M V 2 wheels
06-06-2012, 06:45 AM | #2 |
193
Rep 6,110
Drives: Don't know yet!
They will fit John,but you'll need spacers to push them out.
The offset for the rear MV2 wheel is ET50,so a hubcentric spacer (Eibach/H&R) of 15mm would be safe,this will give you an offset of ET35. There is a possibility that a 20mm spacer would also work as the MV2 is a 8.5j wheel as opposed to a 9/9.5J. The offset for the front MV2 wheel is ET47,so I'd repeat the above,but the offset would become ET32,again a 20mm spacer might work as the front MV wheel is 8J. Teddy @: http://www.ssdd-motorsport.com/ is your best source,although I'd ring him,rather than order through his website. |
