Lowering Springs Question
06-12-2012, 07:24 AM | #1 |
Rep 143
Any recommendations on some springs that give a 1.5" drop and maintains decent performance and as near stock ride quality that is possible? Any downsides to springs that you can point out would be great too. Thanks!
06-12-2012, 07:28 AM | #2 |
1559
Rep 4,109
Drives: BMW M3
Dropping these cars 1.5" is about a half-inch too far to maintain optimal suspension geometry. You'll be introducing all kinds of weird handling characteristics.
That's the least of your worries, however; ride quality will suffer tremendously. The stock shocks don't have that much travel range as it is and dropping it 1.5 inches!? Hitting minor bumps will now be like hitting land mines. Not to mention you'll wear out your stock shocks, since they aren't designed to handle stiffer lowering springs, in a matter of months. Look into an entry-level coilover kit like KW V1 or ST V1, they are a matched shock and spring set that will let you lower the car while maintaining some semblance of ride quality.
2024 BMW M3 Sedan Frozen Pure Grey II/Fjord Blue, 6MT
Past: 2021 Z4 M40i Frozen Grey II/Black Alcantara | 2017 F30 340i Mineral Gray/Coral Red, 6MT | 2011 E92 335i Le Mans Blue/Black, 6MT |
06-12-2012, 07:34 AM | #3 | |
Rep 143
06-12-2012, 07:38 AM | #4 | |
1559
Rep 4,109
Drives: BMW M3
The springs ... +Price of the springs +Install +Alignment Then a few months later ... +Price of new shocks +Install +Alignment Works out to be cheaper to do it all up front, pay for one install and one alignment. I personally can't vouch for KW V1 or ST V1 but a *lot* of people use them around here. The ST are cheaper by a few hundred. People that are just using them to lower the car are satisfied in almost all cases.
06-12-2012, 08:46 AM | #6 | |
208
Rep 3,175
Consider a more simple kit like Eibach Pro Kit springs and Koni FSD shocks or Eibach's Pro System spring/damper kit. http://performance-suspension.eibach...tem__step_1_3_ Eibach springs will provide a more stock-like ride, mitigate body roll, squatting etc. Alternatively you can reach out to Harold at HP Autoworks and he will set you you with a good spring/shock combo. Point being do not just focus on coilovers otherwise I am afraid you will miss out on other quality set-ups that may you serve you just as well or better for less $. Last edited by cssnms; 06-12-2012 at 08:52 AM.. |
