Studio RSR
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Powertrain and Drivetrain Discussions > N54 Turbo Engine / Drivetrain / Exhaust Modifications - 335i > Aquamist HFS-4 Install DIY (Lots of Pictures)
      06-08-2012, 12:17 PM   #1
E90SoFlo
196
Drives: E90 335i
I received my HFS-4 System from Jeff @ Howerton Engineering with his "Two Gallon Twin Tank" setup, I have to say, this system looks awesome, its all put into a beautiful black box and looks very well put together and it all fits nicely together.
I did the install myself with 2 jack stands, it really was an easy install, It only took about 10 hours to install.
First thing I had to do was find where I wanted to mount the tank, I ended up choosing the left side, above the OEM speaker Amp. I chose to mount the tank here because I didn't like the idea of meth lines, and tanks over the battery, incase I had to change the battery or if I have any issues it won't leak all over the battery and cause more problems.
Luckily on the left side there was already 2 holes going into the fender well that I was able to just instal grommets into and they worked perfectly for the meth line and the plug to plug into the HFS-4 "Box".
These are the holes I used
With the two lines going in
It comes out right next to the fuel line, which was really convenient, I tried getting a good picture, but this is the best I could do.
Then I ran it under the car via the fuel line
I ran the power line to the battery via the OEM wires that run under the "spare tire" cover in the trunk.
Closeup of the wires going from the tank/pump
Mounting the gauge I decided to put it into the ash trey, I wanted to be able to close it and make it look OEM which I feel this does.
Full interior picture
Few trunk pictures (sorry the lens kept fogging up, the humidity in Florida is horrible) Don't mind the sub wires and dynamat. (the wires that are showing)
Jeff has been a great help and answered my many emails and questions I would definitely recommend buying your next tank/meth setup from him!
I would highly suggest this system to anyone running any of the major tunes, even the piggy backs. The failsafe works flawlessly with very little setup.
      06-08-2012, 12:20 PM   #2
E90SoFlo
196
Drives: E90 335i
Reserved for updates
      06-08-2012, 12:20 PM   #3
bryce
103
Drives: zhp 3-pedal
heh, i recognize my old trim
nice DIY
      06-08-2012, 12:25 PM   #4
Laid Black 335i
BMW
Laid Black 335i's Avatar
Drives: 2007 BMW 335i (6MT)
Are you protuned yet?
Nice DIY!
      06-08-2012, 12:30 PM   #5
E90SoFlo
196
Drives: E90 335i
Nice DIY!
I can't comment on the tune, Cobb will be releasing Meth maps "soon".
      06-08-2012, 12:45 PM   #6
rader1
70
Drives: Cobb Stage 2+ 135i
Lol our gauges are setup identically
      06-08-2012, 01:06 PM   #7
nafoo
nafoo's Avatar
Drives: Boosted Bimmer
Do you have the unit in the glove box?
Were all the wires connecting to the HFS-4 unit long enough to to reach everything?
I'm going to be moving from WW to the trunk soon too.
      06-08-2012, 01:09 PM   #8
F80M
F80M's Avatar
88
Drives: M Fap
Nice...top notch system. How hard to set it all up to make it integrate with your tune?
      06-08-2012, 01:23 PM   #9
idrift4wd
149
Drives: Three Hundred and Thirty Five
2007 BMW  [7.00]
looks awesome!! love your set up!
      06-08-2012, 02:04 PM   #10
Lulz_M3
Drives: AW 335i 6MT
Man your gonna need meth to overcome the weight of all that dynomat. Got any pics of how you mated the wiring harness from the HSF4 to the DME connections?
      06-08-2012, 02:36 PM   #11
nafoo
nafoo's Avatar
The kit came with these really cool splice connectors. All you had to do was find the right wire and screw a connector on that had a needle in it.
Can't seem to find these anywhere.
Edit: Found it: http://www.amazon.com/Posi-Tap-Conne...184482&sr=8-11
      06-08-2012, 02:45 PM   #12
Lulz_M3
Drives: AW 335i 6MT
Im waiting on Jeff to mail mine out from the GB, i asked for those connectors as well. Just curious how hard the wires were to gain access to. Guess ill find out next week. The only thing im worried about now is having a stock clutch =(
      06-08-2012, 08:02 PM   #13
3-Serious
Drives: AP e92 335i
Nice set up! I plan on doing mine the exact same!
Cobb JR Tune, HFS-4, DCI, AMS Intercooler, Vishnu CP, Forge DV's, AR DP's, RPI exhaust, AR OCC, BMW STS, Spec stage 3+ clutch, CDV delete, H&R Coil overs, Quaife LSD, DefiV Lock down kit, WOTbox.
-SOLD
      06-09-2012, 08:11 AM   #14
3-Serious
Drives: AP e92 335i
Also where did you put the actually hfs-4 unit? In the trunk with the tank and pump?
-SOLD
      06-09-2012, 11:06 AM   #15
E90SoFlo
196
Drives: E90 335i
Thats awesome! haha
The HFS-4 Box is in the ECU compartment, Everything was long enough and fit perfectly, Def. Get a trunk tank!
Everything was very easy, setting up the failsafe was a breeze and it works great with Cobb
The wires are basic, just take your time and go step by step. Stock clutch should be fine!
Thank you!
I dont, the ECU box looks completely OEM, you can't even see where the HFS-4 wires are.
NOT CORRECT You can use posi-taps like posted above, but you can also request the OEM ECU pins, and you actually pop the OEM pin out, and replace it with the new pin, plug the OEM pin into the harness pin and you're done, its like a small piggyback. Very easy to set up.
The HFS-4 "box" is in the ECU compartment, the HFS-4 Pump is in the black box in the trunk!
Thanks everyone!
      06-09-2012, 08:57 PM   #16
badass335
badass335's Avatar
109
Drives: 2017 540i Xdrive
Just curious. Did you order the ecu pins from Jeff?
      06-10-2012, 12:10 AM   #17
marv85
marv85's Avatar
70
Drives: '07 E92 335i MT
Thank you for sharing! will definitely leverage your experience wen I eventually get mine
'07 E92 335i 6MT- HP650, inlets/outlets, ER FMIC, VRSF CP, LPFP stg2, CSF rad, 'is Aux rad, ER OC, Ohlins, M control arms, eibach front sway bar.
'05 C55 AMG
SOLD - '22 Tesla M3P | '10 E92 335i M, 6MT COBB, FBO, st2 LPFP, Mfactory LSD | '07 E90 335i, PTF COBB E50, FBO, HFS4
      06-10-2012, 08:46 AM   #18
E90SoFlo
196
Drives: E90 335i
Yes! Jeff had a special order of the ECU pins, they take longer then posi-taps and I think there is an up charge. (Not 100% sure)
Thanks for reading!
      06-14-2012, 02:02 PM   #19
E90SoFlo
196
Drives: E90 335i
Here is a photo of my ECU box and the HFS4 box inside it.
      06-14-2012, 02:25 PM   #20
nafoo
nafoo's Avatar
Mine came with posi-taps!
Did you change any of the settings inside the HFS-4 unit? What about on your gauge?
      06-14-2012, 02:42 PM   #21
E90SoFlo
196
Drives: E90 335i
Yes you have to change it to DR1 inside the box, and you have to set the failsafe on the gauge, all very easy.
And honestly I think posi-taps would have been easier.
      06-14-2012, 05:05 PM   #22
nafoo
nafoo's Avatar
I mean the little knobs inside the unit that require a tiny flat head.
Yeah, first time using posi-taps and I'm in love
