Procede NLS Datalog 2-3-4
06-10-2012, 12:37 PM | #1 |
208
Rep 2,558
I just installed NLS on my Procede and the 2-3 shift felt weird in that once I was in 3rd gear and dropped the clutch, it felt quite underpowered... so I did a log and here it is. The 3-4 shift felt great... it was just the 2-3 shift that felt weird.
In the log, I started off in 2nd gear, then floored the car, NLS into 3rd, NLS into 4th, and then got off the gas after I was in 4th for a second. Click to download the log: Procede NLS Log 2-3-4
'07 Space Gray 335i coupe - R.I.P.
COBB ProTuned | AMS | CP-e | BMS | Quaife Last edited by skim7x; 06-10-2012 at 08:00 PM.. |
06-10-2012, 01:02 PM | #2 |
The bigger they are...
18
Rep 264
I'm getting the same problem with mine. I just thought it was my clutch slipping so I turned the NLS off. I might have to dig deeper.
Tom Williams BMW Service Advisor
'07 335i Sport 219M Wheels, MMW CF Lip, Shadowline Taillights, Vishnu Procede, BMS DCI, BMS OCC, Aasco LW Flywheel, South Bend Clutch, Turner 90mm Studs, Stoptech pads rotors and lines, BMS LED Tag Lights, BMS Clutch Stop, BMS Clutch Non-Delay Valve, ACS Style Rear Glass Spoiler |
06-10-2012, 01:15 PM | #3 | |
208
Rep 2,558
Aside from the NLS problem, does anyone know what the ignition timing curves are supposed to look like? I still don't know what is good or bad regarding timing being pulled/advanced. What is the difference between "Ign Cor" and "CAN Actual Ign Adv"?
COBB ProTuned | AMS | CP-e | BMS | Quaife |
06-10-2012, 02:59 PM | #4 | |
78
Rep 887
06-10-2012, 03:00 PM | #5 |
68
Rep 1,432
06-10-2012, 09:33 PM | #6 |
55
Rep 944
Its the drop in timing 2-3. My car does the same the slower you shift the least it happends. Its wierd!
E90 M3 AW/Extended FR•Ohlins•Borla•ACM•K&N•IND•BBS•Vredestein•Velos Designworks•Vorsteiner•BMW Performance•Lux AE•Arkym |
06-10-2012, 09:40 PM | #7 | |
70
Rep 2,197
IGN ADV= actual DME timing value Notice when you had a -3 IGN COR that your IGN ADV took a dip. If you scale it in then you see that IGN COR directly affects IGN ADV(ie -3 correction means your timing drops 3 degrees.) |
06-10-2012, 09:43 PM | #8 | |
177
Rep 6,631
I'd be more concerned with those fuel trims than timing. Timing doesn't look all that bad for pump gas actually (assuming this isn't on meth).
E90 LCI N54 6AT
06-10-2012, 09:49 PM | #9 | |
70
Rep 2,197
That's what I get for making an assumption. |
06-11-2012, 06:48 AM | #10 |
29
Rep 1,551
CAN Actual Ign Advance is calculated using DME IGN + Ign Cor. This calculation is technically true since CPS offset is a global variable. DME Ignition should be actual DME timing, as you can see any knock activity if it were present.
Skim, post AFRs. Your trims are changing to max midway during a pull. |
06-11-2012, 12:04 PM | #11 |
1737
Rep 17,960
Drives: A Lot
Garage List 2018 Ducati Panigal ... [0.00]
2016 Mazda CX5 [0.00] 2017 Aprilia Tuono ... [0.00] 2019 BMW M2 Competi ... [0.00] 2015 BMW M5 Competi ... [10.00] 2016 Ducati XDiavel S [0.00] 2016 AMG GT S [0.00] 2011 Ferrari 458 It ... [0.00] 2017 Charger Hellcat [0.00] 2015 KTM Super Duke ... [0.00] 2016 KTM RC390 [0.00] |
OP- if you are using NLS, it's important to adjust OL fuel to keep fuel trims from maxing out. If they do max out, the DME may change fuel modes (from closed to open loop) at the onset of the next gear which may last for 1-2 seconds.
06-11-2012, 04:42 PM | #12 |
62
Rep 759
Drives: '11 E92 M-Sport
^^ What would this look like on a log? I had the same thing happen to me (tho N55 procede) at the drag strip on Wednesday. I don't have NLS option (still waiting for N55's to get that) but was shifting super fast 2-3 and powershifting 3-4. I even got the SES after the 3-4.
06-11-2012, 07:40 PM | #13 | |
208
Rep 2,558
06-11-2012, 07:41 PM | #14 |
208
Rep 2,558
Shiv, how do I adjust OL fuel? Sorry for the n00b question...
06-11-2012, 10:40 PM | #15 |
78
Rep 887
06-12-2012, 04:59 AM | #16 | |
208
Rep 2,558
COBB ProTuned | AMS | CP-e | BMS | Quaife Last edited by skim7x; 06-12-2012 at 06:36 AM.. |
06-12-2012, 06:42 AM | #18 |
Freude am fahren
71
Rep 1,968
Drives: E90 N54
If you increase it you'll run a richer mixture and you won't max out your fuel trims at 34%.
Cobb E40 PROtune by Jake@PTF/RR catless DPs/aFe DCI/ETS 5" FMIC/ER CP/Forge DVs/Alpina B3 TCU flash/BMW Perf. Exhaust./BMW Performance Style 313s/M-Tech Rear
06-12-2012, 11:21 AM | #19 | |
3441
Rep 79,211
You need to increase OL Fueling in user adjustable, probably to 100.
Your AFR was recorded, your scaling is off that is why it is not on the graph. See below: Quote:
Otherwise you should be good to go. Your ignition looks pretty good for pump gas too. The easiest way to describe OL Fuel. OL Fueling: In lamens terms, the car can only add up to 34% more fuel to meet AFR target. Adjusting OL fueling will offset the tables so there is more capability in the OL system. |
06-12-2012, 12:08 PM | #20 |
18
Rep 264
As I am having the same problem, I have been following this thread. I looked at my OL fuel correction this morning and it says I am at 74.blah blah blah%. Should I adjust this setting to 100%?
06-12-2012, 12:26 PM | #21 |
29
Rep 1,551
The 5-13 or whatever the most recent revision is, had "upped" the 3D tables so the OL global value had more adjustability, and thereby became 75% OTS. Directly upping to 100% is more of a 4-13 thing. I'd up to 85%, log, and adjust in ~5% increments upwards until your trims are in the mid +20s.
06-12-2012, 07:57 PM | #22 | |
38
Rep 224
Drives: '18 M2
M2 LCI bone stock
Recently gone, i3 on H&R Springs Long gone, Le Mans Blue X1 xdrive35 M-Sport - Alpina TCU flash - HR springs - Catless dp - JB4 ST2 - CAI -- Alpine White 2007 335i E92 - Procede v3 Stg 2/3 custom - VRSP 3" DP - Stett charge + Forge DV - Stett CAI - CXracing IC |
