Huston we have a problem
06-09-2012, 08:25 PM | #1 |
36
Rep 224
Drives: '18 M2
Sort of that is what the inside of my car looks like. Pretty much every possible alert is coming up on my display "systems controls!" FTM ABS and every on the acronym it has an alert. No codes are showing up on the procede which it makes it ever wierd. As I'm driving I will go away and come back right away.
Any thoughts? Thanks, Fed
M2 LCI bone stock
Recently gone, i3 on H&R Springs Long gone, Le Mans Blue X1 xdrive35 M-Sport - Alpina TCU flash - HR springs - Catless dp - JB4 ST2 - CAI -- Alpine White 2007 335i E92 - Procede v3 Stg 2/3 custom - VRSP 3" DP - Stett charge + Forge DV - Stett CAI - CXracing IC |
06-09-2012, 09:00 PM | #2 |
130
Rep 2,291
Did you just do an install or has anything recently occurred that you can possibly contribute this to? I'd probably go into the procede's admin section and turn off CanClear.
06-09-2012, 10:33 PM | #3 |
26
Rep 1,826
Drives: E92 335i
Actually, this happened to me not that long ago. Failed JBE was spraying garbage on one of the CAN busses causing all kinds of fun stuff to show up on the dash display.
06-10-2012, 07:44 AM | #4 | |
36
Rep 224
Drives: '18 M2
M2 LCI bone stock
06-10-2012, 07:45 AM | #5 | |
36
Rep 224
Drives: '18 M2
M2 LCI bone stock
06-10-2012, 08:48 AM | #6 |
130
Rep 2,291
06-10-2012, 01:52 PM | #7 |
208
Rep 2,558
Sorry for the sidebar... But you know it's Houston, right?
'07 Space Gray 335i coupe - R.I.P.
COBB ProTuned | AMS | CP-e | BMS | Quaife |
06-10-2012, 02:12 PM | #8 |
36
Rep 224
Drives: '18 M2
Firmware update success, I did a short drive and all alerts cleared.
M2 LCI bone stock
06-10-2012, 02:13 PM | #9 | |
36
Rep 224
Drives: '18 M2
M2 LCI bone stock
06-10-2012, 06:19 PM | #10 | |
Some dude
92
Rep 1,780
Check that connection before it damages anything! I'm pretty sure you have to remove the glove box to get to the JB. The JB is the main fuse box behind the glove box, and the JBE (JB Electronics) is the module that resides with the JB. The main battery wire to the JB is hidden behind a small grey cover. It is HOT at all times, so don't accidentally short your wrench to ground when checking it. In fact, disconnect the battery ground connection before checking it.
RRT
E92 335i/6MT with stuff and things |
06-11-2012, 01:53 PM | #11 | ||
36
Rep 224
Drives: '18 M2
Thanks, Fed
M2 LCI bone stock
06-12-2012, 07:27 PM | #12 |
36
Rep 224
Drives: '18 M2
I wasn't able to find much without taking the the glove box and bottom panels. I did, felt the front connection of the jb and check for loose connections but I saw nothing. I will have to remove the whole thing maybe this weekend.
I had a weird issue long time ago in which (I think) the DCI where touching the alternator and stuff went wrong. It was discharging the battery and lighting up some warnings. I'm not sure if this is a similar issue or not.
M2 LCI bone stock
06-18-2012, 04:59 PM | #14 |
36
Rep 224
Drives: '18 M2
Car is at the dealer, I'll report findings
M2 LCI bone stock
06-22-2012, 02:34 PM | #15 |
36
Rep 224
Drives: '18 M2
All fixed "cleaned wheel bearing magnetic pickup on both rear wheels"
M2 LCI bone stock
07-17-2012, 11:06 AM | #17 | |
85
Rep 2,438
Any details would appreciate so much. Last edited by RimasRS; 07-17-2012 at 11:13 AM.. |
07-17-2012, 11:11 AM | #18 |
Some dude
92
Rep 1,780
Wheel speed sensor gets crudded up with metallic dust from brakes and causes DSC faults. Not too common, but definitely could be a possibility.
RRT
07-17-2012, 04:08 PM | #19 |
85
Rep 2,438
But DSC not the only one it's like OP said almost all warning lights on cluster like ABS DSC Airbag Active steering and other lightened up. Also I can't open my car with key fob sometimes it's just doesn't react. I was thinking maybe it's my JBE (junction box) but if there is other problem?
Though I think I will try to change JBE will see then. Just when I saw this thread I've started to doubt is it really JBE. |
07-23-2012, 05:24 PM | #20 | |
36
Rep 224
Drives: '18 M2
M2 LCI bone stock
07-24-2012, 07:55 AM | #21 | |
85
Rep 2,438
