2010 2011 BMW 5 Series Forum F10 BMW 5-Series (F10) Forums Regional Forums UK Change standard front lights?
      06-12-2012, 03:08 PM   #1
ECBMW
ECBMW's Avatar
United Kingdom
32
Drives: Metallic Grey M Sport
Is it possible to change the standard front lights bulbs to give a bit more of a white effect?
Thanks
      06-12-2012, 04:20 PM   #2
A900ss
A900ss's Avatar
United Kingdom
22
Drives: 2012 520d Touring
Philips Diamond Vision should do what you want but I'd be inclined to go Philips Xtreme because at least that way you will be able to see more than from the standard headlights even if the Xtremes aren't 'white' lights.
      06-17-2012, 02:40 PM   #3
ECBMW
ECBMW's Avatar
United Kingdom
32
Thanks. Do you have any links of the actual bulbs im after?
      07-05-2012, 01:35 PM   #4
ECBMW
ECBMW's Avatar
United Kingdom
32
Anyone????
      07-14-2012, 02:46 PM   #5
rory1968
Drives: BMW F10 520D SE
sales@powerbulbs.com. I used these guys. Good price and very quick delivery.
      10-10-2012, 05:05 PM   #6
jedpause
jedpause's Avatar
United Kingdom
159
Drives: G20 330e M Sport '21
Hi, adding to this, which bulbs do I need to change, are they H7's type that are fitted under the bay under the bonnet, or the bulbs you have to replace via the front wheel well?
My problem is mainly low beam on my Halogens, they are terrible and you can hardly see the road and object on each side of the road... thanks
Sunset Orange G20 330e xDrive M Sport Pro - Tech/Pro Pack, Park Assist Plus
Bluestone G30 M Sport - Gone to Stud
Alpine White F10 M Sport - Gone to Stud
      10-11-2012, 12:43 AM   #7
A900ss
A900ss's Avatar
United Kingdom
22
The headlights are replaced through the wheel arches and the main beam are the ones you access under the bonnet.
It's a bit fiddly but only a 10 minute job. You don't need totale the wheels off, just turn them to full lock to make more room. The screwdriver in the car's toolkit is a perfect fit.
Good luck.
      10-11-2012, 05:53 AM   #8
xenon
xenon's Avatar
England
1394
Drives: 2021 G21 330i M-Sport
It's stupid that a £30k + car does not have xenons as standard as halogens are so shite.
Ian
Current: 2021 G21 330i M-Sport
Previous: 2018 A6 Avant S-Line MMI+, 2014 F31 320d M-Sport, 2013 F10 520d M-Sport, 2011 F10 530d M-Sport, 2008 320i M-Sport Coupe, 2002 325i, 2001 318i valvetronic, 1998 318i, 1996 525i, 1990 Porsche 944S2
      10-11-2012, 07:20 AM   #9
jedpause
jedpause's Avatar
United Kingdom
159
Good luck.
Thanks... so it is the same H7 type for low and high beam... (it's just that I have seen low beam and high bean H7's advertised... but I read on this forum that it is the optics/voltage and angle in the housing that determine whether it is a high or low beam
      10-11-2012, 07:59 AM   #10
xenon
xenon's Avatar
England
1394
Voltage? All bulbs are 12v and in halogen cars the high and low beam are both H7. It's simply the postion within the parabolic reflector that changes the beam pattern.
Ian
      10-12-2012, 02:50 AM   #11
jedpause
jedpause's Avatar
United Kingdom
159
Talking
Gottit, I've ordered four of these (Philips X-treme Vision H7), will let you know the results....
      10-12-2012, 08:17 AM   #12
Deabo f10
Drives: 2012 bmw f10
hi sorry to change the subject i have recently just bought a f10 12 reg and i can get adaptive headlights quite cheap i was wondering if they are easy to fit (plug and play) ?
thanks
      10-12-2012, 08:23 AM   #13
xenon
xenon's Avatar
England
1394
Definately not plug and play. Do you already have xenons? If not you will need:
* headlamp washers
* level sensor, front
* level sensor, rear
You will then need the LKM coding for xenon lights
For the adaptive to work you will need:
* Steering angle sensor
* HBA light sensor
* HBA rear-view mirror housing
* LKM coding
It aint going to be cheap.
Ian
      10-13-2012, 01:14 PM   #14
TonkaM6
TonkaM6's Avatar
United Kingdom
26
Drives: 2018 M6 Convertible LCI
Just replaced all 4 bulbs on my car. I went for Philips X-treme 100%. Just hope they are an improvement. Also I'd like to meet the muppet that designed the front end access.
      10-15-2012, 05:25 AM   #15
jedpause
jedpause's Avatar
United Kingdom
159
+1, the access through wheel well was designed for monkeys with small hands
      10-15-2012, 05:30 AM   #16
jedpause
jedpause's Avatar
United Kingdom
159
Installed these over the weekend... main bean ones took 2 minutes... low-beam took about 15 mins each, what a PITA ! Such a small diameter entry space....
I noticed the stock bulbs are basic Osrams... consigned them to the bin.
The new ones are brilliant! Give a great white beam, and I can actually see it now and it lights up the road very, very well.... worth the cost and time...
(eBay from Upgrade Bulbs company)
5post
