BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Powertrain and Drivetrain Discussions > N54 Turbo Engine / Drivetrain / Exhaust Modifications - 335i > Perfect Procede Log - FBO 16psi = Can i get more power?
      06-14-2012, 01:02 PM   #1
Spoolin335
Justin Herass
Spoolin335's Avatar
333
Drives: X6M / M3
2015 BMW M3  [0.00]
2012 Audi TTRS  [10.00]
2012 BMW X6M  [9.00]
2007 BMW 335i  [9.00]
Did a log recently, everything looks to be running great at 16psi, 100%IC, & 91 oct.
No meth, or race gas.
Can i tweak my setting for a little more power or let it run steady at this?
Seems ~16psi is the norm for FBO.
      06-14-2012, 01:04 PM   #2
themyst
themyst's Avatar
South Korea
177
Drives: '16 MK7 GTI
That isnt a perfect log. Observe timing after the shift.
E90 LCI N54 6AT
      06-14-2012, 01:06 PM   #3
Spoolin335
Justin Herass
Spoolin335's Avatar
333
Drives: X6M / M3
2015 BMW M3  [0.00]
2012 BMW X6M  [9.00]
That was just a quick blip of the throttle just to shift, i am assuming if i kept going mach 10 my timing curve would smooth out and trend up slightly as expected.
The main log(3rd gear) trend looks good with the exception of a slight hiccup in the AFR at the onset of boost. From my understanding this is normal and has happened across almost all my logs.
      06-14-2012, 01:11 PM   #4
themyst
themyst's Avatar
South Korea
177
Drives: '16 MK7 GTI
Your AFR looks as good as it can. I'd go 3-4 shift and hold out 4th gear for say 1000 rpms to see how timing reacts after the shift.
E90 LCI N54 6AT
      06-14-2012, 01:11 PM   #5
jpsimon
Team Zissou
jpsimon's Avatar
Drives: 2022 AWD M3 Comp - SMB
you could always drop IC some and re-log. Here is a 93 octane log with IC set at 20 from the other day for me. Was running lower boost to test something but you might as well give it a whirl
      06-14-2012, 01:18 PM   #6
Spoolin335
Justin Herass
Spoolin335's Avatar
333
Drives: X6M / M3
2015 BMW M3  [0.00]
2012 BMW X6M  [9.00]
Ok will do.
jpsimon not sure why you are losing so much boost in your shifts. I was not shifting fast at all and i still didnt lose as much as you.
Thanks guys.
      06-14-2012, 01:21 PM   #7
George@V
21
Drives: 2012 335is
Why don't any of these logs have the ability to have RPM on the x-axis instead of its own graph? That would be more valuable to me.
      06-14-2012, 01:21 PM   #8
jpsimon
Team Zissou
jpsimon's Avatar
I was being very lazy with the shifting, that isn't normal for me. I was just posting it so you could see you can probably run a bit more aggressive timing
      06-14-2012, 01:29 PM   #9
rader1
70
Drives: Cobb Stage 2+ 135i
It's the just the program used to view the data, its in CSV format so you could use excel or VD to graph it if desired.
I completely agree with you, I prefer to have everything on one graph. Not only that but the scaling is ridiculous lol I guess it does smooth things out and make it look better.
      06-14-2012, 01:29 PM   #10
jpsimon
Team Zissou
jpsimon's Avatar
Who cares? you can see the values at any point or adjust the scaling however you see fit. not a big deal
It doesn't matter how "smooth" or not it may "seem" as long as you know what you're looking for in your own log.
      06-14-2012, 01:34 PM   #11
Spoolin335
Justin Herass
Spoolin335's Avatar
333
Drives: X6M / M3
2015 BMW M3  [0.00]
2012 BMW X6M  [9.00]
You can zoom in/out on any point in the graph.
I hate looking at a JB4 log, it looks like scribble, i much prefer the Procede style of logs.
      06-14-2012, 01:35 PM   #12
George@V
21
Drives: 2012 335is
If you're doing a log for something specific you know what you're looking for, doesn't matter how "smooth" or not it may "seem".
Well I do care since I don't have a piggyback at this time, and curious to learn more about their logging capabilities, etc. However, if you are saying that you can adjust the scaling and pinpoint to a certain RPM (or a range) and see the actual variable's data point as plotted on the graph, then you are correct, it's not a big deal.
      06-14-2012, 01:36 PM   #13
jpsimon
Team Zissou
jpsimon's Avatar
It's infinitely easier on the eyes to read procede logs separated out in my opinion. I'd much rather be looking at these than everything on one
      06-14-2012, 01:43 PM   #14
jpsimon
Team Zissou
jpsimon's Avatar
gotcha. Yeah you can zoom in as far as you'd like - and anywhere you click you see that point's values on the left hand side there (for every row). And you can adjust the scaling for each channel
      06-14-2012, 01:44 PM   #15
rader1
70
That's 100% true. A crappy log is crappy and a good log is good regardless of how its presented.
      06-14-2012, 02:17 PM   #16
AU335i
AU335i's Avatar
78
Drives: 2008 335i E92
OP, what maps are you running?
      06-14-2012, 02:19 PM   #17
Spoolin335
Justin Herass
Spoolin335's Avatar
333
Drives: X6M / M3
2015 BMW M3  [0.00]
2012 BMW X6M  [9.00]
12-17 V5 maps.
I only have a rev2.
      06-14-2012, 02:21 PM   #18
Jeff@TopGearSolutions
Jeff@TopGearSolutions's Avatar
Try small increments of IC dropping. Maybe log IC 80 and go from there. You may want to upgrade to a rev 2.5 its a fairly inexpensive upgrade and give you access to the aggressive maps it also has better fueling capacity.
      06-14-2012, 03:14 PM   #19
335okc
335okc's Avatar
42
Drives: e90 335
damn that is rich, and your fuel trim is far from maxed out. i guess lower boost enables you to be that rich?
      06-14-2012, 03:19 PM   #20
AU335i
AU335i's Avatar
78
jpsimon's log doesn't look that rich to me at all?
