Coby Wheel
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Powertrain and Drivetrain Discussions > N54 Turbo Engine / Drivetrain / Exhaust Modifications - 335i > Unstable idle and cutting out at low rpms ?
      06-14-2012, 12:34 PM   #1
Slidewayz
Slidewayz's Avatar
33
Drives: 2007 335i
Question Unstable idle and cutting out at low rpms ?
I'm kind of stumped on this one...hope someone can help !
It starts up fine (no long crank) but then the idle drops intermittently and when I'm driving, especially at low RPMs, the car 'stutters' / loses power. After the car is warmed up and at higher RPMs it is not so noticeable.
This started after I filled up my car but the overflow shutoff on the pump didn't work. I was on the other side of the car checking the tires so gasoline spewed out for about 5 seconds...correlation is not causation, but still...
Any thoughts on what the problem might be or how to diagnose ?
Thanks !!!
      06-14-2012, 01:33 PM   #2
Turb0Surge
Turb0Surge's Avatar
Drives: BLACK e90 335i
From the sound of it looks like A. You either have a bad fuel pump. B. Spark plugs. Or C. Coil packs.
Start with the spark plugs, they're the least expensive.
      06-14-2012, 02:01 PM   #3
Slidewayz
Slidewayz's Avatar
33
Drives: 2007 335i
Thanks. The spark plugs have <5k miles on them, so that's probably not it. It's not throwing any codes, so can that be the coil packs or fuel pump.
What is the best way to figure out which it is so I don't waste $$$ ???
thanks !!!
      06-14-2012, 02:14 PM   #4
Turb0Surge
Turb0Surge's Avatar
Did you use OEM bosch spark plugs?
You can test the coil packs by turning on the engine and taking them off one by one. If the engine starts sputtering even worse then that pack is good. If you take one out and nothing changes then that coil pack is bad.
Fuel pump would be hard to test, because if the fuel pump is completely shot, the car won't start. But it could be starting to go out, in which case the fuel would not be getting to the injectors as it should be and that could be where the sputtering is coming from.
      06-14-2012, 02:28 PM   #5
happy4nk8er
Drives: 335i E92
Might have something to do with fuel in the emission system loop. The system knows when we have not put the gas cap back on tight enough, so maybe fluid has gotten in the the emission vacuum system. Any codes?
      06-14-2012, 04:13 PM   #6
Slidewayz
Slidewayz's Avatar
33
Drives: 2007 335i
No codes.
      06-14-2012, 04:17 PM   #7
hemi to e90
dat boost doe
hemi to e90's Avatar
Poland
238
Drives: 10 335i 21 740li
u have downipipes? when did you put them in?
      06-14-2012, 04:44 PM   #8
Slidewayz
Slidewayz's Avatar
33
Drives: 2007 335i
Have DPs, DCI, Helix IC, and proCede 2.5.
Everything has been in the car for 20k+ miles and no new map or firmware has been flashed in 1+ months.
      06-14-2012, 04:48 PM   #9
Dr_Dirt
Dr_Dirt's Avatar
Drives: E90 335i 6AT
Take out the procede and test again, maybe you got a loose wire in the harness.
      06-14-2012, 04:55 PM   #10
RaddM4
Drives: 2015 F82 & 991 GT3
I just had the same problem. My plugs, coils, and high pressure fuel pump are brand new. Mine was the low pressure fuel pump.
      06-14-2012, 05:01 PM   #11
Slidewayz
Slidewayz's Avatar
33
Drives: 2007 335i
Did you get any codes ?
      06-14-2012, 05:18 PM   #12
themyst
themyst's Avatar
South Korea
177
Drives: '16 MK7 GTI
Dumb question, are you using E85?
E90 LCI N54 6AT
      06-14-2012, 05:34 PM   #13
Slidewayz
Slidewayz's Avatar
33
Drives: 2007 335i
No.
      06-14-2012, 05:42 PM   #14
hemi to e90
dat boost doe
Poland
238
now I'm curious why u asked?
      06-14-2012, 06:04 PM   #15
Joshboody
65
Drives: pickemuptruck
evap charcoal thingy got fuel in it.
      06-14-2012, 06:04 PM   #16
themyst
themyst's Avatar
South Korea
177
Drives: '16 MK7 GTI
When you run E85, some cars will have an inconsistent idle which goes away after warming up or driving WOT.
His issue sounded like he was trying E85. Since that's not the case, it's plugs, coils, or intake valve gunking. If you have cold start misfires, injectors.
E90 LCI N54 6AT
      06-14-2012, 07:07 PM   #17
zztwinturbozz
zztwinturbozz's Avatar
Drives: 335i xdrive
Injectors? Maybe clogged up intake valves? Try dumping a bottle of seafoam in the tank and floor it around for a while.
      06-14-2012, 07:19 PM   #18
MilehighM3
MilehighM3's Avatar
Drives: Harrop E90 M3
2009 E90 M3  [6.50]
If it happens after refueling, it's probably your fuel tank valve valve/purge valve sticking open. Allowing fuel and or fuel vapor into the intake when it shouldn't. Also explains why the pump didn't shut off at the gas station, no back pressure build up in the filler neck as a result.
      06-14-2012, 07:35 PM   #19
happy4nk8er
Drives: 335i E92
What he said sounds pretty damn convincing. That might have allowed fuel to get into your carbon emission can( as someone else mentioned) or cans I think there might be 2.
      06-15-2012, 08:00 PM   #20
Slidewayz
Slidewayz's Avatar
33
Drives: 2007 335i
That was it !
Thanks !
      12-17-2012, 03:26 PM   #21
mannytabloid
757
mannytabloid's Avatar
Drives: 2007 335i E92
Hey, sorry to revive a dead thread. The exact same thing happened to me. Does anyone have a part # or more details on what I need fixing?
2007 335i E92
Sapphire Black, Saddle Brown, Sport, Premium, Cold Weather, OEM Rear Spoiler, M3 Strut Brace, Meyle HD Tie-Rods, M3 Front Control Arms - Upper and Lower, M-Tech Rear Bumper, Painted Side Reflectors, Alpine HID 5300k Angel Eyes
      12-17-2012, 05:04 PM   #22
TenshiWingusu
TenshiWingusu's Avatar
Drives: '07 335xi
16137163596 Probably the part number
http://realoem.com/bmw/ to find part numbers
then
http://getbmwparts.com/ to buy them
http://www.e90post.com/forums/image.php?type=sigpic&userid=167262&dateline=13416  03411
Vishnu PROcede 2.5SE, BMS DCI, Evolution Racewerk Charge Pipe, HKS SSQV4
