Ever wonder about the lean condition at boost onset?
06-16-2012, 05:23 PM | #1 | |||
70
Rep 2,197
Here's a bit of information I came across that's a really informative/interesting read.
Credit is due to dzenno Quote:
Here's what a pigyback tuner had to add. Quote:
06-16-2012, 05:25 PM | #2 |
84
Rep 949
The greatest part about the lean spool table is that certain tuning companies allow you to set the max rpm that table can be active if conditions are met or simply change the table to reflect the targets you would like for actual values being reported instead of fake ones.
06-16-2012, 05:48 PM | #3 |
52
Rep 1,357
Drives: '08 e92 335i COBB 4.01 Stage 1
Thanks for the info. It's always refreshing to have some technical information discussed in this section of the forum.
However, I have a feeling this thread will be closed soon so read it while you can. |
06-16-2012, 05:58 PM | #4 |
83
Rep 2,132
Drives: FBO+ N54xi
Thanks for the info, too bad alot of the tech guru guys were banned from here and its become alot more like which intake/fmic should i buy..
JB4+usb | P3 Vent Boost Gauge v2 | BMS OCC | BMS DCI | AMS FMIC | AR xi CL DP's | BT Tool | Edibias/NCSExpert/INPA BMW Coding | Cyba Quad Exhaust tips | M-Tech Rear & M3 Front Bumper | Red Cyba Air Scoops | Blacklines | Vinyl Overlays | ACS Roof Spoiler | Matte Black Grilles | LED Side Mirrors | Rear Euro Fogs | etc..
06-16-2012, 06:11 PM | #5 |
1737
Rep 17,960
Drives: A Lot
Garage List 2018 Ducati Panigal ... [0.00]
2016 Mazda CX5 [0.00] 2017 Aprilia Tuono ... [0.00] 2019 BMW M2 Competi ... [0.00] 2015 BMW M5 Competi ... [10.00] 2016 Ducati XDiavel S [0.00] 2016 AMG GT S [0.00] 2011 Ferrari 458 It ... [0.00] 2017 Charger Hellcat [0.00] 2015 KTM Super Duke ... [0.00] 2016 KTM RC390 [0.00] |
AFAIK, there is no "lean spool" feature active in the MSD80/81. At least not in the traditional sense. I believe what most people are seeing is the partial load/low RPM AFR targets (which are considerably leaner than high load/high RPM AFR target) and the time it takes for the closed loop fuel control system to reach them during a dynamic load swing.
FWIW, here is the AFR table in a stock DME: |
06-16-2012, 06:16 PM | #6 |
219
Rep 3,012
06-16-2012, 06:46 PM | #7 | |
70
Rep 2,197
It doesn't make a lot of since to me that it would go into a low load fuel table when it sees a high requested load and actual load ramping up. |
06-16-2012, 06:54 PM | #8 |
1737
Rep 17,960
Drives: A Lot
Not sure what user adjustable table you are referring to. Nor do I fully understand your second statement.
06-16-2012, 08:33 PM | #10 |
184
Rep 2,841
This is extremely interesting stuff.
I have noticed for quite some time that my timing will flatline post shift more readily the higher my open loop value is set to. I seem to be able to manipulate the timing drop by using a smaller value for the open loop user adjustable. This in turn makes my fuel trims rise higher......but this configuration seems to work better for me most of the time. Does anyone know if the open loop setting adjusts the fuel pressure or injector pulse cycles? |
06-16-2012, 08:58 PM | #11 | |
33
Rep 1,029
06-16-2012, 09:25 PM | #12 |
84
Rep 949
Shiv - just because you don't have everything unlocked or found doesnt mean it doesnt exist. This is why you have that spike. Here is a screen shot I took of that option for you. Sorry for blocking out all the other tables but its not my place to show more things you may have not been made aware of yet.
Disclaimer - I am not hating. Your single kit is great and you do tons for this community. The flash software you have is just a bit outdated as it was on display here years ago. Cobb has completely decompiled the DME - I know I'd love to see what you could do with a flash tune that was fully capable. You show that one table but I have more fuel tables than the fingers on my hand when making custom maps for my AP. Last edited by Jake@MOTIV; 06-16-2012 at 09:32 PM.. |
06-16-2012, 09:26 PM | #13 |
65
Rep 1,708
There's no leaner afr during spool... Dme just has leanish afr in low and mid range. You can confirm this by logging cobb map0 requested afr, fuel pressure and idc. It will be a smooth transition with potentially an addition fuel add table during spool. I could be wrong, but doubt it.
