Anyway to fix this Hamann REP lip?
06-16-2012, 06:01 AM | #1 |
169
Rep 1,247
I bought this a few weeks back new. Its been on the car about 2weeks and its cracked already. And not from me hitting anything. It just seemed to have cracked and its getting worse. WHat can I do? Ill attach a few pics.
2009 E92 BMW M3.
06-16-2012, 06:05 AM | #2 |
Cisco661
61
Rep 974
Drives: 2006 Monaco Blue 330I
is it carbon fiber or fiberglass?
2006 330i/ Monaco Blue/ ZSP/ ZPP/ I Drive/ Burl Walnut Trim/ Steptronic/ Xenon Adaptives/ Logic7/ CF Mirror Caps/ Matte Black Grills
06-16-2012, 06:24 AM | #3 |
169
Rep 1,247
I believe its fiber glass and was painted already when I bought it in gloss black.. Fixable? Kind of bothers me it was brand new and on the car about 2 weeks.
2009 E92 BMW M3.
06-16-2012, 06:25 AM | #4 |
40
Rep 2,431
That's a simple repair but will require a paint touchup or entire respray. If you can get to the back of where the crack is, just lay down some reinforcing fiber glass. Then sand down the crack area and give it a coat of filler. Sand smooth and respray. It'll be good as new and you'll never know it was cracked.
My speeding isn't the problem. It's the Slow Folks ahead of me that cause accidents!
06-16-2012, 06:29 AM | #5 | |
Cisco661
61
Rep 974
i would recommend buying abs plastic one or CF. fiberglass breaks and cracks really easy. good luck
06-16-2012, 06:47 AM | #6 | |
169
Rep 1,247
2009 E92 BMW M3.
06-16-2012, 06:53 AM | #7 |
169
Rep 1,247
Do you think it would make it a bit more durable if I was to have it wrapped in Vinyl? Maybe that would help?
2009 E92 BMW M3.
06-16-2012, 06:57 AM | #8 |
Cisco661
61
Rep 974
no. the vinyl will probably tear or just crease. not sure but maybe if you go to an auto parts store and buy some two part epoxy for fiber glass and try to get some on the inside and outside. then just sand, prep, and paint or vinyl. it should work but see if you can get some more advice first. good luck.
06-16-2012, 10:37 AM | #9 |
40
Rep 2,431
If the crack is just from hitting the ground with the lip, then you could just sand it down, fill and sand it smooth and respray. There's no real stress area that needs reinforcing so opening the back wouldn't be necessary. More work than it's worth and would only weaken the lip. Just do a cosmetic touchup and see how it holds up. I would think it would be just fine that way.
If when you sand down the crack, you get through the front lip material, you would then need to fiberglass it from the front, sand the glass smooth, fill sand smooth and respray. I doubt you'd need to do all that, but just in case be prepared to do a more in depth repair. But I think you'll be fine with a cosmetic touchup.
