335i straight pipe problems
06-07-2012, 10:52 AM | #1 |
Rep 14
I recently removed my exhaust and resonator from my car. It sounds good but I feel I lost low end power how can I solve this but keep the sound? Oh I have afe dual cone and Cobb as well
06-07-2012, 11:12 AM | #2 |
149
Rep 3,552
i have a feeling that you need some sort of back pressure to regain that torque back, but a turbo car there really isnt back pressure. maybe its in your head?
06-07-2012, 11:20 AM | #3 | |
70
Rep 2,197
Since we have turbos they are going to be the big restriction in the exhaust and what we do post turbo isn't going to have the same influence on flow as it would on a non turbo car. However, full catless has shown to have some HP gains. OP, Its all in your head. |
06-07-2012, 11:20 AM | #4 |
Rep 14
Thats what I was thinking. It's not in my head fully I did a data log before and after and it did effect it. I might throw on some resonators and see if that helps.
06-07-2012, 11:25 AM | #5 |
70
Rep 2,197
06-07-2012, 12:22 PM | #10 |
79
Rep 2,396
Drives: '08 E90 335i
If you're looking to speed up adaptation, you've got 1 of 2 options:
06-07-2012, 12:52 PM | #11 | |
71
Rep 510
'2018 F87 M2 LCI | LBB | GC Camber Plates | Ohlins R&T 90/190N/mm | 18x10 et33 square 275/35 | MPe | Poly Transmission Mounts | Recaro Sportster CS
06-07-2012, 12:57 PM | #12 |
79
Rep 2,396
Exhaust modifications (DPs specifically) seem to be the biggest shock to the DME b/c of the o2 sensors. A catless system usually throws a wrench into the system b/c of the emissions the car starts trying to make "trimming corrections" (the specific fault code wording), which then can cause misfires/limp mode/decrease in power.
06-07-2012, 01:01 PM | #13 | |
71
Rep 510
06-07-2012, 01:07 PM | #14 |
79
Rep 2,396
If you're not getting a CEL/SES light, misfires or any lambda bank/emissions-related codes + your logs are good, then you're fine. Some people (myself most recently) get lambda bank fault codes when they install DPs, which like I said then triggers misfires. At that point, reseting your adaptations would be a good place to start.
06-07-2012, 01:37 PM | #16 |
79
Rep 2,396
There is a reset option on the AP, but I'm not sure if that goes as in depth as reseting the adaptations.
06-07-2012, 01:40 PM | #17 |
Rep 16
^QFT. For years I've been trying to explain to people that backpressure is always bad, NA or FI, and that the key is exhaust gas velocity.
06-07-2012, 05:06 PM | #18 |
Rep 14
So what should I do to fix my problem of Low end power loss. It def with out a doubt doesn't kick like it did before around 3k it does higher around 5k.
06-17-2012, 02:19 AM | #19 |
instagram: black.listed_
20
Rep 238
I have a similar problem! I've installed my Catless Downpipes prior to my freeflow exhaust, and the power difference is amazing! Until I installed my full exhaust, everything seems boggish as well, as if "hollow" or "loose" power engagement. Anything else I Could do besides unplugging the battery? That is because I've programmed my LED amber lights off and all, so I don't want everything to reset~
