Meth - Risks/Considerations
06-07-2012, 07:50 AM | #1 |
Rep 54
I'm considering installing a Meth system, but have a few questions.
How much risk am I assuming by installing this? Is Meth only for the super die hard? Or does it carry a moderate amount of risk, but overall isn't something to be overly concerned about? Does Meth work better for piggybacks (PROcede) than Flashes (Cobb)? Which meth kit is considered the standard? Is it the PWM thru vishnu? or thru aquamist? or is the pwm aqua mist? Will an independent mechanic install meth kit for me? or is this somethign I will have to do on my own. The install guide looked painful. thanks.
09 335xi Barbara Red Metallic Cobb AP BMS DCI
06-07-2012, 07:53 AM | #2 | |
161
Rep 7,377
06-07-2012, 08:08 AM | #3 |
1837
Rep 6,990
Drives: 15 F80 M3, 22 G01 X3 30i
It goes without saying you will need a different charge pipe with a "meth elbow". One thing to keep in mind is that you probably don't want to use a blow-off valve with meth, as spraying that meth mixture into your hot engine compartment on throttle lift-off could have disastrous results. If your BOV can be diverted to vent under the car, then that would be better; otherwise, you probably want to use diverter valves (stock or otherwise). Also, watch where your meth lines are routed - you definitely don't want them melting or rubbing against something to produce a leak under the hood.
2015 F80 ///M3 Sedan 7DCT Tanzanite, 2022 X3 sDrive30i 8AT Brooklyn Grey |
06-07-2012, 08:29 AM | #4 |
Joint Chiefs of Staff
4918
Rep 115,980
The best advice for meth is to go with the kit your tuner recommends and supports. So pick your tune first and then decide on meth kit. Right now the Piggy's (JB4, PROcede) handle meth better then the flashes (COBB, GIAC)
Mike |
06-07-2012, 09:04 AM | #5 |
133
Rep 4,764
Based on recent threads you might read up on tank placement and also consider keeping a fire extinguisher in the cabin. I have had no problems in a couple of years with my kit (tank in trunk), but I do keep a fire extinguisher in the cabin just in case.
06-07-2012, 09:07 AM | #6 |
79
Rep 2,396
Drives: '08 E90 335i
Bro, I don't know if you're ready or knowledgable to be jump into the meth game yet. You started a thread a month ago about the difference/benefits of a single-turbo setup vs. a twin-turbo set up. I also see you're running a COBB setup with just an intake, so you might want to consider getting some DPs & run Stage 2 on your tune before you make the jump straight to meth.
It is YOUR car so I'll answer your questions:
Like I originally said, I think you should start shopping for DPs + running Stage 2 on your COBB before you think about meth. While the jump in power won't be as significant as going from Stock to Stage 1, going to Stage 2 will give you a very healthy jump in power that might satisfy your thrist for power until you become a little more "informed" on meth. |
06-07-2012, 10:11 AM | #7 |
40
Rep 957
u may have trouble finding a local shop to install methanol especially on a bmw. truth is the install is not that bad. the pwn was my first dealings with meth and i had my battles during install but everything runs great now and i love methanol lol. i feel like id want methanol on anything boosted that i ever have again. totally worth it and impacting. there are many variables when you have an issue in your meth flow and performance of ur kit. air getting in the lines? hardware issue? wiring? relay? when you have issues with something with a lot of components it will pay off to have done the install yourself bc you know what you did and the points of possible failure etc and will be familiar with the kit on your car. the pwn install is easy imo. and it runs excellent with the tune. this is my first and only experience with meth and i havent looked back. have had no safety issues, just great power, consistency, and healthier logs
07 335i- SOLD, and will be missed...
Parts for sale- PWM meth kit, M steering wheel, M shift knob, perforated e brake handle |
06-07-2012, 10:39 AM | #8 | |
Rep 54
Thanks for your informed response.
06-07-2012, 10:52 AM | #9 |
Freude am fahren
71
Rep 1,968
Drives: E90 N54
subscribed
I think this is a great question, actually, as I have not seen a lot of discussion on the risks associated with this modification. Although I also haven't been searching for it so that could be why! Methanol is a level of tinkering that I'm not interested in getting involved in right now but at least the OP has the right idea to be asking these questions. It is very easy to fall into the peer pressure "all the cool kids on the forum are doing it" mentality which can lead to disaster. Benzy has it absolutely right about doing DVs, CP, DPs, and FMIC before even considering methanol. And the fire extinguisher suggestion is also excellent. If I were going to do it, I'd wait until I had the funds for the absolute best kit out there. Not something you want to skimp on IMO.
Cobb E40 PROtune by Jake@PTF/RR catless DPs/aFe DCI/ETS 5" FMIC/ER CP/Forge DVs/Alpina B3 TCU flash/BMW Perf. Exhaust./BMW Performance Style 313s/M-Tech Rear
06-07-2012, 11:14 AM | #10 |
79
Rep 2,396
+1, since meth has danger potential, you def don't wanna buy the "budget kit". OP, I'm not sure why you're considering selling your 335, but I can promise that you won't be short on power with a FBO N54. I daily drive my car & only ran a Stage 1 tune & loved how it transformed the car -- Now that I'll be FBO, I can't imagine what it'll be like running Stage 2 as my "normal" map
Trying to resist the temptation to take my modding further (not looking to empty the bank account). Was at VAC the other day and they showed me how they're not only doing a custom-Quaife LSD install, but they're also porting N54 heads and prepping for a turbo upgrade |
06-07-2012, 11:59 AM | #11 |
65
Rep 1,708
If you want easy power:
sell the Cobb, purchase a piggy and meth kit, tap your charge pipe (or better IC pipe) and turn up the boost. A good 30 to 50 more HP over FBO/pump. OR you could run piggy and 50% E85... still more HP then FBO OR you could try Cobb stage 2+ on 50% E85... this would be fun. |
06-07-2012, 12:02 PM | #12 | |
Rep 54
Thanks for your posts gents.
