BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Powertrain and Drivetrain Discussions > N54 Turbo Engine / Drivetrain / Exhaust Modifications - 335i > Ugh. JB+ problem.
      06-07-2012, 08:33 AM   #1
Turb0Surge
Turb0Surge's Avatar
Drives: BLACK e90 335i
Ugh. JB+ problem.
So... I picked up a used jb+ for cheap yesterday online. Didn't wana spend the money for a jb3/4 and would have been more than satisfied with the 40 hp gain the jb+ offers.
So I install the jb+ (simple enough) and when I reconnect the battery and start the car it automatically starts shuddering and rpms start jumping. When you put it into drive it starts jerking horribly and after a few moments CEL comes on and it goes into limp mode.
The car does not have these problems when jb+ is disconnected.
Help anyone?
      06-07-2012, 08:35 AM   #2
E90Company
E90Company's Avatar
194
Drives: Car
Are you sure it's connected to the correct sensor?? I know my friend said that two connectors looked very similar when he was installing his.
PS Post in N54 section
      06-07-2012, 08:45 AM   #3
Turb0Surge
Turb0Surge's Avatar
Yeah it's the correct one.
      06-07-2012, 08:50 AM   #4
BAL278
BAL278's Avatar
48
Drives: E92 335xi JB
Yeah.. I would also check what it is set to, but more than likely it is not connected properly, you don't need to disconnect the battery, just make sure the ECU goes to sleep
2008 335xi Jet Black//Coral Red
VTT Stage 1+// Procede V5//VRSF DPs//AMS FMIC//KW V1//M3 Sways & Sub Bushings// Alpina AT flash
Apex EC-7//Michelin PSS//Dinan CAI
      06-07-2012, 08:53 AM   #5
Sara
5791
Drives: A car
Uh oh...
      06-07-2012, 08:58 AM   #6
Turb0Surge
Turb0Surge's Avatar
Yeah, it was originally set to 100%. Now it's at the minimum setting.
      06-07-2012, 10:09 AM   #7
86rexer
0-335 in 4.9 seconds.....
86rexer's Avatar
18
Drives: 2008 335i E90
Exactly what he said . open the hood prep the area and put your keys inside the house, and wait for at least 15min...or disconnect the battery for a definite power off.
      06-07-2012, 11:21 AM   #8
Turb0Surge
Turb0Surge's Avatar
No its definately plugged in correctly. In fact, I took it off/ on 4 times. (each time I dilaed down the boost) now I'm at minimum boost and it still does it. Battery was disconnected when I put it on each time.
      06-07-2012, 11:55 AM   #9
Lulz_M3
Drives: AW 335i 6MT
You are either installing it wrong or you got sold a bricked JB+. Are you following the instructions from Burgers website? You might be plugging it into the map sensor in the intake manifold instead of the one on intake pipe before the throttle body.
      06-07-2012, 11:56 AM   #10
Turb0Surge
Turb0Surge's Avatar
Yeah, followed all instructions. And sadly, I have been plugging it in correctly so I think it is a bad chip. But I bought it on ebay so hopefully I'll get my money back.
      06-07-2012, 12:14 PM   #11
quasitime
Drives: 2007 335i 6MT
You may want to check the connections on the JB+. The wires have a tendency to get pulled lose out of their sockets from the removal process. It is pretty noticeable if you shine a light inside the connector, and look to see that all the metal contacts are lined up correctly. When this happened to me, one of the contacts was pulled back.
      06-07-2012, 12:20 PM   #12
benzy89
Drives: '08 E90 335i
2008 BMW 335i  [7.50]
Poor choice making the eBay purchase -- Sounds like you either got screwed with a fake/broken JB+ or when you're putting the tune on, it's inducing misfires since you're running the car at a higher performance settings. I'm dealing with this right now -- My car was running at COBB Stg 1, but now that I've bumped the tune up to Stg 2 the car is misfiring (replacing the plugs/coils this weekend).
      06-07-2012, 02:18 PM   #13
Turb0Surge
Turb0Surge's Avatar
***UPDATE***
I just went out to lunch and before I went i took the jb+ out. (using proper procedure, of course) Drove to in-n-out and CEL disappeared, and car started pulling normally and no sputter. Basically running how it's supposed to.
When I was installing it I disconnected the battery and then installed it as opposed to waiting 15min with the hood open for the ecu to fall asleep. (Jb website says either way is fine) maybe that's my problem?
      06-07-2012, 03:03 PM   #14
benzy89
I can't answer 100%, but if you didn't follow the install correctly that might be a reason why it didn't work out well.
      06-07-2012, 11:45 PM   #15
tanginaglaz
tanginaglaz's Avatar
Drives: 2007 e92 335i
Take pictures of how you installed it. Just want to confirm that it was installed properly. I would also suggest to pull the codes.
Tags
335i, bmw, jb+, problem, tune
