pissed n confussed at the dyno
06-14-2012, 10:01 PM | #1 |
10
Rep 139
so i went and got the car dyno today on a mustang dyno. i did logs while he was doing a couple runs. but he was having trouble with running it in 3rd gear cus its auto and it would automatically downshift to 2nd gear, so he had to run it at a higher rpm in 3rd and and above 40mph. well after all said and done i was not impressed with the numbers. he blamed it on the dyno cus of my car being auto or the dyno reads alot less..but either way the readings are 279hp, 314tq. Which i don't think is right? car feels and seems alot faster then that. especially with what i raced. can i get your input on this..it has me frustrated and confused
2011 N55 335xi - Jb4 - bms intake - ER charge pipe - cpe 5" downpipe - bms meth trunk kit - aa fmic - ER carbon fiber shroud - 60 scale/60 additive - 93 octane - 328awhp/395tq on mustang dyno
06-14-2012, 11:15 PM | #4 |
98
Rep 1,647
+1, although those numbers seem about rigbt for your mods/mustang dyno.
Current: 2021 X3MC
Past: 2013 bmw 335i, 2011 bmw 335i coupe, 2016 bmw m3 |
06-15-2012, 03:10 AM | #5 |
734
Rep 4,635
i thought you were supposed to dyno in 4th?
Follow my BMW instagram @CARMODIFICATION Let me know you are from bimmerpost and i'll follow back
06-15-2012, 06:05 AM | #6 | |
Joint Chiefs of Staff
4920
Rep 115,999
Mike |
06-15-2012, 09:44 AM | #7 |
65
Rep 1,274
My numbers were 280 whp and 380 torque... I need to log a few runs.
2011 e90 KW V1, JB4, BMS Dp, BMS Intake, CP, Alpina Flash, ISO, E85
Coming soon to the garage: 2014 M3 Maybe M5 |
06-15-2012, 01:01 PM | #9 |
10
Rep 139
So how do I go about testing the Wastegate or boost leak. I went through everything and I'm so frustrated ...errrr!!!
06-15-2012, 01:07 PM | #10 |
10
Rep 139
What's weird is that when I'm on the streets. My boost hits 14 but never hit 17 yet. It was hot yesterday about 87 degrees. Just wonder how I would be having a leak already. Maybe I should put the stock cp on n see if it's the new cp I got leaking???
06-15-2012, 01:12 PM | #11 | |
98
Rep 1,647
Current: 2021 X3MC
06-15-2012, 01:17 PM | #12 |
10
Rep 139
On the st. Map 2 jb4 and I hit 10-14. But I tried map 7 and it's only 14. Both maps never go above 14 even with 100 octane.
06-15-2012, 01:19 PM | #13 |
98
Rep 1,647
Was it with full 100 octane ? Map 7 should be hitting 16+.
Current: 2021 X3MC
06-15-2012, 01:23 PM | #14 |
10
Rep 139
20% 93 but I've been running it awhile to get the 100 in the motor
06-15-2012, 01:25 PM | #15 |
10
Rep 139
Any ideas on what to do to fix or figure out my problem. Sucks spending this money and it's not running full potential ???
06-15-2012, 01:31 PM | #16 | |
98
Rep 1,647
Current: 2021 X3MC
06-15-2012, 01:44 PM | #17 |
98
Rep 1,647
also you were suppose to dyno on 4th and i have a feeling the guy who was dynoing your car hit the kickdown button like someone above me said..
Current: 2021 X3MC
06-15-2012, 01:55 PM | #18 |
Sameet
740
Rep 2,541
Drives: AY/B M4 '15
Agreed with everything said above.. 4th gear pulls without hitting that damn kickdown button. And definitely a boost leak judging by the logs.
06-15-2012, 02:31 PM | #19 |
10
Rep 139
Guess imma have my buddy at BMW do a smoke test for me n see where it's coming from. But meanwhile I might throw on the factory cp n see if that's the problem. Cus when I put the new one on I forgot to put the big o ring gasket to the throttle body on. And I was only boosting 8-9. But after I fixed that it now boost 10-14. On map 2. But I still feel like the new cp isn't fully fitted even tho I adjusted and readjusted. Is there another o ring gasket to the inter cooler pipping?
