Short in Aux-In USB Connector
06-14-2012, 07:54 AM | #1 |
9
Rep 562
I did some searching, but couldn't exactly find what I was looking for. Basically, my aux in connector is shorting out, making it so that one side of my speakers doesn't work. I can prompt it by wiggling the aux in plug. I've done some research, and it looks like part # 61319129652 will fix my problem. What I'm really looking for are some installation tips, as far as how to replace this. I've read some posts about going in through the rear AC vents - is this the best way? Is there any way to access the above part from the center console itself?
Thanks for the help.
ZPP / ZSP / Navi
06-14-2012, 10:03 AM | #2 |
338
Rep 842
The part clips in from the center console but you'll have to open up the back (air vents) to access the clips to release it. Youll need to pull the duct out to gain room. Once the clips are released it pull it into the center console and you should get just enough slack in the cables to release their clips.
Plug cables into new part and pop it back down into the slot. Close vents and done.
2021 G05 X5 ///M50i / Phytonic Blue / Cognac Vernasca
iStep 03/2023.50 |
06-14-2012, 10:59 AM | #3 | |
9
Rep 562
ZPP / ZSP / Navi
06-14-2012, 11:09 AM | #4 | |
338
Rep 842
BTW, do you have just the Aux or do you have the Aux / USB connection? The part # for the Aux / USB is 84109237653.
iStep 03/2023.50 |
06-14-2012, 02:56 PM | #5 | |
9
Rep 562
ZPP / ZSP / Navi
06-14-2012, 03:41 PM | #6 |
338
Rep 842
BTW, I replaced mine because it kept randomly dropping my iPod connection. I would have to unplug and replug the USB to get it working
iStep 03/2023.50 |
06-15-2012, 08:05 AM | #7 |
9
Rep 562
Yeah, I'm going to ask my dealer since I have CPO, but I'm guessing it won't be covered based on the terms. Since the part is only ~40 bucks I'm not too worried about it, though. Just didn't want to bash up my console not knowing what I was doing.
ZPP / ZSP / Navi
06-15-2012, 11:34 AM | #8 |
338
Rep 842
I'm still under warranty but I didn't want to bother trying to get them to acknowledge and fix the issue since it was intermittent. It's been fine since though I relocated mine loosely under the center console in order to run the cables for my dash mounted iPhone setup. I have a link in my sig if you are interested in seeing what I did.
iStep 03/2023.50 |
06-15-2012, 12:39 PM | #9 | |
9
Rep 562
ZPP / ZSP / Navi
