Extreme Powerhouse
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Powertrain and Drivetrain Discussions > N54 Turbo Engine / Drivetrain / Exhaust Modifications - 335i > 30FF
      06-08-2012, 01:02 AM   #1
lawwailok
lawwailok's Avatar
Drives: E90 335i, E70 X5
30FF
i had this weird problem for a few times since last 2 weeks. on normal driving, if i do occasional WOT, car was running fine and boost is normal. but if i do couple gears WOT, let's say from 2nd - 4th WOT all gears, as soon as it shifted to 4th, i always get 30FF code and also i do hear a louder "air hissing/inhaling" noise.
and after that and plug in the AP, i do notice the boost is lower than usual but not low enough to trigger another 30FF. currently running cobb S1+ and i should see ~15psi average and tapper down to 12psi towards redline. with that incident happens, max boost i can only see 10.9psi.
which area should i narrow down the possibility?
current setup: cobb s1+, ets fmic, forge dv, bmw pe.
thanks for all the help!
-eric
E90 335i TiAg *STOCK* see my garage for mod list..
E70 X5 SGM *try to stay stock* :/
      06-08-2012, 01:05 AM   #2
enrita
enrita's Avatar
Sweden
161
Drives: 335i - Big turbos
the usual suspects: charge pipe, dvs , intercooler connection. Check first Dvs.
      06-08-2012, 01:09 AM   #3
lawwailok
lawwailok's Avatar
DVs are new and just installed 2 weeks ago with the optional stiffer springs. now on the CP, what should i look out for? thanks for the suggestion!
-eric
      06-08-2012, 01:26 AM   #4
enrita
enrita's Avatar
Sweden
161
Since you installed the dvs 2 weeks ago i woulf focus on that area.
      06-08-2012, 02:26 AM   #5
EDM92
EDM92's Avatar
Drives: Low&Slow
+1
Montego Blue 2007 E92 335i - ZSP / ZPP / Steptronic / Logic7
Broadway Static - CCW - Megan - Orion
Instagram: bmwforlife
      06-08-2012, 02:35 AM   #6
blisstik
blisstik's Avatar
151
Drives: E92
n00b install, haha! I told you man, it could be your FMIC connectors. They get mad oily.
      06-08-2012, 03:03 AM   #7
lawwailok
lawwailok's Avatar
i just went to the garage and checked. without jacking up the car and inspect the couplers from the IC to the pipes, all the visible area were checked. only thing was odd is one of the DV wasn't sit totally in to the connector. i ensured they were sit flush when i did the install. so i pushed it back down and re-lock the grey tab. i'll monitor the boost again tomorrow and hopefully i can find a road allows me to do 2-3-4th gear WOT again and try it out.
LOL sup bro, let's get our hands dirty on that Sunday night while doing my suspension, how's that? =)
-eric
      06-08-2012, 12:15 PM   #8
BES335xi
BES335xi's Avatar
Albania
83
Drives: FBO+ N54xi
03/07 E90 335xi  [1.00]
Can boost leak and that 30FF code trigger other codes and make you go into limp mode? went wot last nite and after i go past 100mph i get into a limp mode scanned the car and saw 30ff and 2fbc i think, now i just had hpfp replaced few months ago, would totally suck if its a hpfp again..
JB4+usb | P3 Vent Boost Gauge v2 | BMS OCC | BMS DCI | AMS FMIC | AR xi CL DP's | BT Tool | Edibias/NCSExpert/INPA BMW Coding | Cyba Quad Exhaust tips | M-Tech Rear & M3 Front Bumper | Red Cyba Air Scoops | Blacklines | Vinyl Overlays | ACS Roof Spoiler | Matte Black Grilles | LED Side Mirrors | Rear Euro Fogs | etc..
      06-08-2012, 12:23 PM   #9
E90SoFlo
196
Drives: E90 335i
If you can hear the leak its obviously very large.
Im check to make sure your charge pipe hasn't popped off the throttle body.
      06-08-2012, 12:36 PM   #10
335(EX)(EYE)
Drives: e90 n54 & n55 / e46 330ci DD
that always happened to me, dude its 30ff its a boost leak or something obvious, its not hpfp u would have associated codes for that to if it was that
      06-08-2012, 12:55 PM   #11
CUTigers
CUTigers's Avatar
Drives: 2008 Montego Blue 335i
2008 Lexus IS F  [10.00]
2008 e90 335i  [9.00]
My 30FF was for busted and cracked vacuum lines.
      06-08-2012, 02:16 PM   #12
Chefcg1
Chefcg1's Avatar
Drives: 2008 BMW 335i
mine was a bad wastegate
2008 335i coupe AW 6AT, RB Turbos, PROcede 2.5 V5, Alpina Flash, Injen Intake, VK MW DP . Helix IC, Vishnu PnP Meth(M10 nozzel), M3 sides, OEM Aero Lip, VMR V710 Midnight Blue, LUX H8, HID Fogs, M3 front bits, D2 Coilovers, Whiteline Rear Bushing inserts, Custom M3 Steering Wheel, Cyba scoops, M2 Performance Exhaust
