after install Procede problem on my 335is
06-15-2012, 10:44 PM | #1 |
yasmin3
18
Rep 112
Hey guys, My buddy and i just installed my procede 2.5 se in my 2011 335iS with DCT transmission. He has installed and removed procedes at least 7 times so everything was easy. everything turned on and no codes were thrown right after installation. once everything was back in the car i tried to run it on Map 1 and as soon as i got to around 3K to 4K RPM my car bogged down and threw a code for the transmission (the car told me to drive in reduced speeds and go to the dealer for service) . so i turned off my car and did the clear and started again. In this next go round I put my car on manual mode with sport button on and it did the same thing (ie. it started hesitating around 3-4K RPM and the car went on neutral) At this time it threw a couple of codes for the DTC and transmission. I tried to do this with full auto and all the other combinations i can think of with the DCT. I then tried it on Map 0= stock. everything was fine (thank God). I tried it with the valet mode and that was fine as well. I think it is just the maps with the aggressive settings that is messing up. I would love to find a solution for this before i try and return it. Your help would be appreciated. T
Current: 2017 M3 competition Pack.
Old: 2015 Audi S4 2011 335is 2009 Honda S2000 2008 328i 2007 Honda S2000 |
06-15-2012, 10:57 PM | #3 |
yasmin3
18
Rep 112
@ Focus this will be my second to the last resort but when i ordered i told them what car and in the packaging it specifically said it was for a 335is DCT. I hope Shiv or Robert chimes in
@PR3 im not going to have that arguement here but thanks.
06-15-2012, 11:08 PM | #4 |
COBB'ed
65
Rep 2,228
I'm no DCT expert here, but I'm pretty sure the DCT computer senses excessive torque figures, therefore I throws the transmission into limp mode trying to protect itself.
13 Mini Cooper S 08 E92 335i (SOLD) |
06-15-2012, 11:17 PM | #5 | |
1737
Rep 17,960
Drives: A Lot
Garage List 2018 Ducati Panigal ... [0.00]
2016 Mazda CX5 [0.00] 2017 Aprilia Tuono ... [0.00] 2019 BMW M2 Competi ... [0.00] 2015 BMW M5 Competi ... [10.00] 2016 Ducati XDiavel S [0.00] 2016 AMG GT S [0.00] 2011 Ferrari 458 It ... [0.00] 2017 Charger Hellcat [0.00] 2015 KTM Super Duke ... [0.00] 2016 KTM RC390 [0.00] |
06-15-2012, 11:25 PM | #6 |
Some say...
239
Rep 4,296
Drives: Fresh
Def seems like its the wrong map, just reload it and try it again.
I have exhaust and an intake... |
06-15-2012, 11:33 PM | #7 |
yasmin3
18
Rep 112
i think so too but if it is then what fix can be done?
06-15-2012, 11:34 PM | #8 |
1737
Rep 17,960
Drives: A Lot
06-15-2012, 11:58 PM | #9 |
394
Rep 3,161
If you need help reloading the map and firmware, im in san pedro and can help you reload both.
2015 M3 BPM Tuned, Eibach, Magnaflow and more www.tmrmzine.com/m3/f80
SOLD E92 Slēk Carbon Fiber Widebody M3 www.tmrmzine.com/m3/slek/ SOLD E92 335i Stage 3+ with all the toys www.tmrmzine.com/335/ SOLD E39 M5 Modded, What a great car! www.tmrmzine.com/m5/ |
06-16-2012, 12:00 AM | #10 |
yasmin3
18
Rep 112
Shiv, thanks for chiming in. As i said on my original post. i did try it on Map 0 and everything seemed to be ok. Everything seemed to work 100% normal but when i switched it to Map 1 or 2 it hesitates and a code would show and the car would go to Neutral.
How do i load the correct maps and firmware for the 335is DCT. Also, as i was installing it i didn't see a serial port instead i saw something that looked like a 5 to 7 pin plastic connector. is that what is supposed to be there?
06-16-2012, 12:08 AM | #11 |
yasmin3
18
Rep 112
TMR i just may take you up on this if i don't figure it out.
How do i download the firmware and maps?
06-16-2012, 12:22 AM | #13 |
29
Rep 968
Drives: 2007 335i Coupe
I had the same issue with my Brothers 335i procede rev2.5 SE. The fix was to press the male power spade and female connectors together tighter. It was a power issue because the connector was not pressed together completely because we were worried that we would break it. Threw a transmission, DTC limp mode. Hope that helps.
06-16-2012, 12:32 AM | #14 | |
yasmin3
18
Rep 112
06-16-2012, 12:47 AM | #15 |
394
Rep 3,161
I'll be in west covina area most of the day tomorrow. If you need help, i can check the wiring and can reload the software for you. I also have an extra PNP harness kit in case something is wrong with your harness.
06-16-2012, 09:31 PM | #16 | |
yasmin3
18
Rep 112
06-17-2012, 06:49 PM | #17 |
Some dude
92
Rep 1,780
That IS a serial port, not a USB. You need a USB to serial adapter, available from Radio Shack or other electronics store.
Did you perform the adaptation resets in Command Center mode 3?
RRT
E92 335i/6MT with stuff and things |
06-18-2012, 01:10 AM | #18 |
yasmin3
18
Rep 112
I had some help with TMR and he uploaded the right firmware and maps. But Shiv just agreed to help me out with something. I just hope it works out better than my current situation.
Props to TMR though for helping me out and getting my procede to work. I just got to say that i learned a lot from him.
01-13-2013, 08:11 PM | #19 |
Rep 59
Hey Tagon, when you updated your maps even though the ones that were indicated as Installed were correct, did it fix your problems? I'm having the exact same issues your stated and already tried making sure the power spade was pushed as tight as it will go.
