Clouds of Smoke..
06-16-2012, 03:48 PM | #1 |
11
Rep 64
Clouds of Smoke..
hello guys. i'm getting really bad white smoke coming out of my exhaust at times and its becoming really annoying. it only happens when car is warm at operating temperature-never at start up and it only happens at idle or very low speeds, never at cruising speeds.
i've read a couple of threads and i figured it could be the turbos going bad or engine is just burning oil. i have already installed the bms occ in hopes that it would fix the problem but it has been almost a month and not a drop of oil has been caught. i'm starting to think it might be the broken pcv and then if the pcv isn't working then where would the blow by gas be going? what do you guys suggest i do next? i heard about the rb pcv upgrades but i can't find any links for the info or how to purchase. thanks, eric |
06-16-2012, 05:04 PM | #2 |
83
Rep 2,132
Drives: FBO+ N54xi
I have the same thing going and will go to a shop on tuesday to see what they find, but as for Robs pcv just go to n54tech(.)com and youll find the info there.. Please keep thread updated if you find whats happening..
JB4+usb | P3 Vent Boost Gauge v2 | BMS OCC | BMS DCI | AMS FMIC | AR xi CL DP's | BT Tool | Edibias/NCSExpert/INPA BMW Coding | Cyba Quad Exhaust tips | M-Tech Rear & M3 Front Bumper | Red Cyba Air Scoops | Blacklines | Vinyl Overlays | ACS Roof Spoiler | Matte Black Grilles | LED Side Mirrors | Rear Euro Fogs | etc..
06-17-2012, 12:14 PM | #4 | |
11
Rep 64
eric |
06-17-2012, 12:16 PM | #5 |
11
Rep 64
06-17-2012, 01:00 PM | #6 |
vroom
61
Rep 1,022
Drives: Grocery Getter
Garage List 2023 G80 M3 Comp [0.00]
2020 F82 M4 [0.00] 2018 BMW 440i [0.00] 2015 BMW 328i [0.00] 2007 335i e92 [10.00] |
Valve cover gasket is probably leaking.
That was the problem with mine. ~$800 fix (I think, mine was covered) G'luck, OP.
Before I used to go fast, now I just pick up the kids and pick up groceries.
06-17-2012, 02:03 PM | #8 |
11
Rep 64
06-17-2012, 02:07 PM | #9 |
11
Rep 64
06-17-2012, 02:39 PM | #10 | |
21
Rep 549
Hard to describe by smell, but white exhausts would be water getting in the mix somewhere. Is it like a cloud or just puffs of smoke? Do you drive your car for longer stretches, like more than 100 miles in one trip? |
06-17-2012, 03:01 PM | #11 | |
11
Rep 64
What can I do to confirm that it is indeed water? Thanks, Eric |
06-18-2012, 12:41 AM | #12 |
vroom
61
Rep 1,022
Yessir. Car would start fine...as soon as I got onto the fwy (about 2 minute drive from the office) and sat in traffic, that's when it would start.
06-18-2012, 02:26 AM | #13 |
21
Rep 549
Clouds of smoke wouldn't be condensation from many short trips, especially if you get it in summer time.
If it's the valve cover gasket, I'd be surprised to see white smoke, but hey anything is possible. |
06-18-2012, 03:34 AM | #14 | |
40
Rep 623
but back on topic, if its thick white smoke its your seals. Depending on what kind of relationship you have with whatever BMW dealership you take it to, you might be able to get new turbo's. I think BMW made it some kind of bulletin until 80K miles, if im not mistaken. And honestly if your looking to upgrade turbos I would only do Rb's. I love mine unconditionally and the car is still "drivable" so to say... I know the ASR's arent to cool. Had a friend get the ASR's on and had bad fitment issues and the car just doesnt feel like a car with RB's for some reason... Personally if you want to drive the car (not have it sitting at the shop because somethings wrong with it) and maintain that reliability and driveability then the RB's are the way to go. trust me my friend you wont be dissapointed. but if your tight on cash, then try the BMW bulletin thing... it might only be for wastegate rattle....im not sure...but you should def look into that because I know they (BMWNA) can replace turbos now if you have the right advisor and the turbos are really bad with less than whatever miles they set it at..They made it kinda like the HPFP recall thing or something similar.
[SIZE="2"]Crimson Red E92 335i M-sport 6-speed with MHD custom stage 2+ flash only , 40% E85/93 mix,+ HRE P40S wheels, KW Clubsport, M3 sways,+BMW performance CF Mirrors, BMW Performance CF deck lid spoiler,+ CF interior trim, p3 vent boost gauge,+ LUX angel eyes (11.73@124mph on street tires)
06-18-2012, 10:42 AM | #16 |
153
Rep 3,730
Mine did the same thing on "shorter" trips when the car was at operating temps. After my RB turbo install, the problem seemed to fix itself Gonna have to say either your valve cover gasket (as mentioned) or turbo bearing seal. It's easy to tell which if you have divorced exhaust pipes.
2008 BMW 335i e90 - Sold - Rob Beck Turbos / PROcede V5 / Aquamist HFS-4 / AR Downpipes / AE Exhaust / ER Comp FMIC / ER CP / TiAL BOV / Custom Intake / RPI Scoops / Quaife LSD / Swift-Koni Coilovers / DSS HS / Morr VS8.2 Sig Black / Michelin PSS / P3 Boost Guage / M3 body / M3 steering wheel / Adam's Rotors / Hawk HPS / SS lines /
06-20-2012, 05:37 PM | #17 |
25
Rep 152
06-20-2012, 06:10 PM | #18 | |
83
Rep 2,132
Drives: FBO+ N54xi
06-20-2012, 06:48 PM | #19 | |
25
Rep 152
06-20-2012, 07:13 PM | #20 |
Big Boost Addict
52
Rep 689
So how long have you had the OCC on the car without catching any oil? If you have been over 3k miles with the OCC installed and have not caught ANY oil then there is something wrong with your PCV system. I remember even with the poorly designed Riss Racing OCC that I had before the BMS one I still caught plenty of oil, enough to empty it every 3-5k miles.
So yeah if that is the case I would suggest replacing the PCV valve with the upgraded Rob PCV and see if you start catching that oil. If your PCV valve is broken you would be letting boosted air into the crankcase which is not good for the engine or valve cover gasket. |
