Front Sway-bar Endlinks
06-16-2012, 04:50 PM | #1 |
68
Rep 961
I have a 2006 BMW 325i e90 lowered on Sonic Tuning S1 coilovers. My front Endlinks look a bit worn especially the bolts and one of the Endlinks the tread is stripped.
I would like to replace both Endlinks but do not want to buy sonic tuning. I see that HP autoworks and ground control makes Endlinks for the e90s. Does anyone have any experience with either brand? If so please share. |
06-16-2012, 05:41 PM | #2 |
1559
Rep 4,109
Drives: BMW M3
I have these:
http://store.vacmotorsports.com/powe...sets-p103.aspx They work perfectly. I have taken my car with them installed to the track several times. You should have adjustable end-links anyway since you're lowered. The sway bar isn't going to be in the right position otherwise; when you lower the car, you're altering the suspension geometry.
2024 BMW M3 Sedan Frozen Pure Grey II/Fjord Blue, 6MT
Past: 2021 Z4 M40i Frozen Grey II/Black Alcantara | 2017 F30 340i Mineral Gray/Coral Red, 6MT | 2011 E92 335i Le Mans Blue/Black, 6MT |
06-19-2012, 09:55 AM | #3 | |
102
Rep 1,903
Drives: e92 335i 6MT
It's neat that the GT500 uses the same end links! |
06-20-2012, 11:46 AM | #4 | |
197
Rep 2,163
06-21-2012, 09:12 PM | #5 |
109
Rep 1,948
I have the ground control front and rear end links plus I replaced my velocity toe links with the ground control ones. Very nice set. Tightened up the suspension feel!
06-22-2012, 10:19 AM | #6 |
40
Rep 818
Meyle has HD sway bar end links, front and rear:
http://www.e90post.com/forums/showthread.php?t=670343 |
06-23-2012, 11:00 AM | #7 | |
146
Rep 1,160
Have Ground Control end links, front M3 sway & M3 arms. They said something about stock end links not fitting. Oddly, stock links looked fine on comparison, but Ground Control fit & worked without a hitch. Rear end links stock w/M3 sway & M3 arms, work fine, no problem. Little off topic, I installed HP Autowerks' rear toe links - excellent. |
