JB4 map3 Log HELP
06-10-2012, 09:31 AM | #2 |
Rainbow Racer
1008
Rep 2,539
What is your WG value at? What mods? Octane? Your ignition timing is starting at a very low curve.
-Loe P.-
Prior Car:'14 Audi S5 3.0t DSG [ APR ECU/TCU | Pullies + basic bolt-on mods | 10.861@127.90mph ] Current Car: F82 M4cs | TT-RS | On Order: i4 M50 |
06-10-2012, 08:02 PM | #7 |
76
Rep 1,883
Not really experienced reading JB logs, but it looks like preboost and target boost are pretty close showing no boost leak.
It looks like your meth (is meth flow shown by PWM?) is lagging in relation to throttle when you you start to go WOT which is causing some timing pulls at max boost. The graph where you shift looks nice in the next gear since meth is flowing full from the onset of the gear.
Legal Disclaimer: Anything I or anyone else says about my vehicle on this website(e90post.com or any affiliated or nonaffiliated sites), pertaining to modifications, is only to gain acceptance from my/our peers, and does not actually represent anything actually existing on my car, and thus, cannot be held against me in any issues, i.e. warranty claims, that may arise.
06-11-2012, 06:36 AM | #10 |
Rainbow Racer
1008
Rep 2,539
I would pull the additive to 40 and relog, I'm willing to bet your timing curve will then start at 10 degrees and work smoothly up to 14.5degrees near redline.
-Loe P.-
06-11-2012, 06:37 AM | #11 | |
Rainbow Racer
1008
Rep 2,539
-Loe P.-
06-11-2012, 09:24 AM | #13 |
76
Rep 1,883
What is PWM then? I was thinking that PWM was actual meth flow and METH was called for flow.
06-11-2012, 09:27 AM | #14 |
177
Rep 6,631
PWM is the duty cycle added by the JB4. When it's maxed out it won't hit boost targets. Regulated by 18ohm or 15ohm resistors.
E90 LCI N54 6AT
06-11-2012, 10:03 AM | #15 |
76
Rep 1,883
Ah. Got it.
06-11-2012, 01:12 PM | #16 |
36
Rep 1,054
Looks good! Right on target for JB4. As the additive increases, you might see a gap between target and preboost as the autotune monitors the timing keeping 8-14 degrees. It takes a few pulls with traction control off to see smooth timing lines but they will improve.
PWM= wastegate value.
JB4 beta 15 ohms FSB,AEM inline filter/ CM 10, ETS fmic, ER custom made charge pipe,TSW Donnington 18's,Simitumo HTRZ3, Injen DCI, AR DPs, Forge DVs, AA SLD, Koni FSD, ZSP springs.
06-11-2012, 01:15 PM | #17 |
161
Rep 7,377
those logs do not look good timing wise.
