328i
57
Drives: e92
2008 BMW 328i  [9.00]
I measured from top edge of tire to fender and then converted inches to mm, I have 12mm on the rear, about .5''
ZSP/ZPP/BMW PE&PI/ BMW CF STRUT BRACE/ EIBACH PRO SYSTEM / H&R WHEEL SPACERS
      07-03-2012, 10:54 PM   #21
Tommy1025
Drives: '06 325i
Post some pics!. is it pricy to get them powder coated?
      07-06-2012, 09:53 PM   #22
jakuum
Bought some 12mm (front) and 18mm (rear) spacers from a fellow forum member here. Hopefully they'll work fine with my Michelin PSS/162s. Tire runs a bit wider from what I've read. I guess I'll find out next week!