Ilma, piggies bias fuel pressure only. At first i thought this was only increased fuel pressure, but depending on your fuel correction, dme may not be able to reach target pressure so it compensates with ipw. This is a good subject. |
06-16-2012, 09:29 PM | #14 | |
84
Rep 949
06-16-2012, 09:34 PM | #16 |
84
Rep 949
I removed all values. I simply left the title of the table showing its there. You can also adjust the max RPM that spool mode is able to be used. So if you wanted it gone you could lower the RPM or simply copy your primary bank 1 / 2 fuel tables into the spool mode and youd could avoid it all together.
I really don't want to go into detail much on this publically. Arguing with Shiv is a bit tedious because he has a vast knowledge of a lot and is a salesman at the same time. I respect him twice over but its just something not worth my time because publically he will hold a position and the people who follow him will believe it. I am not saying he lies to people at all. Just internet arguements on here will not be something I feel like engaging in. I have fact and evidence as I have software in front of me with maps and tables. I really don't want to go into more detail on here. I just came in to provide a screen shot showing the table that does exactly what me and dzenan were talking about. Shiv may not have access to these parts of the dme with his flash software as its older and cobb has spent far more time than the creators of what he is using did, but it is there, and is the reason he has those lean spikes. It's programmed right in the factory table for that condition specifically - lean spool. |
06-16-2012, 09:40 PM | #17 | |
1737
Rep 17,960
Drives: A Lot
Also, the "age" of my tuning interface is a irrelevant. It is an open source ROM editor which requires a user defined XML file (one for each dme software version). It's a tool, not a fashion accessory. It's really not worth starting a debate on how the dme works on the Internet. I'd rather show what we can do with it on the dyno, street and track. |
06-16-2012, 09:51 PM | #18 |
65
Rep 1,708
I have logged many parameters on map0 and didnt see evidence of leaner targets during spool... Although i wasn't looking for this specifically. This is not the reason piggies show a leanish spike in the logs though as the OP stated.
06-16-2012, 09:51 PM | #19 |
84
Rep 949
The size of the table is irrelevant. They are all adjustable. That is just what the axis were set to. All of the tables can change resolution based on what the person who has the coding abilities wants it to look like. I can change the scaling and load values to represent different ranges etc. I am not trying to teach you anything or prove you wrong in anyway. Simply discussion. I know you are used to fighting with people on here and always having to go on the offensive or defensive but assure you I have no issue or case to prove. I was just providing information. Its obvious you know these things. Your table screen shot'ed above has the same axis as the one i screen shot'ed. Thats because its just the unscaled / unchanged table decompiled from the dme. That can change based on what is needed for what table for any one of thousands of reasons.
Anyways - I am passing out. I just wanted to reiterate im not trying to argue with you. I was just posting up something because earlier you said: AFAIK, there is no "lean spool" feature active in the MSD80/81. At least not in the traditional sense. I believe what most people are seeing is the partial load/low RPM AFR targets (which are considerably leaner than high load/high RPM AFR target) and the time it takes for the closed loop fuel control system to reach them during a dynamic load swing. FWIW, here is the AFR table in a stock DME: Anyways - I am looking forward to customer reviews of your single kit. It is a work of art and will be a lot of fun come fall when customers starting hitting the track with favorable DA's. I can't wait to see what poeple run. Congrats!! |
06-17-2012, 12:20 AM | #20 |
Rep 538
It's good to see that BMW is still using code features that are similar to the older Bosch code. The fuel tables posted above have a similar layout to the tables in my 1987 Porsche! Now I'm really curious to see a stock ROM!
BTW the table is labeled 'FUEL (SPOOL)'. It doesn't say it's 'lean spool' unless all of the values are lean? I'm not asking to see the table, I'll take your word for it if it's leaner than the stock fuel maps. |
06-17-2012, 06:47 AM | #21 | |
184
Rep 2,841
Seems that way I can strongly correlate that I get better post-shift timing recovery when fuel trim values are high, so maybe that causes the DME to use more IPW. If having a high OL value = higher fuel pressure, then my engine doesn't seem to like this as much as lower pressure and more IPW. |
06-17-2012, 11:43 AM | #22 | |
1737
Rep 17,960
Drives: A Lot
