Help!
06-12-2012, 02:10 AM | #1 |
Rep 34
Help!
I was driving my 07 335i today and everything was fine, I parked the car and a few hours later started it up again. I started driving and it started to shake a lot, so I turned the car off and started it up again, this time I would be at around 2k rpm in 1st and the car would turn off. Then I tried again after a while because I wasn't far from my house and I was fine at around 60km/h but anything more and it would shake, the engine light came on and *engine malfunction* came up. I'll be bringing the car to my mechanic tomorrow, but wondering if anybody has any ideas ? The car has a new engine that was put in a couple months ago and now has over 15k on it. Thanks for any feedback. It also said "low power" I believe
06-12-2012, 02:16 AM | #2 |
68
Rep 743
Drives: FBO 335i
I'm guessing it's the fuel pump. Do you have a BT tool handy or a tune that can read codes?
06-12-2012, 08:17 AM | #5 |
79
Rep 2,396
Drives: '08 E90 335i
Low Power = Limp Mode. The High Pressure Fuel Pump prob needs to be replaced (again). Between limp & the problem occuring anytime you reach highway speeds, sounds like you've gone through another HPFP.
06-12-2012, 08:20 AM | #6 |
103
Rep 3,177
without the error codes, we're all just guessing. yes, it could very well be the hpfp. it could also be VANOS. or misfires. or injectors. or a wide range of problems. limp mode indiciates an issue that needs to be corrected. withouth the fault codes, it's impossible to identify what though.
