Scan Tool
06-08-2012, 05:20 AM | #1 |
Rep 34
Scan Tool
Hi,
Can anybody recommend a scan tool (make and model number) to check and re-set fault codes? Can you check and re-set fault codes through the iDrive system on a 335i? Can you re-set service schedules through the iDrive or do you need to do it through the OBDII port? Thanks. |
06-08-2012, 06:35 AM | #4 | |
Rep 34
Does the BT TOOL let you scan for fault codes and re-set them and re-set service schedules? Where can you buy them? How much do you charge for fault code checking and re-set service schedules? Thanks. |
06-10-2012, 07:09 PM | #5 |
86
Rep 1,993
Vishnu PROcede V5 | VK Motorworks FMIC | AR Design OCC | Forge DV's | Bilstein PSS9 | M3 Lower Control Arms & Caster Rods | Quaife LSD | HiTech Exhaust | BMW Performance Illuminated Door Sills | BMW Performance Gear Selector & Boot | BMW Performance E-Brake Cover