06-07-2012, 12:14 PM | #13 | |
79
Rep 2,396
If you're active enough on the forums, you'll know the problems that come w/ owning this car (HPFP, misfires, frequent oil changes) and be able to avoid any serious, expensive problems by responsibly modding + caring for your car. |
06-07-2012, 01:23 PM | #14 | |
Freude am fahren
71
Rep 1,968
Drives: E90 N54
The one thing that many people on here refuse to accept is that you are taking significant risks when you tune a car. It is not free, and you have to pay to play. Sure it is fun to push your car and mod it (believe me, I've got the sickness pretty bad!) but living on the edge of financial disaster at all times for the depreciating asset in your driveway isn't very smart either. (I'm not saying this is you per se, just speaking generally here about some of the folks on this forum). I guess what I'm saying is if you're at that stage in your life where money is a factor then just go FBO, take your 400 whp and gobs of torque that will smoke 99.5% of cars on the road and be done with it. If you want more than that, sell your 335 and buy a Boss 302. With proper maintenance your car will be fine. I think adding methanol etc. is a level of tinkering that you (and me) are not really ready for.
06-07-2012, 01:30 PM | #15 |
79
Rep 2,396
This is going to be a treasonous claim, but here we go..... I just don't like the idea of meth as whole -- IMO it's "fake" power (the minute that tank empties, the magics over) and I'm not a fan of turning my car into a torch if anything leaks.
06-07-2012, 01:42 PM | #16 |
Freude am fahren
71
Rep 1,968
Drives: E90 N54
oh man get your flame suit on!!!! LOL But actually the same is true with the gas tank!!!
06-07-2012, 01:45 PM | #17 |
79
Rep 2,396
Think I'm ready for the hate to starting raining from all the meth junkies
If you want power, go FBO. If that's somehow not enough, invest in some RB/ASR turbos, dial in some extra boost and hold on to your asshole. Last edited by benzy89; 06-07-2012 at 01:51 PM.. |
06-07-2012, 02:09 PM | #18 |
3441
Rep 79,211
Well here is my .02
Here is when methanol can work on Cobb to reap the maximum benefits. If you have a Cobb tune only, and add methanol you can use stage 2 aggressive to almost maximize gains. (If you have full bolt ons you still wont be able to maximize gains without using the below options). You would need their race maps, (which I dont know if they are available to the public yet), OR ATR, which allows you to tune yourself (unsure if its available yet) or Custom tune which can cost anywhere between 300-600+ depending on where you go, and not all places will tune methanol. Now before the others jump down my throat about this recommendation, I can tell you it is much easier to get methanol going on a piggyback, for 2 reasons. Please understand this is not a sales pitch it's just straight facts. Reason 1 is cost Reason 2 is maximizing benefits easier You can purchase a generic methanol kit, and generic failsafe and flow sensor and whether you run a Jb4 or PROcede you will be maxing out your ignition and boost for full benefit, with no draw backs. You will also be able to switch maps on the fly and using a failsafe/flow sensor be sure you are flowing methanol and everything would be safe for your engine in that regards. Now, before I get attacked, Yes, you can run methanol on Cobb, and yes you can get something like an Aquamist HFS-4 methanol kit, and have a failsafe built in to bleed boost if methanol isn't flowing. However, I'm not sure at this juncture if you are able to maximize the benefits without a professional custom tune/ATR/or Race maps. If you can then it will be something to consider of course. However, all said and done it is going to cost more and it's not going to be as feature enriched as a piggy. If cost is not a concern and either pro tune, race maps, or ATR are an option then the only thing a Cobb doesnt have over a Piggy is the on the fly map changes and flow sensor read outs in dash. However, one can purchase a flow sensor gauge if they so incline. This is honestly the most unbiased response you will find here and whichever route you choose can work. |
06-07-2012, 02:20 PM | #19 |
3441
Rep 79,211
I'd also like to add that I truly believe people should understand how methanol works, how to install it, how to remove it, how to troubleshoot it, and have a buddy that has one. I dont recommend people have it installed by a professional without understanding it fully. Although that sounds funny that I would advise against professional install, I dont advise against it so as long as you understand how it was installed,works, the risks, and how to troubleshoot. 9 times out of 10 people have it installed, something goes wrong, and they have no idea where to start or what is what.
As people are coming to realize it is not for amateurs and does come with it's inherent risks. I do tell people to avoid using windshield washer reservoir kits because of the fire risk. There are other options to consider like race gas and E85. |
06-07-2012, 02:30 PM | #20 | |
56
Rep 1,311
06-07-2012, 02:51 PM | #21 | |
Freude am fahren
71
Rep 1,968
Drives: E90 N54
06-07-2012, 03:27 PM | #22 | ||
3441
Rep 79,211
I didn't even get to touch base on the simpler things of methanol. A few years back when methanol was introduced we were still learning the correct amount to spray and how that effects fuel, intake air temp, avoid meth quenching and stuff. I feel nowadays it is so easy to read something on the forum, buy it, have a pro install, and drive home really takes away from all that comes together to get the system working properly/efficiently. I remember one of the first kits to hit this platform came with a single M5 (5 GPH nozzle) and everyone thought it was sufficient, just like 14 PSI was too much boost, it is amazing how platforms develop and change over time. |
