Minimum W RMS amplifier for SWS-8
06-13-2012, 10:44 AM | #1 |
886
Rep 9,097
Hi Guy,
This may have covered earlier but I cannot find it. Looking at SWS-8 specs, it is 150RMS each. What is the minimum watts RMS amplifier should I be looking for? Any choices? I have Kenwood 4 channels, where each channel can be 60W X 4. I guess that will be underpowered for these sub. Shall I be looking for 150X4 RMS minimum amp? Any suggestions?
F36 Xdrive for her - HUD, park assist, heated steering wheel, rear camera, Apple car play
F36 RWD for him - HK, M sports pack, GTS tail light, Apple car play |
06-13-2012, 11:14 AM | #2 |
886
Rep 9,097
Well that amplifier booklet says
Maximum Power Output (4Ω) 180W x 4 Rated Power Output 60W x 4 (4Ω) Maximum Output Power 720W would that be enough for SWS-8? looking for a quick reply guys.
06-13-2012, 11:25 AM | #4 |
886
Rep 9,097
JYphay, I want only one amplifier which can power fronts + SWS-8s.
Fronts are L7, so they would not require much of power, but SWS-8s would require a lot. Coming back to my question looking at this Maximum Power Output (4Ω) 180W x 4 Rated Power Output 60W x 4 (4Ω) Maximum Output Power 720W would that be enough if use all 4 channles, 2 for fronts and 2 for subs. Or I will have to use it in bridged mode, where it can only power two subs then?
06-13-2012, 11:34 AM | #6 | |
886
Rep 9,097
Thanks Matey, looking at the RMS of that amplifier and considering against SWS-8, do you think, SWS-8 will blow the amplifier or vice versa?
F36 RWD for him - HK, M sports pack, GTS tail light, Apple car play Last edited by makkan00; 06-13-2012 at 11:49 AM.. |
06-13-2012, 12:24 PM | #8 |
221
Rep 2,339
A common cause of blown VCs is not enough power because it usually leads to excessive clipping by trying to push the amp beyond its capabilities. The clipping leads to heat and the heat kills the VC.
OP - I would say from experience that 60W each on the SWS is not enough. The SWS is very inefficient. I was able to run them off 100W each and they sounded decent but didn't get too loud. When bumped up to 250W each it was a lot better.
2016 Porsche Cayman GTS - Sapphire Blue / Black Full Leather Interior / Carrera S Wheels
06-13-2012, 12:34 PM | #9 |
223
Rep 5,120
You are right but the cause is improperly set gain not underpowering. Otherwise you would blow your subs/speakers every time you turned down the volume.
06-13-2012, 06:08 PM | #10 | |
886
Rep 9,097
Confusions kicks in when RMS watts are different to max watts. If I look at max watts of my amp, which is 180W X4 and it should be enough to power SWS. However if I look at RMS watts, then 60W should not be enough. Can somebody please clarifiy, which watts should we consider when matching speakers / woofers? Thanks.
06-13-2012, 07:57 PM | #11 | |
221
Rep 2,339
06-13-2012, 10:41 PM | #12 |
886
Rep 9,097
Thanks.
06-14-2012, 04:39 AM | #13 |
38
Rep 405
I had PDX-5 powering it, 300 watts fed to both the sws-8 in mono mode and it was loud enough for me. Never had any problem.
Upgraded to MS-8 and I am having nothing but problem, now I have dreaded bt echo.
650i F12 - HUD, 6WA, SLI, Logic 7, Dynamic and Adaptive Drive, Comfort Access, Soft-close, top-view,
Previous X5 40d M Sports and 535d LCI |
06-14-2012, 05:25 AM | #14 | |
886
Rep 9,097
so did you go for 75W x 4 (speakers) + 1 x 300W both SWS-8 in parallel?
06-14-2012, 05:33 AM | #15 |
38
Rep 405
Yes, any 5 channel amp will do, PDX was much small footprint, however keep in mind PDX is noisier, but then there are ways to filter it out. I wasn't bothered, noise was very little.
