Bov and meth
06-09-2012, 01:06 AM | #1 |
34
Rep 513
Bov and meth
Is it true that I can't run a bov if I plan on getting meth because it will spray meth into the engine bay when it releases boost
full bolt on 6mt
cobb e30 protune fortune auto coilovers 12.08 119 |
06-09-2012, 04:14 PM | #5 |
79
Rep 2,396
Drives: '08 E90 335i
If you're using a very aggressive mix of meth, you mite have a reason to be concerned. But even w/ a BOV, any meth that escapes is a negligible amount -- the BOV will only open in between shifts, so if you're WOT the BOV shouldn't be open very long.
06-10-2012, 02:23 AM | #8 |
24
Rep 592
Drives: JB 335i-M3
Meth ignites alot easer when sprayed than in liquid form, even if the probability is minimal, you are increasing your risk.
06-10-2012, 12:27 PM | #9 |
79
Rep 2,396
Any flammable substance is more dangerous as an aerosol than as a liquid. If a BOV did release some meth into the engine bay, it would be dispersed so quickly b/c of all the turbulence in the engine bay.
If you do want the SAFEST option, you are better off using Diverter Valves that will not release any meth into the atmosphere/engine bay. |
06-10-2012, 03:03 PM | #10 |
278
Rep 5,062
Drives: Black e92 335i
Wouldn't re-circulating meth also be an issue?
I'm guessing it's too tiny of an amount of meth to worry about?
JB4 / OSS Angel Eyes / Downpipes / F1-Racewerks FMIC / Custom Meth Kit / BMS DCI / ER Chargepipe / HKS BOV / BMS Meth Elbow / BMW Performance Exhaust / Carbon Fiber Inlay Quad Tips / 19" Miro 111 / Front Aero Lip / M3 Sides / VRS CSL Trunk / Mtech Rear / DD CF Quad Finned Diffuser / LCI Tails / BBK / Smoked Reflectors / F1 Euphoria LED Interior / License LED's / GT 5000k Corners / 5000k HID Fogs / Air Scoops / LED Turn Signals / FK Silverline Coilovers / HPA endlinks / Vibrant Resonators / Osram CBI 5000k D1S
06-10-2012, 03:16 PM | #11 |
79
Rep 2,396
The meth would be recirculated back into the intake tract, which is why some meth users experience less carbon build up in their intake valves.
06-10-2012, 04:04 PM | #12 |
70
Rep 2,197
06-10-2012, 05:02 PM | #13 |
278
Rep 5,062
Ehhh, I'm not a fan of injecting pre-turbo and this seems to end up with a similar effect although it's probably a negligible amount.
06-10-2012, 11:52 PM | #14 | |
Rep 61
06-11-2012, 08:44 AM | #15 | |
79
Rep 2,396
All meth injected into the CP during WOT will reach the intake valves, but we were discussing the potential for a fire if meth was released by a BOV into the engine bay. B/c a BOV vents directly into the atmosphere (more specifically the engine bay), if you are running an aggressive meth blend (greater than 70%), there is a potential for fire. With a 50:50 mix, there is close to zero concern. The power gains between a 50:50 mix & 75:25 mix are minimal, but the potential for a fire igniting is drastically different. |
06-11-2012, 08:55 AM | #16 |
33
Rep 1,029
You could always relocate the BOV, ive thought about changing my BOV location to the hot pipe just before the intercooler, or mounting it to the intercooler itself. Full Race often mounts their BOV directly on the intercooler(hot side) with the theory that its better to vent the hot air than the air that has already been cooled by the intercooler.
06-11-2012, 08:58 AM | #17 |
79
Rep 2,396
Great in theory, sounds like a bitch for fabricating
06-11-2012, 09:02 AM | #18 |
33
Rep 1,029
Find a spot on your piping, mark it, head to your local speedshop to weld a new bung on. Depending on your BOV, either make a block off plate (easy for the greddy style) or have them cut the flange off and weld a piece of alumnium over it. Run a new vacuum line down to wherever you mounted the BOV and your done. Sounds like an average enthusiasts saturday if you ask me.
06-11-2012, 09:04 AM | #19 |
79
Rep 2,396
Tru.... I'm happy w/ my Forge DVs & meth-less car, so whatever floats your boat.
